TurboTPI upgrade....Finally
Old 06-18-2013, 12:21 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Well, after almost 10years i am doing some upgrading. New turbo and wastegate. After so many years and not going much faster over the years (turbo is maxed out), ive finally gotten bored. I figure my 62mm turbonetics has done good so far, but i want alittle more. I was looking at the turbonetics hurricane series 78mm turbo, but a friend of mine didnt use a turbo he bought a (Turbonetics HP-76) and desided to sell it, so i said if it fits, ill take it. Its tight, but it fits. With a horsepower rating of 1,000hp, i have plenty of room to grow. I also went away with the 38mm wastgate i had previously and went with a 44mm tial unit. Should be back on the street for some fresh tuning in a couple weeks. Im hoping for some low 10 sec times, MAYBE a 9.99 with the new setup. We will see. The stock block and crank will determine that. Heres a pic of the turbo on the car.
Attached Thumbnails TurboTPI upgrade....Finally-123.jpg   TurboTPI upgrade....Finally-125.jpg
Old 06-18-2013, 12:50 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TurboTPI upgrade....Finally
nice! tpi and turbos look perfect together
Old 06-18-2013, 07:47 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Subscribed!
Keep us updated!
Rafael
Old 06-18-2013, 07:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Awesome! Love this car. Hope it picks up well with the new turbo, thats a good sized jump.
Old 06-18-2013, 08:31 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Thanks guys, should be getting the wastegate and piping for it figured out next week. I had the wastegate venting to atmosphere, but this time im going to route it back into the exhaust, so i have a little bit of work to do. Im kind of sick of the loud open wastegate sound.
Old 06-18-2013, 09:20 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Nice upgrade. My memory has failed me....what are the heads and cam?
Old 06-18-2013, 04:18 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Are you running a log on the passenger side or a header? I saw pics of a header on the driver side.
I can't seem to get my car past the 94 mph barrier in the 1/8th at any boost and our cars are similar in many ways. Trying to figure out my bottle neck.
Old 06-18-2013, 04:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Nice upgrade. I need to read these boost builds more and finsih my 3rdgen. (need to leave my 97 alone also)
Old 06-19-2013, 12:20 AM
TurboedTPI's Avatar
Car: 92 Formula 350
I'm running aluminum L98 heads with 2.02/1.94 valves and minor port work with a TPIS ZZ-9 cam.
Old 06-19-2013, 12:24 AM
TurboedTPI's Avatar
Car: 92 Formula 350
The passenger side is half header, half log. The two out side exhaust ports exit the head in a single pipe then joint a main "log" that the two center exhaust ports just exit straight into.
Old 06-19-2013, 12:54 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Turbo TPI....You sir, are my hero.
Old 06-19-2013, 09:17 AM
TurboedTPI's Avatar
Car: 92 Formula 350
haha Thank you sir
Old 06-19-2013, 09:20 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
AWESOME BUILD. I love seeing TPI cars make good numbers. Do you happen to have a dyno sheet or breakdown of your best pass.
Just want to see how I compare so far..........
Old 06-19-2013, 12:41 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI + some bits
He got to say it before I did
+1
Old 06-20-2013, 10:09 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Thanks, I will try and find my fastest timeslip. What is your car putting down? or running in the 1/4?
Old 06-20-2013, 01:40 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Around 650rwhp through a 6 speed.
Here are a couple passes. As you can tell, I can't hook or shift too fast, yet....
7.2@102 with a 1.87 60"
Better burnouts coming!
Old 06-21-2013, 11:31 AM
fatalicshock's Avatar
Car: 87 Trans Am
Subed XD
Old 06-21-2013, 12:25 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Nice car man, subscribed!
Old 06-21-2013, 04:40 PM
GenX'Motorsport's Avatar
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
I always have loved this formula. TPI + BOOST = a beautiful thing!!!!
Hey,, wait just one minute. I thought SBC with TPI cant be fast... J/K. lol
Old 06-25-2013, 11:16 PM
TurboedTPI's Avatar
Car: 92 Formula 350
I found a timeslip where i went 6.9@102mph in the 1/8 with a 1.61 60ft. That run i went 10.81@126mph. I cant find my faster timeslips but i want to say 6.8@103 1/8 mile and i know ive cut a 1.55 60ft and that was one of my 10.7passes @ 129mph in the 1/4 mile. And i know i had one pass in the car that it went 130mph in the 1/4 mile. So we are very, very close power wise i'd say
Old 06-27-2013, 09:56 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Awesome! Looking forward to seeing how the new turbo works out for you. I've got a TC78 on my setup. Still dialing in a few things on it, but it's been a blast so far!
-Paul
Old 06-29-2013, 08:58 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.73
Need more pics please was or are you running a bbs header?
Old 07-11-2013, 11:38 AM
TurboedTPI's Avatar
Car: 92 Formula 350
obeymybird, yes, i have a BBS header.
Well, ive been driving the car daily to work and back. I have the boost set at 14 lbs and it feels alot stronger than before. The boost comes in so much harder than the 62mm. Its almost like hitting N2O. I was going to start working on the tune, but i think im just gonna wait and get the EBL p4 when i have the extra cash. Once i get a wideband in the car and verify the A/F ratio is safe, ill get some new times at the dragstrip.
Old 07-11-2013, 12:21 PM
Those really are amazing #'s with those heads. There 113's right? Whats youre intake setup exactly? Runners, Base, etc.. And what is youre compression?
Old 07-11-2013, 01:00 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Hey! I was driving right behind you yesterday on RT 83. I was in a white '83 Z/28.
Old 07-11-2013, 05:05 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Thanks, I'm not sure exact numbers off the heads, but they are off a 1990 L98 vette. I have TPIS large tube runners, ported stock base, ported plenum and 58mm throttle body. Compression is 8.35:1
Old 07-11-2013, 05:07 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Chazman, very nice Z! Looked mint!
Old 07-11-2013, 05:39 PM
1990 Vette heads would be 113's. But with the 58cc's on those. How did you get that CR ratio?
I love youre car BTW. Have the GMHT with it.
Old 07-11-2013, 11:40 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Yep, they are the 58cc heads. I have dished pistons and the thickest SCE copper head gaskets available. I was trying to get the lowest comp possible with the 58cc heads. i was trying for 8:1
Old 07-28-2013, 12:32 PM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
Do you have any pics of your hot and cold side?
Old 07-29-2013, 01:25 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
any engine makes power if you cram enough air and fuel down its throat
OP, your times will improve cosiderably if you can get that turbo spooled up at the stage light. some sort of make shift bang box would do it... and scare the bajesus out of people at red lights
Old 07-29-2013, 11:01 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Not off the car, but you can see pics of the BBS header online.
Old 07-29-2013, 11:03 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Yeah, im sure i could have gotton mid-lows 10's if i has a trans brake, but then i'd have rear axle problems for sure. Im not sure how the stock rear end is still alive now, let alone with any boosted launches. haha
Old 07-30-2013, 07:42 AM
ZZ3Astro's Avatar
Car: 87 Iroc
TurboedTPI,
I'm on a mission to get my 60 foots to 1.5. Since your combo is similar to mine, just wondering what all you've done to get to those. I went 1.59 on my old sport coupe on stock suspension and have gone 1.79 on radials in the Iroc, but since putting the new engine in I can't seem to control wheel spin on the rollout.. My best 60 foot now has gone to 2.0. Anyway I want to get it right but I don't want to buy parts I don't need. Debating on dual adjustable shocks and struts and an adjustable torque arm.
Old 07-30-2013, 09:55 AM
TurboedTPI's Avatar
Car: 92 Formula 350
TurboedTPI,
What tires exactly are you running? My best 60ft's were with 255/50r16 M/T drag radials on my stock wheels. I have all stock suspension execpt for TPIS valved shocks. Its transfers weight really well for being nearly stock. One day ill get a 9in rear axle and get some boosted launches made.
Old 07-30-2013, 08:33 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
you could also bring in boost like your doing a 5-10 foot roll out to help keep the axles straight.
Old 07-30-2013, 09:51 PM
ZZ3Astro's Avatar
Car: 87 Iroc
My tires are stock size 16" Firestone Wide Oval Indy 500's. The original Wide Ovals hooked better. I just found a set of the M/T ET Streets 255/60r16 that I would use on the stockers. But my friend had me convinced to buy some 15 inch wheels instead until I saw your 1.5 60 foot on the same 16" tires I was looking at.
I've been leaning towards double adjustable struts/shocks front and rear. I really like the QA1 coil over conversion struts. The only other major parts I was thinking about are Spohn crossmember with driveshaft loop and SFC's.
Old 08-13-2013, 10:38 PM
TurboedTPI's Avatar
Car: 92 Formula 350
took a short vid of the car. Need some out of car vids
Old 08-14-2013, 09:45 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Nice! Spools quick
Old 08-14-2013, 11:24 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Thanks, it hits nice and hard.
Old 08-15-2013, 05:08 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Nice! Spools quick
Yes it does!!! Congrats!
Old 08-15-2013, 08:55 AM
  #42
Dakota W.'s Avatar
http://www.youtube.com/watch?v=QlciC...FSCLVYtUK3KaQA
My ears need more, more eargasms, more turbo, more tpi.
Old 08-15-2013, 10:53 PM
  #43
Guest
Guest
Posts: n/a
Where is the ride along vid....
Old 08-20-2013, 11:05 PM
  #44
TurboedTPI's Avatar
Car: 92 Formula 350
alittle longer video
Old 08-22-2013, 11:59 PM
  #45
TurboedTPI's Avatar
Car: 92 Formula 350
So tonite i finally finished the wastegate plumbing, it is now routed back into the exhaust. I only drove it a few miles with a couple pulls, but so far its great. Nice and quiet, and able to hear more turbo whistle. And i still have the electric cutout if i want to disturb the peace.
Old 08-23-2013, 12:51 AM
  #46
Dakota W.'s Avatar
http://youtu.be/tzo4g7lxKQw
God, I can't wait to do my twin turbo 310 build....
Old 08-29-2013, 12:09 AM
  #47
TurboedTPI's Avatar
Car: 92 Formula 350
Heres a video of the car from the outside, first pass closed exhaust cutout, second is with the exhaust cutout open. The second one, the sound cuts out as i pass the camera, buts its just the recording, not the car cutting out.
Old 08-29-2013, 12:29 AM
  #48
TurboedTPI's Avatar
Car: 92 Formula 350
Heres an in car video. The sound of the exhaust has me thinking i need a bigger exhaust system. It sounds like air rushing out, no engine sound at all, just high velocity air blowing out the exhaust.
Old 08-29-2013, 07:03 AM
  #49
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
http://youtu.be/_w9bwvhlXSo
don't feel bad...I have a 3" straight thru exhaust and all you can hear is the turbo spooling and a huge rush of air out the exhaust too
Old 08-29-2013, 07:21 AM
  #50
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Mine has 4 mufflers on it and sounds like air too. With the old setup with turbos out the hood and no filters i could just hear turbo screaming lol underhood not so much
Quick Reply: TurboTPI upgrade....Finally
