o-ring the block...
Old 07-12-2006, 11:42 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
o-ring the block...
At what point do you need to machine the block for o-rings? Is the there certain amount of boost? Or how much is it dependent on HP/TQ? Whats the deal?
Old 07-14-2006, 01:39 PM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Cylinder pressure is what it comes down to. You can run big boost w/ a low compression piston and not need to o-ring the block. Be gentle w/ the timing advance, watch your intake temperatures, and don't get lean. I wouldn't start to think about it until past 650 rwhp in any case, since head gaskets could be a safety valve instead of breaking pistons w/ detonation.
Old 07-15-2006, 06:19 PM
MYBLUZ's Avatar
Engine: Blown 383
I'm going to run 8.2:1 forged JE's so I should be alright. Procharger says it could be 1000 plus easy(not at the wheels) and the bottom end will take up to 1400hp.
Old 07-17-2006, 01:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
uhh yea, i'd get it cut for o-rings and use head studs for sure. A very good quality head gasket as well, cometic or such.
Old 07-17-2006, 06:04 PM
roarin_mouse's Avatar
Car: Z-28
Engine: 383 stroker
I hope that you've got a strong lower end too. 4340 rods and crank, for sure. 1100 is a lot of ponies for a regular block. If you go past 650, I'd definitely recommend a Dart block or something like it. Even the old high nickel GMs would be limited to around 700. Anyway, since you didn't say anything about the bottom end, I thought I'd put my two cents in.
Roarin_Mouse
Old 07-18-2006, 12:30 PM
83 Crossfire TA's Avatar
Huh…
Usually you only run lockwire/o-rings grooves with copper gaskets and gaskets like the fel pros that are designed to be used with a receiver groove. As far as I know they are totally inappropriate for something like the cometec or felpro MLS design.
The second question is do you want to cut the head, block or both? I’ve always heard that head or block doesn’t matter as far as function, but of course, you can cut the heads any time, even with the engine in the car, but the disadvantage is that they need to be recut if you deck the head, and now suddenly there are builders turning up with setups that have both cut (for example, nelson racing engines cuts one, puts the ring in it, bolts it down and uses the impression as a pattern to cut the other).
Old 07-18-2006, 02:22 PM
BlownBird's Avatar
I run 9.6-1 compression, and 21# of boost. I had the Felpro lockwires on my old heads, with no problems, now I am running Felpro MLS gaskets with no complaints. I would recomend running Cometic or MLS and not cut the block or heads. DonB.
Old 07-18-2006, 03:08 PM
I’m curious Don, did you have any issues with your installation with the felpro MLS gaskets?
We used a few of the earlier ones and ran into all sorts of small issues. The 2 that I remember is that they didn’t have the cutout for a driver’s side dipstick tube and that some of the rivets were located in a location that they got caught between the head and the block which we were wondering if it would either keep the gasket from properly compressing or brinelling the aluminum heads in that spot.
The reason that I’ve played with copper + o-rings is that it seems to me that a good 85% of what I get near seems to have the pistons deep enough in the hole that we’re looking for <.035” thick gaskets all the time and the copper ones are easily available down to the .02x” range. I haven’t seen any MLS gaskets thinner then .038”. I keep hearing the rumor that they can be had that way but I can’t seem to find any, I know felpro won’t do it, I’ve asked them.
Old 07-18-2006, 11:00 PM
MYBLUZ's Avatar
Engine: Blown 383
I guess I should have mentioned the forged 4340 Scat assembly. And definatly running studs through out. Good info, thanks.
Old 07-19-2006, 03:25 PM
BlownBird's Avatar
I have had no such problems with the Felpro MLS gaskets.
I can add that I ran standard felpro gaskets, and would blow them every second or third pass, put the MLS's in and have made 15 passes without issues.
DonB.
Old 07-19-2006, 07:04 PM
MYBLUZ's Avatar
Engine: Blown 383
How much boost are you running Blownbird? I was looking at Fel-pro's website, I didnt see MLS gaskets. Is it a new Item? Where did you get yours? Thanks
Old 07-20-2006, 01:51 AM
Hum… Don, how long ago did you do them? Like I said, the sets that I had experience with were probably the first few they made and I suspect based on our issues with them they would have redesigned them if they had any sense. Do you remember what thickness the ones that you used were?
Old 07-22-2006, 12:13 AM
dildo baggins's Avatar
I just blew a $180 Fel Pro on my DSM. 25 PSI on a 50 trim turbo, pissed me off fo shossss.
Old 07-25-2006, 11:41 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
im planning on getting near 30psi, and i have the sce multi layer copper gaskets.......no o-ring for me........preston smith has run them as well in his world famous turbo iroc lol.....he actually persuaded me to try them
hes making around 950HP and he hasn't had any probelms with them at all........he also didnt have any trouble with his stock block until around 900hp.......i saw that someone commented on that......850 should be fine with a decent factory block.
if you're not sure when and where an o-ring application is needed though, you might want to reconsider building an engine like that and do alot more research and questing for understanding first.
Old 07-26-2006, 01:59 PM
Hum (confused)
SCE has a number of different styles of gaskets that partially match your description there. They have their copper Titan gaskets, ICS Titans and I believe they have an MLS gasket. I believe that you’re talking about one of the 2 titans… the normal titan is just a copper gasket with printed on sealing beads so that you don’t have to use other compounds to seal the coolant passages, as far as I know, these are supposed to be used with an O-ring in a cut receiver groove (though I have heard rumors that they work without the ring. The ICS titans are the same with a steel o-ring between the top and bottom copper layer that compresses into the copper layers and does not use a groove cut in the head or block… Which one are you using?
Old 07-26-2006, 02:40 PM
Car: '91 Camaro RS
Originally Posted by 83 Crossfire TA
Hum (confused)
i'm sorry.......they are the titan self sealing copper gaskets, they have seals bonded to the fluid passages on both sides, not the MLS ones......i was half asleep when i typed that last night apparently, i dont know where the hell i got that from lol
heres the gaskets on summits site.....
SCE Titan Copper Self Sealing Head Gaskets: SCE-T11064 - summitracing.com
they don't require any machine work or lock wires either.
Old 07-27-2006, 07:05 PM
MYBLUZ's Avatar
Engine: Blown 383
Old 07-27-2006, 07:10 PM
MYBLUZ's Avatar
Engine: Blown 383
If I'm not sure if I should O-ring it or not I should do more research? What do you call this thread? Research perhaps?
Old 07-27-2006, 08:39 PM
Car: '91 Camaro RS
you really don't need to, the newer gaskets like the SCE ones im using are getting so good now that needing to do so is even further away than it used to be.
i know several people using these gaskets with no problems....making around 900hp
Old 07-28-2006, 08:47 AM
BlownBird's Avatar
I am making 1300+ horsepower with the Felpro MLS gaskets. It would be crazy to think you would need to cut the block or heads to get a good seal!
Old 07-28-2006, 03:13 PM
Car: '91 Camaro RS
well played sir lol
Old 07-28-2006, 07:24 PM
MYBLUZ's Avatar
Engine: Blown 383
Cant seem to find a good enough machine shop around me that even knows about o-ringing. So I guess its good that I wouldnt need it for the boost I'll be runing. Blown bird what block did you use? And how much boost does it take to make that 1300?
Old 07-28-2006, 09:15 PM
BlownBird's Avatar
I am using a Dart little-m and am running 20-21# of boost.
Old 07-28-2006, 11:53 PM
Car: '91 Camaro RS
gas or alcohol? and what are you using for a cam?
im going to max out the f1-R and see what happens lol
gixxer92
05-18-2017 11:20 AM
BOOT77
09-16-2015 08:37 PM
BOOT77
09-05-2015 03:55 PM
bamaboy0323
09-03-2015 06:07 AM
RED85TPI
Brakes
08-31-2015 10:29 AM
Quick Reply: o-ring the block...
