Twin Turbo 400 Buildup- '89 Iroc-Z
#153
Re: Twin Turbo 400 Buildup- '89 Iroc-Z
Thanks, it turned out pretty good. I"m happy with it. Once i get a 4" v-band clamp, I can finish the last bits and pieces and set it on the ground to see how much clearance i have. SHould have more than last year and last year I had very little so any bit gained is a win for me
#154
Car: 2014 2SS/RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.55
haha not sure if i'll ever sell the setup but I do have a single turbo manifold i'm trying to unload.
LSx motors seem to be different when it comes to boost. They seem to make more power than sbc's with similar setups. If i can reach 850whp with 18 lbs or so I'd be extremely happy
#155
Its a BBS Designs one but it dont fit A/C or serpetine belt setups...atleast not the factory style one. I tried to fit it and it wont clear the AC or AC delete pulley
I had it on ebay and it didnt sell either. I'll take any reasonable offers for it at this point
#156
Engine: 5.7
How do you plan do doing the twin walboro in tank pumps? I don't think they have a kit for thirdgens.
#157
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I connverted the top of my tank so they are -6an.
NOTE I DIDNT USE ZIP TIES, I USED 2.5INCH STEEL CLAMPS OR SOMETHING.
Jay
#158
Engine: 5.7
Which pump did you use I was looking at the GSS340 or GSS340M from Racetronix?
#160
The cylinder head design is much different..there are a number of things but agreed the head design has a lot to do with it. I have never not made under 550 rwhp on any of my LSx setups...and on a 97 LS1 made 430/400 with just H&C, pully, LS6 intake, and headers.
People are lucky to get 350 rear hp/tq out of a 350 SBC with the same mods. I have been trying to decided whether to go H&C on my bird or go FI....I am leaning towards the FI side but it seems that kits are very limited for these cars.
I love the TT stuff, but the kit that has looked the best to me so far that fits under the stock hood and retains most of the stock components was/is the Twin IC ATI Supercharger kit...but it looks like the Twin IC idea was scrapped.
I could invision a Single Turbo setup...I had to have a mold made for my Twin Turbo on my C5...all of a sudden I am the owner of a hood mold...luckily people buy them and one day I may actually make back the money I spent of have the mold fabricated. I would rather not do that again...so for the bird...I would like something that fits under the stock hood...or the ram air hood.
Orr's TT build is fantastic too watch and I'm impressed that he is doing it himself (I can't weld). I had to draw up the design for my kit and send it to the fabricator along with the car...I have similiar build pics in my sig.
It will be nice too see how it perform after the final tune and track test n tune.
#161
Doesnt mean u cant do it...I fit twin 255s in my stock tank. It is a pain tho. It took me 4 trys to get them to go it. The filters make it hard to fit.
Jay
Jay
#162
Car: 1987 Z28
Been using them for about 500mile now no issues, my buddy had one on his car for the last 2 years also.
Jay
Jay
#163
I havent updated this in a while and made some progress since last post but no pics really. Wont get a chance to work on it this weekend but within 2 more weekends i should have this thing running.
I'm impressed with myself too haha since i knew very little about turbocharging 2 months or so before starting this build. I've learned a ton in a short time but i got an engineering background so i pick up quickly i guess. I can tack weld and weld exhaust pipes somewhat ok, but for the manifolds and cold side piping, i had my buddy tig/mig that stuff since he's better than me by a long shot and i dont have tig welder. My welds arent always pretty as i'm still learning haha. But what i have done so far I am pretty impressed. I have an idea to improve the setup but will not pursue due to time/money etc. I want to move the turbos to a different location and lower to keep them under stock hoods.
The fuel system is almost done and i was gonna get ready to post alot of pics and info about it. I may get some up tonight but i'm running Lonnies Performance twin walbro in-tank setup for 4th gen LS1 tank, as I'm running a 4th gen LS1 tank now. Thirdgen tank has smaller inlet opening so you have to fish the pumps inside and i guess assemble in tank. MAJOR PITA, so i picked up a LS1 tank for 50 bucks and have the below setup.
Dual pumps sit in the factory bucket and Y into the supply line. Push style connectors on the plastic outlets into a -8 an supply line and -6 return. Fuel Lab filter and regulator. Racetronix wiring harness for this setup with Hobbs boost switch to activate the other pump. Special fuel level sender for 0-90 ohm stock style gauges. Bolts right in so far.
#164
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
when u get it running could you let me know if you get the smaller 5/16 flanges on the hookers to seal. i never could get a seal on a na motor really wondering about a turbo setup.
my turbo setup uses 3/8 thick ss flanges and will somtimes leak but im runnin silicone and no gasket.
#165
These are advertised at 3/8". Would have been cheaper just to get laser cut THICK flanges and start welding pipes to it, but these had stubouts already welded on.
I hope these seal, they got a good flat surface and I'll be using silicone and a copper gasket
#166
Engine: 5.7
Push style connectors on the plastic outlets and Fuel Lab filter and regulator
Do you have part numbers on these? i'm in the process of doing the same thing.
#167
Justin, looks amazing dude. This car is going to be a rocket ship! If your still looking for a hood, I have a 4" harwood show series hood I'm trying to get rid of. I'm going back to stock to make my car a sleeper. It's in perfect shape.
#168
I actually picked up a hood for this thing...4" harwood that a local guy had. Seems to fit ok, just needs some cuts/trims
Do not have part numbers for these. I got the whole kit from Lonnies Performance, not sure what the fittings are but I believe summit has them. Just dont know the partnumber.
Pure Choice Motorsports has them i do believe.
http://www.purechoicemotorsports.com...rod/prd181.htm
http://www.purechoicemotorsports.com...rod/prd310.htm
Something like that will work. Or call Lonnies Performance to see if he can ship you some
#173
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I'm looking forward to hearing your opinion on the power delivery. My blower added a lot of power but made the car pull smoother. With an auto trans its just not as fun as I thought it would be. The initial launch is amazing though. The car pulls like a jet, just doesn't have that kick in the ***. I've been debating either switching to a turbo to get maybe a more spikey powerband or going with a stick...
#174
This upcoming week and weekend I should have the car pretty much complete. My fuel lines are pretty much done, just need to run the wiring harness for the pumps. Got an electric water pump to put on, so all I need now is an alternator bracket and modify factory powersteering bracket. Should fit ok.
Got to repin the ecm and it should be ready to go. I mean there are some little things to do to make it complete but so far all major stuff is done. Rest shouldn't be too hard to do, atleast I dont think. Last major item i need is a driveshaft.
I just bought a 99 Trans Am for my daily driver since it was at a price i just could not pass up. I just felt like driving it this weekend and not working on the camaro haha. Big car show here Aug 7 so I want to have the camaro somewhat driveable by then. It could happen if I really put in the time this week and weekend.
#175
#178
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
damn, how the hell did i miss this thread! looks awesome orr.
#179
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
looks like your new setup is going to be insane! good luck with it
#180
As far as the cam, I believe i posted it somewhere here. Grind is a custom hyd. roller from Mike Jones Cams. Its a 292/292 advertised 233/233 at .050 with .564 lift on a 112 LSA. I wanted it to peak in the 5800-6000 range and I do hope it does so i can shift 6200 ish. With my tire size and gear I will eventually run, it should be good to 145-150 mph in the 1/4 which is kinda where I want to be on high boost/race gas mix
#181
Engine: 5.7
The cam grind I got is a lot smaller that yours. It's almost a peanut came with high lift. : )
#183
With my car being a stalled automatic, I dont think its gonna have a kick in the *** type pull. Not like the nitrous 383 last year, that thing was fun but filling up bottles got annoying and pricey. I hope this car does deliver instant boost and hooks up well. It should be a very fun car to drive, but the power band will be smooth. If the turbos were bigger and took longer to spool, you would fill that huge rush of power come on as the turbos started to spool up. With these smaller turbos, it should kick on pretty darn quick and deliver loads of power quickly, but smoothly. Smooth pull I think is because of the broad flat torque curve it will make and a nice steady climb in hp. Its not going to be a spikey curve I dont think.
#184
Engine: 5.7
Mine is a 215/222 114 .540/.532 w/ 1.6
It's smaller than my NA cam was and it wasn't all that big.
#186
1 Post
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
He must be out driving it.. Hasnt updated in forever! I need some video or pics!
#187
Car: 1988 Firebird Formula 350
Axle/Gears: BW 3.27
I think he's just been spending every possible minute trying to get it up and running before the snow flies.
#188
yeah sorry for no updates as alot has been done since then. It will be downright scary haha and I hope it is. I need the thrills.
Car is in final assembly mode and I'm having a few problems getting all the flanges lining up perfect as for some reason, its not lining up in final assembly as compared to mockup, so minor setbacks. Soon as I get these downpipes connected, I can hook up the rest of the exhaust and then engine accessories and it will be ready to fire.
ECM harness is rewired to 730 pinouts, and I have the driveshaft finally which was the last part. I cant wait, but soon as its together I'll get good updated pics of everything from fuel system to air filters
#189
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Nice man, I can't wait!
#190
Awaiting brackets again... ordered march kit to go with CSR waterpump. HOpe it fits.
Heres quick tease of somewhat final assembly. ABit messy with the lines and such but i just need it running for now. At some point i'll clean it up with AN lines for the vacuum stuff or just rerun everything to clean it up.
THought about making a fuel rail cover and/or dizzy/top end motor cover
#193
Fuel filter mount in stock location. Fuel Lab filter with -8an feed lines
Fuel lines come in from back driver side and return same location. Fuel Lab regulator, boost referenced.
3-bar MSD Map sensor
March bracket and pulley kit for electric waterpumps. Uses stock thirdgen alternator and power steering pump. CSR electric water pump.
#194
Summit radiator overflow catch can mounted below battery box area
Vacuum line runs and shot of the oil feed assembly for the turbos. Ordered abit shorter 4an line than i needed so i used fittings to make up the distance. Worked out great.
Moroso vented breather can for valve cover venting. No pcv on this car anymore
#195
so nice!
#196
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I Like that water pump man... and i see your still have an inch of room over there in that cornner!
#200
Nice Bro, I'll be starting on my project next weekend.
