Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
rear sway bar for 1.40 & quicker cars
Old 10-27-2014, 05:21 PM
  #51
DIGGLER's Avatar
Re: rear sway bar for 1.40 & quicker cars
Update. Last week went 1.37 and pair of 1.39's. car still has more left if tires hold. Gonna try more rpm or more boost off line if it will make more at the lower rpm. Leaves straight and smooth. Love the feeling
et?
Old 10-27-2014, 06:27 PM
  #52
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
didnt make the pass. just workin launch since car had issues
Old 11-03-2014, 08:54 PM
  #53
87_TA's Avatar
Qwik84 - What kind of 60fts are you pulling with this bar? I have a comp universal that has gotten me 1.25 best so far on radials - But getting some twist still and feel that 1" universal is much of the fault. Just curious what that bar can handle. Was thinking of going Spohn or BMR - Just want to make sure I am not downgrading.
Old 11-03-2014, 09:51 PM
  #54
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
tom, i believe it would be a downgrade. you need a true drag bar if you don't have one already. even BMR said that anything quicker than a 1.30 might be pushing it.
Old 11-03-2014, 10:05 PM
  #55
87_TA's Avatar
Ahg.. I think I am twisting mine now.
Old 11-04-2014, 06:07 AM
  #56
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Umm you went 1.25 on the back tire! If anyone hasnt seen it yet
Old 11-04-2014, 06:38 AM
  #57
no green's Avatar
Kwick & I don't have the horsepower to move out that quick (yet).
FWIW, the Stainjanger bar is "Hollow 1.25 x .120 wall tubing", so it's bigger than what you got, now. I do agree with Matt, though, that your 60' is getting into territory for a piece like the TRZ. But if that's out of reach, I think the Stainjanger one is comparable to the other brands' similar designs, and it's $50 cheaper.
Old 11-04-2014, 01:53 PM
  #58
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Agree with all of the above....Those 60' numbers call for a dedicated all oit drag piece. However if you want to send me your driveline I would be more than happy to test it out and give some feedback!
Old 11-04-2014, 02:01 PM
  #59
mw66nova's Avatar
Engine: 7.0L
tom's engine is held in with dzus fasteners, so i'd bet that wouldn't be a hard task. i bet he could have engine/transmission out quicker than you could pull your antiroll bar off
Old 11-04-2014, 02:16 PM
  #60
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Lol no joke, i dont know anyone faster at removing and tearing down engines lol. I've gotten real good at transmissions
Old 11-04-2014, 04:22 PM
  #61
87_TA's Avatar
You guys are funny.. I am not that fast, LS's are just kind of easy - For instance I never have to remove spark plugs to get heads off, and not needing to adjust valves really speeds up the process. Getting my intake off is a total Bitch though.
Well my comp is pretty much a dedicated part, but just feel it only being 1" hurts it. That TMZ or whatever it was looks stout - Not sure I want to drop that coin either - But also dont want to remove stock fuel tank for a BMR double set up. Anybody know anyone running that TMZ bar?
Old 11-04-2014, 06:15 PM
  #62
DIGGLER's Avatar
check into the quarter max stuff... btw i must have missed your car running mid 8's... when did that happen?? pass looked great!
http://www.rjracecars.com/Anti*Roll-Bars-Prodlist.html
Old 11-04-2014, 08:46 PM
  #63
87_TA's Avatar
I will check that out! Thank you BTW, it had gone 8.8 beginning of season, few months ago went 8.7s, then I added boost controller, Radials and 3.08 gear and completely changed car. Mostly boost controller really made it spool much quicker. Best to date was 8.34 @ 165, think she has a little more left
Old 11-09-2014, 12:04 PM
  #64
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
https://www.thirdgen.org/forums/powe...harged-f2.html
Check out ogies ta! He has the trz bar and runs high 7's at almost 180
Old 11-10-2014, 09:18 PM
  #65
87_TA's Avatar
Wow, that car sounds meaty!
Old 11-10-2014, 10:55 PM
  #66
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I like my trz setup that was recently added.
Old 11-11-2014, 05:51 AM
  #67
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
But you are slow show car lol
Old 11-11-2014, 06:45 AM
  #68
mw66nova's Avatar
Engine: 7.0L
does it leave straight on the stevestands?
Old 05-06-2016, 01:09 PM
  #69
FirstBird's Avatar
Car: 88 Firebird GTA
Engine: 385
Transmission: manual 350 Turbo
Axle/Gears: 4.30 9 inch
First, thnx to all the regular contributors to this forum. I've used the search feature for the archives for years, which led me to this post.
Calling ahead to Steinjager, they could not confirm that their drag bar would fit a Moser 9 inch but offered to take it back if it did not. There is interference between the bar and the upper thru bolt for the torque arm adapter. Using the Spohn axle brackets I had used to mount the stock sway bar positioned the bar correctly further from the axle, but left the links too short to work. Steinjager expressed out longer lengths of threaded rod as I chose to try to make it work, and it did.
Sent detailed pics and measurements to Steinjager. If you want to try their product on a Moser piece, call ahead to see if they made changes.
Old 05-06-2016, 01:27 PM
  #70
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Since this thread i have been 1.28 on stock 24 mm rear sway and 36mm front still connected lol
It twisted abit but worked lol
I want a drag sway tho
Old 05-10-2016, 08:23 PM
  #71
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
For anyone wondering....I am no longer with the company, but I am still running the bar and hoping to put some mid to low 1.4's on the time slip.
Right now I think Ricky is hitting that bar pretty hard, and I haven't heard about it turning into a pretzel.......yet....lol
Old 05-31-2016, 09:02 AM
  #72
no green's Avatar
Still fine, no pretzel, even with a few road race style antics on the return road...
Good Luck with the new venture.
Old 05-31-2016, 09:10 AM
  #73
no green's Avatar
Turbo Firebird goes 8.39, 164 at Pittsburgh Raceway Park - YouTube
We were just at PRP this past saturday, we're returning Jun 25, with the Renegade Racing index series. Check it out, I think your cars would be a good fit. http://www.renegaderacingassociation.com/
Old 05-31-2016, 09:13 AM
  #74
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats pretty interesting but i have no running car at the moment
Old 05-31-2016, 09:14 AM
  #75
no green's Avatar
It is a month away
Old 05-31-2016, 09:38 AM
  #76
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
As in i dont have a car that will be running within a years time
Old 05-31-2016, 11:58 AM
  #77
mw66nova's Avatar
Engine: 7.0L
i believe i'll be making the trip up to thompson the first weekend in august, still undecided what class i'll be running.
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
9192camaro
16
02-03-2019 12:21 AM
1nastygta
10-28-2015 08:51 PM
z28addict8490
08-07-2015 08:48 PM
Quick Reply: rear sway bar for 1.40 & quicker cars
