TPI intake manifold toque sequence
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
anyone know the torque sequence for installing a sbc lower intake manifold for my superam? also, no RTV on the gaskets right? For some reason I thought you should put a dab around the water ports. thanks.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I put rtv around the ports and at the corners where the block, heads, and intake all meet. You can put it on dry, it'll save you about 45 seconds. But pulling the SR and re-doing it will take a little longer.
It's up to you. I don't know for sure about the tq sequence, but I just start from the inside and work my way out.
ambainb
04-25-2016 09:21 PM
86IROC112
08-17-2015 02:00 PM
