triple walbro 255s in a stock (modified) tank
Old 12-03-2012, 08:46 AM
turbo iroc's Avatar
Car: 89 iroc single turbo
Engine: 383sbc 76mm turbo 402ci ls 88mm (in
Transmission: tko500
Axle/Gears: 8.5 10 bolt 4.10 gear 28 spline axl
Wasn't sure where to post this so i figured id put it here in power adder because the car is turbocharged. I'll be running one pump normally and the other two will be activated via hobbs switch. Should be enough fuel for 1500 hp
Old 12-03-2012, 08:47 AM
turbo iroc's Avatar
Re: triple walbro 255s in a stock (modified) tank
Old 12-03-2012, 08:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Interesting. Why cut side of tank to mount them rather than use the stock hole but modify that? Could likely have just sumped the tank if you had to cut it.
Whats the setup going to be? I believe mightymouse on ls1tech pushed 1300hp with triple walbros. Should beable to do 1500 if pressures are kept low
Old 12-03-2012, 09:51 AM
turbo iroc's Avatar
Hey man how've you been? How's the car? Ive talked to you before ob other sites lol
Sumping the tank doesn't work to well the location if the muffler. We thought about goung through the factory tank but this way will allow us to keep the factory float/sending unit in tact, plus the factory sump is in the back where we cut the hole. Shiuld be enough fuel for 1500fwhp. The engine/turbo setup is a 402ci forged lq9 with l92 heads 9.3cr t6 pt88turbo 1.08a/r custom 1 3/4 headers 2.5" merge pipe and 4" downpipe. Its blow thru carb for now but fi is in the near future. Id like to see 800rwhp
Old 12-03-2012, 11:39 AM
project89's Avatar
nice job , tripple pumps will fit without modifying the tank but its a major pain in the ****.
i did tripple 190lph pumps in mine u have to mount 2 then drop it in the tank then mount the 3rd witht he sending unit halfway in the tank. royalpain in the **** but its doable
and i know ur going to ask why 3x 190lph pumps , it was a temporary fix till i got 2 new areomotive 340lph pumps , i only paid 12 bucks each for brand new 190's
Old 12-03-2012, 12:12 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
looks good ...
Old 12-03-2012, 12:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ah i remember talking about that setup now. It should do it. 88mm will be pushed hard but it could get there.
My setup has had problems this year so i gotta freshen up the shortblock and heads and reassemble. Probably switching efi systems too. Redoing trans converter may add t-brake, etc. long winter lol
Old 12-03-2012, 03:28 PM
turbo iroc's Avatar
@ project89. I actually didn't think of that haha. We did it this way so we could just do everything to this tank then just swap them. Also my original tank had a sump in it that gave me alot of problems ( kind of a hack job) 190s for 12$ is awesome! My previous setup was an a1000 but it was about 8 years old and wasn't flowing what it should. With this setup i probably won't ever have to mess with fuel pumps ever again!
@orr the 88mm flows 120lbs per min so 800 whp shouldn't be a problem. Similar setups on ls1tech teach my goal at around 15-17 psi.
Old 12-03-2012, 04:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No not at all at 800hp, 88 with good wheel should easily do 1000+ just dont know if it will push 1500 hp. I believe the x275 rated 88's with the best billet compressor wheels can do 1500 hp. Your fuel system is overkill for 800 whp
Old 12-03-2012, 04:08 PM
turbo iroc's Avatar
Yea it is overkill, but here's my logic. 2 255s is good for about 1000 fwhp so at 800whp im right on the edge. So 3 it is plus ill be going e85 in the future
Old 12-03-2012, 04:28 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
you could of just ran two aeromotive 340lph pumps and you would of been set for 1300hp, i am running two 255lph pumps and it is good for 1100hp.
Old 12-03-2012, 04:37 PM
turbo iroc's Avatar
How much do the aeromotive 340 cost? I paid 70$ each for the 255s. I thought it was cheap considering the aeromotive eliminator i wanted to buy was close to 500.
Old 12-03-2012, 05:45 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Very nice looking setup.Should be a screamer ! I like it !!
Great Fab work on the tank / pumps. Are you going to trap door the rear hump to access that fuel tank also?
Old 12-03-2012, 06:05 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
the aeromotive pumps are 150 each. That is pretty cool setup that you made, guess if you have a ton of power later on you can always run 3 aeromotive pumps and you will be good be for 1800+hp.
Old 12-04-2012, 06:01 AM
turbo iroc's Avatar
Thanks for the compliments , my brother Manny is behind all the fab work this car. He's got skills for sure! We thought about putting a trap door in but i probably won't. Assuming everything works the way it should, i shouldn't have to upgrade pumps anytime soon.
Old 12-04-2012, 06:04 AM
turbo iroc's Avatar
@orr
Ls swap time! ?
Old 12-04-2012, 07:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Naw but i may go ls computer to run my setup since my buddy is a great latemodel tuner. He tuned my 99 trans am and '10 sierra truck with the 6.2l. 411 ecm the older ls cars had offers great tuning features with hp tuners software.
Old 12-04-2012, 12:55 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ditching $59 too huu?
I've collected parts for going 411 pcm but 4x with single coil and distributor in my lt1.
I just need a vortec distributor
or convert my msd one over for cam signal only.
Old 12-04-2012, 02:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I dont want to do it but the chip burning issues i had this year and a wiring glitch in my conversion harness have frustrated me alot and now that the motor has to come out might as well do the swap. My buddy is such a good lsx tuner i can just have him do most of it and be done with it. Just have no idea where to mount coil packs. I have no room whatsoever haha. It likely wont look too pretty
Old 12-04-2012, 06:20 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Do you have room back on the firewall? heaterbox area? etc.. Ya you would need custom wires but no better time to get some nice firecore 50 wires.
Old 12-04-2012, 06:48 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Can't wait to see this up and running
Old 12-04-2012, 06:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I may but i want them away from heat as much as possible lol. May go block mount below the heads. Kinda hidden but accessible from underneath
Old 12-04-2012, 07:00 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I dont recall but to you still have non a/c box? or all delete and flat firewall?
Ive seen people put em all inside under the dash before.
Old 12-04-2012, 07:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ac delete
Old 12-10-2012, 02:34 PM
turbo iroc's Avatar
It's been running for over a year now. Just the a1000 fuel pump is shot and couldn't keep up on the dyno. It was going lean and i let out at 5900 rpm. Still mustered 615 rwhp@10 psi
Old 12-10-2012, 02:40 PM
turbo iroc's Avatar
This was when i first got it running
Old 12-10-2012, 02:41 PM
turbo iroc's Avatar
First startup
Orr89RocZ
04-25-2016 08:28 AM
sweet_87_iroc
09-25-2015 10:01 PM
Camarothatcould
08-20-2015 08:49 AM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: triple walbro 255s in a stock (modified) tank
