89 IROC Twin Turbo LQ4 Build
Old 10-28-2015, 11:33 AM
  #101
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: 89 IROC Twin Turbo LQ4 Build
Wow the more you post about this thing the more I want it lol. Pretty slick setup/concept.
Jay
Old 10-28-2015, 10:41 PM
  #102
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
WEll I decided on going like your exhaust routing. Going to see if anyone wants to buy 3/4 of a fully welded dual mandrel 3" system with Xpipe and stainless mufflers with dual 3" that goes over the rear end.
Received my 4" tubing, dual 3" into 4" flowmaster Y pipe and my 4" dynomax SS ultra flow muffler. So well see how loud it really as its going to look exactly like yours. Do you have any sound clips of it running? I would love to hear it.
Old 10-29-2015, 09:26 AM
  #103
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
See post #71, there is a link of a video with it idling.
Old 10-29-2015, 12:34 PM
  #104
Car: 87 TA clone
Thanks, forgot it was there and that yours is turbo'd so the exhaust is a good bit quieter than a NA/supercharged setup.
Thanks!
Old 11-01-2015, 04:46 PM
  #105
89JYturbo's Avatar
I made a few pulls at the sloppy mechanics dyno day yesterday. It didn't make crazy power, but we had fun and had a nice drive there and back in my car. It was the first lengthy drive I took the car on (a little over and hour each way). I spun the tires on the rollers both times, the first pull spun real bad and put down 565hp. The second pull didn't spin much, and was 575hp. I was the 3rd car on the dyno (cold drum) and had new tires, so I think that hurt traction. I really don't think the tire slip hurt the power number much, especially on the second pull.
14psi, 12 degrees timing
I was hoping to at least match a factory Hellcat, but came up quite a bit short. There was one that pulled there later and put down 646hp. A little tuning should get me there I think.
Attached Thumbnails 89 IROC Twin Turbo LQ4 Build-10-31-15-dyno
Old 11-02-2015, 11:39 AM
  #106
Jay_rich's Avatar
Car: 1987 Z28
Awesome, Respectable numbers for sure!
Jay
Old 11-04-2015, 08:49 PM
  #107
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
What a beautiful car. Nice build! I am in the process of installing the ms3 gold box in my car now. How did you hide all the wiring under the hood? I see you also moved your brake proportioning valve. Where did you move it to?
Terrell351
06-13-2021 01:13 PM
SiCkRs
Members Camaros
32
07-01-2018 04:53 AM
Orr89RocZ
04-25-2016 08:28 AM
86White_T/A305
08-17-2015 12:16 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: 89 IROC Twin Turbo LQ4 Build
