Pacific Northwest Region Regional discussion board for WA, OR, ID, and BC.
Camaro stuck in Central WA
Old 12-02-2014, 04:14 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
At the end of summer, my 91 Camaro and I were headed back to the west side of Washington from Spokane, when the unthinkable happened. The 305 finally gave its last breath, and proceeded to sieze up and dump oil 200 miles from home. I was being deployed to Asia with the Army (Fort Lewis) just 2 short weeks later, and due to lack of funds, had to flatbed her to a local storage unit in Moses Lake. I returned from said deployment just a few weeks ago, and want to get my car up and running. The issue? Its 200 miles from home, 100 miles from Spokane. I talked to Moses Lake Chevy dealers, but they were quoting $7000+ for a low output engine installed. Found a place in spokane for much cheaper, just needing to find a way to get it over there. I have family in spokane to drop her at, but 100+ miles on a flatbed would cost a pretty penny. Any ideas or experiences fellow PNW owners?
Old 12-02-2014, 04:27 PM
Car: 1991 Camaro RS
Engine: 5.0 L03
Re: Camaro stuck in Central WA
Scrapping is not an option to me, as I have rebuilt most of the car mechanically. Fully rebuilt wc t5, rebuilt rear with 3.42 and torsen posi from a 97 ws6, new springs, various suspension parts. Engine was pretty much the last mechanical part to tackle, just didnt get to it in time.
Old 12-03-2014, 08:50 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
sign up for AAA, unlimited miles or whatever, then when u get the card call em up & have your car towed???
Old 12-03-2014, 11:55 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Just an option....Do you have a friend with a truck? If so, go to U-Haul, rent car trailer, go get it and bring it home (your home), and return the trailer.
Might be cheapest....gas and rental money
Old 12-03-2014, 12:38 PM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
you can rent the trailer AND the truck from U-Haul or one of the others. not an expensive option considering the $7000 alternative.
Old 12-04-2014, 09:41 AM
luckydog0_18's Avatar
Car: 1986 camaro iroc-z28
yep I agree truck and car hauler from u-haul. really the only way to go in order to save money.... and to have it done quick
Old 12-15-2014, 12:58 AM
Car: 1991 Camaro RS
Engine: 5.0 L03
The only thing im figuring out is how to get the camaro onto a uhaul with just me and one other person. If only they had winches.
Old 12-15-2014, 07:36 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Pick a 2-3 ton cable hand winch from Harbor freight. We winched a 5500lb full size Chevy Van onto a -Haul trailer with ease.
Old 12-15-2014, 07:44 AM
Exactly what Bob88GTA said
Old 12-15-2014, 08:43 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
If you were on this side of the country I'd go get it for you - PM me your contact info and I'll post this on a couple of other boards - I bet we can get it picked up for you.
BTW, thank you for your service and best of luck with it.
Old 12-16-2014, 01:37 PM
11ellswray's Avatar
Car: 1986 Camaro, 2004 9c1 impala
Engine: TPI 350, previous owner hackjob
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
We rolled my friends 80 camaro onto the uhaul trailer, it was his girl inside steering and then three pushing. just a slight hill and some manpower can move quite a bit.
Old 12-17-2014, 02:47 AM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
If you dolly it, with the back tires on the ground, disconnect the driveshaft, dont want anything else going wrong possibly, or you can put the front down, but thats funny looking..
Old 03-17-2015, 03:02 PM
Myorangecamaro's Avatar
I run between Seattle and Spokane a lot with an empty flatbed
BADNBLK
11-16-2016 09:12 AM
thefirebirdm@n
South Central Region
09-14-2015 01:45 PM
backtothe80s
09-05-2015 12:39 AM
bbernardo94
08-19-2015 05:25 AM
Quick Reply: Camaro stuck in Central WA
