rear mounted turbo on carb setup?Many questions
Old 01-31-2012, 08:59 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
Well i have a friend thats big on turbos, hes got a 300zx tt and is addicted to boost. Hes also got a 2000 mitsubishi eclipse that hes planning on doing a rear mounted turbo set up on.
So im wondering if the same would be possible to do on my wimpy carbed LG4 305? Im gonna be swaping it soon so i dont care much for it.(figured it would make a good experiment)
I understand the concept of a rear mounted turbo but how would the fuel delivery part of it work with a carb? would i have to enrichen the carb mixture to keep up with the turbo? bigger jets?
would a regular holley 4160 work or would i need a "blow thru" carb?
what would be an adequate turbo size for a rear mounted set up on a 305/350 engine?
We would be doing this on a budget,strictly as an experiment.
Any info is appreciated.
Old 01-31-2012, 09:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: rear mounted turbo on carb setup?Many questions
Still need a blow thru carb or modify the one you have. I dont know anything about carbs but a good blow through carb is fairly expensive ~600-900 bucks from what I seen. But its worth it as a good carb makes for the best driveability.
I've been planning a remote mount on my 99 TA as of late since i love my other turbo car. I'd use something in the 60-70 mm range depending on the hp level. I'd probably try a small a/r T4 housing for the turbine side, P trim wheel in the 62-64mm range. For a mild 305, figure pushing 350-400whp is all you will ever want to try to get out of it, a single 61-64mm would just about do the trick. I myself plan on a T67 for my LS1 car looking for 450-500whp.
Old 01-31-2012, 10:57 AM
Street Lethal's Avatar
Originally Posted by J0hn_J0hn08
So im wondering if the same would be possible to do on my wimpy carbed LG4 305? Im gonna be swaping it soon so i dont care much for it.(figured it would make a good experiment)...
Why rear mount? Go with a front mount, much easier to do. As for the carb, if you go with a carb enclosure box you won't need to modify it for blow thru... you would just need a decent fuel pump, boost referenced fuel pressure regulator, then tune your fueling in the carb (get a wideband to monitor your air/fuel ratio). Get your hands on a carb enclosure box like this one, then just fab up some turbo headers...
Old 01-31-2012, 06:34 PM
one92rs's Avatar
Car: SOLD!!!!!
http://ststurbo.com/
i have seen these and ridden in cars with them and they work great.
Old 02-22-2012, 09:53 PM
Kurtis2short's Avatar
What kinda oil delivery system could u use I plan on doing the same but with 78 mm turbo and mount it in the back like a sts set up I was thinking about using a dry sump oil tank instead of tapping my oil pan and using a sts oil feed system unless somebody knows of one cheaper I live to hear about cause they're around 800 bucks and as far as a fuel pump can u use a manual fuel pump or would I have to use a electric
Frozer!!!
01-19-2024 04:55 PM
customblackbird
08-15-2021 10:16 PM
Terrell351
06-13-2021 01:13 PM
pimp2303
07-27-2017 02:03 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: rear mounted turbo on carb setup?Many questions
