New best
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
New best
ok pretty pleased with my last weekend ran a 12.56@107.5 with a 1.74 60' getting it dialed in. I'm happy for my first trip to the track in at least 5years.
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
Re: New best
91 Formula 8.5:1 383, AFR 195's, Holley stealth ram, hooker 1 3/4 long tubes, and a megasquirt. It is quit the under achiever, wish I would have built it 11:1 instead but I'm trying to see if I can get it into the 11's with this setup. I'm also running tubular front a arms and cross member as well as qa1 single adjustable front struts and Viking rears with a 9" and 3.90's and a fresh 700r4 with a 3500 local built stall. I'm running the Rocky Mountain Race Week in two weeks
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
Re: New best
PA racing tubular parts and the struts are good I've only got about 80miles on them and 6 passes so I'm still figuring them out. but they seem to work well.
as far as cam specs go it's an old cc306 duration is 290in 307exh 230 244 @.050 .544 .577 lift 112lsa not ideal for my compression.
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
Re: New best
New best again Ran an 11.75 in great bend last Wednesday during Rocky Mountain Race Week.
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
Re: New best
the da for the 12.5 was 3550 here in Phoenix, the 11.75 was with 100hp nitrous at great bend KS not sure what the DA was. I was using nitrous that week for the race to keep it in the 12's at 5 different tracks ranging in elevation from 5800-1900 and I left the bigger kit in to finally get an 11 second pass. I averaged a 12.41 for the week (second in class) which I consider good since I turned in a 13.08 the first day After crossing 2 plug wires on a plug change. Once I found the problem the lanes were closed. It was an Amazing week of racing. and the car weighs 3470 with me in it.
