ZZ3 Turbo Iroc - Round Three
#851
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: ZZ3 Turbo Iroc - Round Three
gone
#854
You could be right on the lifter being pumped down. I don't recall, what's your cranking PSI? Did you lose any after putting in this cam compared to the old setup? You could have a ton of power if your cam's off.
#855
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Are you sure you measured the lift at .050" properly? 1.5 rockers means .075" at the valve.
I would do the following before tearing apart or ordering anything.
1) verify the cam card for ICL and intake open @ .050" is correct. Some places mess up the +/- and the ATDC and BTDC.
2) Ensure the (pi*D) = 3.14 * 8" is correct.......that the balancer is 8"
3) Double check the (114/360)*(3.14*8") is correct and tape to balancer
4) Loosen cyl #1 rocker. Put something around pushrod to keep stationary relative to head pushrod hole or valve guide. Setup dial indicator on pushrod with valve on the base circle. Record dial indicator value. Spin engine until pushrod lifts .050" and look at balancer, then do this for max lift and look at balancer.
EDIT: putting some lines 2 degrees apart in visio works. Set the snap grid to (2/360)*(3.14*8).
#856
Car: 87 Iroc
gone
#857
1 Post
Engine: 3xx ci tubo
It sounds like you did it right. Measure ICL by the .050" point before and after ICL and then find center of that in terms of degrees for ICL.
Only other thing I can think of is making sure the harmonic 0* mark is correct as compared to TDC.
Could also just do the .050" opening and .050" closing point for intake and then calc ICL from that. That is how I do it. It sounds like you are "there" in terms of the .050" open point. I bet the .050" closing is correct too and the ICL falls into place from that calc. ICL directly is harder to measure.
Either way, being advanced or retarded 4* is not going to make it quit revving like you described. With the wheel in the turbine it gives flow direction. Without it, massive turbulent flow.
EDIT: I don't see the pressure of the dial indicator causing a leak down problem.
#858
Car: 87 Iroc
gone
#859
1 Post
Engine: 3xx ci tubo
Looks great. Instant 50HP pickup right there. Where do you get the turbine outlet flange, or does yours match up?
I would call the cam good for now, install the turbo, and let er rip.
#860
Car: 87 Iroc
gone
#861
I've been following this build for a long time. i have talked to you before on YouTube, i have ZZ3 too.
did you get a new cam? i read some of this thread (not every post) i couldnt find what cam you chose.
I'm a huge fan of TPI but i really think you can go way faster at this point with a Holley Stealth Ram. it would add some power and you would lose a little bit of the low end torque that will help with any traction issues I'm pretty sure after this winter my ZZ3 is getting a Stealthram and may an LT4 hot cam. I've been cam shopping for about a year now and i still can't make up my mind. i dont wanna have to upgrade half my motor or half of my car just for a cam.
#862
Car: 87 Iroc
gone
#863
Car: 87 Iroc
gone
#864
perfect project for the plasma cutter. get some 5/16-3/8" plate, cut out a piece that will bolt onto the turbo, drill 2 bolt holes, and then tap it to whatever you need it to be. 1/8-1/4" pipe or whatever your fitting is. tap should be available at lowes/homedepot etc.
#865
Car: 87 Iroc
gone
#867
Car: 87 Iroc
gone
#868
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I think every time I've dynoed this engine it has been mph based. On the rpm based ones in the past, the stall makes the start around 4000-4500 and the peak hp was always at the beginning and falls off. Same thing for the mph based one. Power shoots straight up at 65 mph, peaks at 80 and declines the whole pull. Peak hp of 532 at 85 mph and down to 460 at 114.
3.27 ratio and 25" tall tires.. Not accounting for the converter slip:
85 mph is 3736 rpm
114 mph is 5001 rpm
Your guess is as good as mine on converter slip.. probably 8-10% so 5500 rpm for the 114. Sounds about right from what the tach is doing.
85 mph is 3736 rpm
114 mph is 5001 rpm
#870
Car: 87 Iroc
gone
#871
Car: 87 Iroc
gone
#872
Decided to keep the cam advanced 4 degrees between my research and what you guys have input. Results are in.. as expected, spooling sucks compared to the PT6766. Power takes forever to come in and right when there is a hint of go I am out of rpm. Just very lackluster overall at 16.5 psi.. with a 78 at that boost level, assuming no insane restrictions, it should be an intense ride. It's not.
I have a few ideas of how to proceed...
I can test intake runner and lower intake restrictions by connecting a second boost gauge to the cold start injector location. I would expect a 5 psi drop at 5000 rpm from the upper plenum pressure to the cylinder head inlet (semi-close to the cold start plumbing. This drop estimate is based on the length and diameter of the stock tpi runners and estimated flow/psi. If the drop is much higher than that, the intake is the biggest restriction. If it is less than that, the heads or cam would be the source of the restriction.
I can eliminate the intake also by changing it. I have a blow thru carb available and the original intake and distributor from the ZZ3. This would be an easy swap and ironically is the first step towards removing the engine anyway. Also I can just do this N/A to see if the 4000 wall is still there.
I've been debating intake/heads/cam ugprades but I keep thinking it might be time to do a 5.3. Certainly my current setup is not going to work as it is.
right now im thinking about a set of the 60mm t70's or a pair of on 3 66's
if i knew i could spool them id drop a set of gt45's on it .
second put an clone hsr on it for 200 bucks + 50 bucks for the fuel rails
#873
Car: 87 Iroc
gone
#874
what condition is the t70 in might be willing to trade ya a bigger turbo or something for it
think ive got some big old school garetts and holsets laying around
#875
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I'm curious as to how much timing you are currently running. Our setups are not extremely similar, but I always like comparing. I have been running around 20-22 degrees of timing over 3000rpm at 10psi (180kpa). I haven't ran higher boost yet but this seems to be about as high as I can go and be a couple degrees shy of the detonation threshold. I'm running cast iron vortec heads with a 212/222 cam with a performer rpm intake and a blow through setup running low 11 AFR's.
Regarding the lower exhaust backpressure (theoretical with the larger turbo), I noticed a definite difference in how much timing mine would tolerate whether I had my full exhaust vs an open downpipe. If I remember right, it would handle about 3-4 degrees more advance with the open setup.
#876
Car: 87 Iroc
Project89, it wasn't burning oil or anything but it has about 10k miles on it. Biggest thing is a good bit of radial play but only about 1/2 what the Precision has. Are you just looking to mock it up or use it?
Vortec350s10, I have to refresh my memory on the timing error on my MS but I think it is about 5 degrees at 5000 rpm. Until tonight I was running the following:
4900 rpm 15.2 psi 20.1 degrees (25.1 in the map)
3700 rpm 15.2 psi 13.5 degrees (17.0 in the map)
4900 rpm 10 psi 24.0 degrees (29.0 in the map)
3700 rpm 10 psi 15.7 degrees (19.2 in the map)
This evening I bumped that up a bit to the following with no detonation:
4900 rpm 15.2 psi 22.2 degrees (27.2 in the map)
3700 rpm 15.2 psi 15.8 degrees (19.3 in the map)
4900 rpm 10 psi 24.9 degrees (29.9 in the map)
3700 rpm 10 psi 19.8 degrees (22.3 in the map)
I found the tpi setup to be very prone to detonation in the 3000-3500 range and have always been conservative there.
#877
Car: '88 Iroc
I would bet the 3000-3500 rpm range is where you are making the most torque. Is that where your VE numbers are highest? How are you getting your rpm signal for the MS? I ran my MSD box rpm signal off of the pickup coil in the distributor and with the timing programmed to a constant value, it would still advance itself about 5-6 degrees when revving it vs idle. I always chalked it up as cam walk and timing chain. I'd be curious to see your msq sometime if you don't mind sharing. I'm currently converting over to a MS3 setup from the carb right now. I'm going to install a 36-1 wheel on the crank for an rpm signal to hopefully get away from the timing variance I'm currently seeing. Thanks for sharing your timing.
#878
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
#879
or maybe even the garett 66mm compressor wheel and housing
#880
Car: 87 Iroc
gone
#882
yea im gonna say its too tall. ive got a low rise intake and carb on my 92 firebird with a stock trans am hood and i have to use an insanely small filter, Camaro do have a lil more room but youll probably need a cowl hood to run that intake.... but im not an expert or anything
#883
Car: '88 Iroc
My friend ran a Spectre low profile carb hat that was the lowest he could find. Although I'm not sure if you would run a 4150 style TB or do an elbow and run your TPI TB or go with a LS style. I'm not sure what would be the lowest setup. I know I'll be using at least 2" of my 3" cowl for clearance on mine. I'm going to run a RHS single plane EFI intake (12903) and it's probably taller than the Procomp. I think most anything would be a challenge fitting under the stock hood.
#884
Car: 87 Iroc
gone
#885
1 Post
Engine: 3xx ci tubo
I remember you looking into the MS ECM spark latency before. The stock TPI ignition module averages about 200 microseconds of latency. At 6000 RPM, the crank takes 10,000 microseconds per revolution which is 10,000/360 = 28 microseconds per degree.
So, 200/28 = 7 degrees.
If the MS2 doesn't take into account the module latency then your timing is 7 degrees retarded from where you think it is at.
Good move with the cam, I would have left it where it was at too.
Not sure why it takes so long to spool. Stock 305ci with two 54mm compressors makes 15PSI by 3500 RPM.
#886
Car: 87 Iroc
gone
#887
u can ditch the module and do direct coil control, rotor phasing will also have an impact on spark timing performance
#889
1 Post
Engine: 3xx ci tubo
What do you have it set to now?
There are two parts to the spark latency:
1) The time for the signal from the detection of the "tooth" to the ECM seeing the signal.
2) The time from the ECM sending the "coil fire" signal through the switch (IGBT,BJT,MOSFET) to the coil.
Even the "direct coil" control method has spark hardware latency.
#890
Car: 87 Iroc
gone
#891
Car: 87 Iroc
gone
#894
Dont go darkside... ok a LS swap isnt darkside. i said it once ill say it again lol i really think with everything your ZZ3 has on it you would upgrade to a Holley Stealthram. you probably make peak power in the 4,700 - 4,900 RPM range now with your TPI setup, but with your current heads and cam you could be making peak power at 6,000 RPM. ive seen a 400 horsepower TPI engine turn into 500 horsepower Holley stealthram engine, just swapping the intake. ADD in your turbo and you can imagine the horsepower your current motor has the possiblity of making. im telling you its gonna be the best $600 you spent. you could even buy one of the Ebay $300 rip offs if you wanna save a few bucks. speed master i think makes one too. i think with just the intake and redoing the tune to match the intake youll be a happy man. and no need for a cowl hood, the stealthram will fit under it. i have to modify my formula's hood to make the stealthram fit under my hood... wish i still had my
IROC lol
IROC lol
#895
Why not take it to the track and see what it does before you start LS swap it? I mean can you really tell the difference at these power levels with the kind of torque a TPI system will make? That torque curve is going to be insane, and it may not pick up much on the high end the way you expect, but it'll still pick it up in the mid range.
#896
Car: 87 Iroc
gone
#897
Just run it on the street/highway and stop crying. Be thank full for what you have.
#898
Hey OP, what size coupler on you running on the TB?
(I bought a 3" to 4" and it seams like it might be to big / haven't put a clamp on it yet)
#899
Car: 87 Iroc
TB fits 4". I can't remember if it went on loose or tight though. Seems like it was a good fit but its been years!
#900
I put it on and their was about 1/4 of material on the coupler that was "loose".
