Need some advice 1/8th mile times
First off I am still new to actually racing my car only 3rd time down the track and looking for any tips to better my times. I have a 87 Iroc L98 stock minus a cat back exhaust. I have replaced most of the ignition system; Accel cap, rotor, & ignition control module. MSD ignition coil and wires. Ac-Delco plugs Nothing special, but runs good.
So far my best time is 9.55 at 71.68 with a 60' of 2.172
9.6 at 72 mph is my best mph.
I'm not looking for a racecar just a semi-fast car. I would like to run low 9's if possible like 9.4 or better. Am I asking for to much or is this possible with current setup.
Thanks for any help
Thanks for any help
1 Post
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Re: Need some advice 1/8th mile times
Thanks for any help
Thanks for any help
converter is more important than any of the other. it will have the biggest return on the dollar. gearing will too.
i need more information to tell you if your ET is in line. i'd like a full time slip and all weather conditions, as well as track location. at first glance, a 9.6 converts to ~14.98 1/4 mile, which is slow for an l98 car in my experience, but want to know all variables to be able to form a proper opinion.
Bringing this back, I finally had a decent trip to the track. Same setup as mentioned above just better driving this time. Here is the best slip from trip out.
2.1267 60'
6.0965 330'
9.4076 1/8th
73.43 mph
Some extra info from that night
-134 DA(ft)
100.39 Relative Density (%)
This was leaving it in second gear instead of drive.
2.1267 60'
6.0965 330'
9.4076 1/8th
73.43 mph
-134 DA(ft)
Car: 89 Firebird
Engine: 355 TBI
Almost exactly what my stock 91 z28 LB9 Auto with 2.73 gears ran. It was stock except for smog delete, aftermarket chip, and 3in exhaust
Car: 92 camaro
Engine: 383
Transmission: Th350
Axle/Gears: 9" 31 spline moser 4.11 gear
I have these wheels I'm selling. Mickey Thompson tires 0 miles on them. Take
$1100. 42001 zip code
mjb198421
04-04-2016 03:46 AM
