Oil restrictor plate help
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I made a run up to summit today to look for two oil restriction plates but apparently summit doesnt carry them. I was wondering if someone could point me in the right direction or give me a link for one. I just got the motor fired up and it runs around 60-70 psi of oil pressure and i dont believe that it would be a good thing to run that through my turbos Ebay or not. Thanks again guys!
Re: Oil restrictor plate help
60-70 psi at redline once its warmed up or only when cold?
are u using -3 or -4 feedlines
also what ebay turbos do u have
if ur using -3 lines u more then likley wont need restictors
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
It was warmed up it ran around 60 the feed lines are 4 an i believe.
The turbos were the t3/t4 hybrids 57 mm i think?
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Also at WoT id say i would be closer to the 80s. I just want to make sure i dont blow my seals
race parts soulutions
http://www.racepartsolutions.com/pro...-OilRestrictor
be sure to order the .67's
anychance u have apicture of the turbos u bought
some ppl list them as 57mm and they are more like 48-52mm
and then others have the real 57mm units
Hotrodboba400
12-10-2019 07:07 PM
Kenwood
09-04-2015 05:50 PM
