and so it starts
Old 02-19-2014, 07:19 AM
  #101
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: and so it starts
Originally Posted by 1991sleeper
For a 305 that's pretty hot. ... and that signature is about 2 years old the motor only has 1000 miles on it if that just got it pit in a couple months ago and I have a 150 shot waiting to go on it
Sent from my XT907 using IB AutoGroup
I was recommended the cloyes double roller by someone who used it in their 383 pushing 600hp, I don't see the need for a billet timing set if his has held up for 4 years without issue. It's not like you can see how shiny it is through the timing cover anyway.
Dakota W. is offline
Old 02-19-2014, 08:08 AM
  #102
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Y the hell does it matter what parts I put in MY motor not urs ? If I wanna put 1500$ pistons in a 300$ motor that's my choice so blow me .. like I said I didn't skimp on anything ! And if his lasted 4 years w 600hp then I shouldn't have to worry about mine for awhile huh ? .. and with a 150 shot IMA b pushin around 500hp with a 305 .. which is gonna be in a lot more strain than a 500hp 468cu.in.BB
1991sleeper is offline
Old 02-19-2014, 08:58 AM
  #103
Dakota W.'s Avatar
Why do you feel the need to be argumentative and post something when I was asking the OP a genuine question? saying "why not?" is no better than saying "because I can." I asked the OP because I thought that maybe he knew something I didn't, wasn't trying to start anything, not sure why you are.
Old 02-19-2014, 09:07 AM
  #104
Car: 1991 firebird
Axle/Gears: 4.10
u r the one acting like I'm retarded for choosing a better part than u used
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Old 02-19-2014, 09:09 AM
  #105
Dakota W.'s Avatar
So, do you always walk up to 2 people having a conversation and interrupt? Or do you only do that online? I honestly don't give 2 ***** about what's in your car, I was asking about the OP, not yours. I didn't know common courtesy wasn't taught to children anymore.
Old 02-19-2014, 09:15 AM
  #106
Car: 1991 firebird
Axle/Gears: 4.10
U started this **** retard .. u were saying that why do I need billet set and I Told u y .. then u proceeded to say it was pointless in a stock lo3 which I replied that it was not stock .. so how am I interrupting ur conversation when u were talking **** to me ? Hmm ? And I was referring a part and a price to the op not u so u got itself involved in my conversation
Old 02-19-2014, 09:19 AM
  #107
Dakota W.'s Avatar
It's pretty clear you were posting it in reference to my comment. I mentioned my part and price and then immediately after you mention yours. Get your ego checked and stop cluttering up the OP's thread.
Old 02-19-2014, 09:25 AM
  #108
Car: 1991 firebird
Axle/Gears: 4.10
Who cares what I referenced I was not talking to u I was posting nother option for the op not u... and u are the very first person ive ever had an Argument with on this forum since I've been on it so mabey u should check yours.. and if u would stop arguing with me like a 13 year old girl on her period I wouldn't b cluttering HIS thread which u r also doing the same thing .. so once again stfu
Old 02-19-2014, 09:33 AM
  #109
project89's Avatar
the reason the belt drive is better is timing is more stable, and it does not transfer any harmonics up into the valve train
years ago before belt drives and even today guys used to run composite and plastic timing gears with a chain to help cut back on the harmonics. hell i even have a few of those gears laying around somewere
project89 is offline
Old 02-19-2014, 09:36 AM
  #110
krazeefewl's Avatar
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
Maybe you gentleman can take this to PM instead of hijacking a perfectly good thread. I was looking forward to updates to this build, but was disappointed by the lack of useful information in the last few posts.
krazeefewl is offline
Old 02-19-2014, 11:43 PM
  #111
Dakota W.'s Avatar
Don't belts usually stretch a lot easier than chains? I don't know about a wet setup, but I know the dry setups do. I thought roller valvetrains soaked up a lot of those vibrations?
Old 02-20-2014, 01:18 PM
  #112
project89's Avatar
i shouldnt say a belt stops the transfer of all harmonics , theres still some
yes a belt can wear out faster,and requires maintenance.
this will be my first time using a wet belt setup so we will see how it goes , like i said i paid a fraction of its cost so for that cheap im willing to give it a go
Old 02-20-2014, 05:29 PM
  #113
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Who makes those headers?
88GTAbandit is offline
Old 02-20-2014, 06:21 PM
  #114
project89's Avatar
which ones the log style ones or the up and fowards that ill be using?
Old 02-20-2014, 06:25 PM
  #115
The forward facing ones you plan to use
Old 02-20-2014, 07:10 PM
  #116
project89's Avatar
cx racing on ebay
Old 02-20-2014, 07:14 PM
  #117
really? lol nice, may look into those myself, thanks for helping
Old 02-20-2014, 07:16 PM
  #118
project89's Avatar
if u get a pair i would email them the ad says 2.5 inch vbands but the picture sure looks like 3 inch
i havent ordered mine yet , its the next thing on my parts list right after the last few parts i need for the hsr
Old 02-20-2014, 07:18 PM
  #119
i was thinking i may want a 3in cross over depending on my route...was thing either a t4 76/78mm or a t6 80mm
Old 02-21-2014, 09:28 PM
  #120
project89's Avatar
just ordered a pair of gt3582's, new turbo flanges , bunch of 3 inch mandrel bends for the dual 3 inch downpipes , and im debating on ordering a 2 in and single out inter cooler so i can redo all the charge piping
i still need to come up with a manual steering box and manual brake conversion so i have room to run the downpipes out the fenders behind the front tires
sigh... the more i work on this thing the more it becomes a track only car, before i know it ill be hanging some fiberglass doors and front end on it
Old 02-28-2014, 05:18 PM
  #121
project89's Avatar
quick update
im heading over tonight to work on the car . were preping the engine bay tonight for paint, if the prep work goes fast enough hopefully we can spray the engine bay tonight , if not ill spray the engine bay tommorow , and then the following weekend we r going to drop the engine back in
Old 03-02-2014, 07:46 AM
  #122
Street Lethal's Avatar
Stop your stalling, get that engine in there....
Street Lethal is offline
Old 03-02-2014, 10:15 AM
  #123
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
What he said! Lol. Can wait to see it in and running!
willexoIX is offline
Old 03-02-2014, 07:43 PM
  #124
project89's Avatar
im taking ,my time with it the car is gettig a nice paint job this spring so i want the engine bay paint to look nice as well
even if i dropped the engine in today i wouldnt be able to fire it , im still waiting on a few misc parts to arrive
that and im hesitating wondering if i shouldnt upgrade the camshaft, when i picked out the summit 224/224 cam i had the intentions of running a gm cast iron head and the tpi. with the new heads and hsr intake im thinking i could benifit greatly from a larger cam or swaping to a roller cam with alot more lift to take advantage for the good heads
i traded my friend some of my old parts for a new ms harness so i could redo all the wiring in the car ,the premade harnes si got with my ms unit was a total pos and has been hacked up a million times
Old 03-02-2014, 09:17 PM
  #125
Dakota W.'s Avatar
The bigger the better, go for it.
Old 03-03-2014, 06:00 AM
  #126
Too much emphasis being placed on the cam Dave. Was talking to Paul last night going over your setup, and he thinks your overdoing it. Even if your shooting for 8's, there are guys going that fast and faster with less, unless your into a lot of cam, of course. Either way, get her done and have fun doing it...
Old 03-03-2014, 06:05 AM
  #127
project89's Avatar
ur probably right with the parts i have, and twin 61mm turbos i shoudl have no problems making enough power as it is
my biggest concern is actually if the stealth ram will have any air distribution issues at high boost
Old 03-03-2014, 06:12 AM
  #128
project89's Avatar
btw not sure if u saw these or the other thread so ill post them here
  #129
Does MS have individual cylinder correction?
Edit: That engine looks sweet as hell...
Old 03-03-2014, 06:16 AM
  #130
project89's Avatar
yeah its got some nice parts in it for sure
no i downgraded from a ms2 to ms1 when i thought my ms2 cpu went bad, i can still switch back to ms2 as i still have the cpu
in the near future i will upgrade to ms3 pro and have sequential and ind cyl fuel/spark control
Old 03-03-2014, 04:53 PM
  #131
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Since MS1/2 has two drivers then you could run 4 injs at different cals. I am surprised MS still doesn't have it. Easy to add. Some of the GM ECMs OBD1 have two drivers and you can use it for fuel distribution changes. Run 4 inj in the richer holes, and 4 in the leaner holes.
Or just run all 8 as rich as leanest hole needs and deal with slight power loss.
junkcltr is offline
Old 03-03-2014, 09:32 PM
  #132
project89's Avatar
ms does does do that u just have to run duel table
Old 03-04-2014, 06:52 AM
  #133
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Install a bung for wideband in number 1 or 2 primary and in number 7-8. Do a back to back pull on lower boost to check whats going on. That was my concern when i built my motor and i convinced myself to switch to single plane and been very happy
Orr89RocZ is offline
Old 03-04-2014, 08:51 AM
  #134
project89's Avatar
doesnt the backpresure and heat kill the sensor?
i was thinking about doing a couple egt probes and logging them with the megasquirt
Old 03-04-2014, 08:58 AM
  #135
Depends on the sensor. The Bosch sensors will eventually fail being that close, but then again you'd only be using it as a test, not long term. The XFI wideband sensor in my vette was designed to be that close though. Don't forget though Dave, they sell housings that the Bosch sensors screw into first, then the housing screws into the bung, to allow for the Bosch sensors to live being that close, just need to clock the housing the right way otherwise you'll get an innacurate reading...
Old 03-04-2014, 10:16 AM
  #136
junkcltr's Avatar
Engine: 3xx ci tubo
Under boost the sensor will overheat and not be accurate. The controller will not be able to control the heat and get a proper reading. NA is a possible for a little while.
junkcltr is offline
Old 03-10-2014, 07:09 AM
  #137
project89's Avatar
pushrods are sitting at the post office ill pick them on lunch break today,
need to order up some felpro 1206 or 1266 intake gaskets , thos ei can just get at my local napa
also picked up 100 each grams cobalt blue, and silver pearl powder ,and got a ton of .015 blue metal flake
the blue pearl gets mixed in with the black base so the car looks black but shows up blue under sunlight/light
the silver will be used for some ghost stripes and lettering , and then i may spray the entire car with the flake , or instead of ghost stripes and lettering i may just do some stripes in metal flake
ill be experimenting on the old iroc hood for the next few days to see how the different ideas come out
Old 03-10-2014, 08:08 AM
  #138
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I guess it depends on egt, pressure and sensor used. I know people have done this with no issues. It is only short term to get a quick distribution reading. Else do it the old fashioned way with plug reading
I've had my bosch 9-10" from turbine exit and it seemed fine for few years. I've had the first 2-3" of downpipe glowing red before
Old 03-15-2014, 01:35 AM
  #139
project89's Avatar
intake came in , this thing has enough meat to be ported to a 1207 gasket , my heads are just under a 1206.
the wieand would need a lil bit of welding to be ported to a 1206.
so either way i have a ton of room to grow with this set of heads and intake
engine bay is getting painted tommorw and on sunday ill button the engine up then next weekend we should be firing the engine up
Old 03-15-2014, 07:10 PM
  #140
willexoIX's Avatar
Wow Dave, that looks incredible! I wish our 455 looked like that, lol.
I'd love to have that Kawasaki behind it
Old 03-16-2014, 01:56 AM
  #141
project89's Avatar
started to mount up my acessories n stuff so i could lay out the new turbosystem
other then that my first attempt at laying down a pearl basecoat in the engine bay was a total disaster
of course it didnt help that the color pearl i picked is one of the hardest to spray even for a good painter, were as i have a tiny bit of experiance and its mostly spraying primers
Old 03-20-2014, 03:38 PM
  #142
project89's Avatar
im finally within 30 days of the car being done
the engine goes back into the car this weekend
next weekend i touch up some body work on the car
on april 4th my new 4 inch hood gets here
april 7th the car goes into the body shop for paint
april 18th the car is being hauled down to las vegas motor speedway for some test hits , and on the 19th the car gets dynoed (weather will be a factor on this one)
Old 03-20-2014, 04:53 PM
  #143
Waiting patiently for your numbers Dave, already know what mine runs, tee hee...
Old 03-21-2014, 02:40 AM
  #144
project89's Avatar
wont be long now , im just hoping the body shop wont have the car for more then 2 days , i need a bunch of time to get a base tune down before i tow the car out
Old 03-22-2014, 10:21 PM
  #145
project89's Avatar
hit a snag with getting the motor in the car , the plan was to reuse my old turbo system till after the car gets painted and ten swap over to the new headers and gt3582's
well my old headers no longer fit as u can see in the pics , i need to cut the wastegate tubes and move them , not a big deal but we had no gas for the welder.
so next weekend i will fix the headers and drop the engine in , and also build the parachute mount
work may slow down on the car though now that i have a 2 wheeled transportation
Old 03-23-2014, 06:22 AM
  #146
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
If you can make it out this way.....
https://www.facebook.com/#!/events/5...ilter=upcoming
Bunch of folks from LV Buicks are renting a lane at LVMS, I plan on being there.
34blazer is offline
Old 03-23-2014, 06:45 AM
  #147
project89's Avatar
that should work for me as long as i dont run into anymore issues putting the car back together
btw u got any names of shops with dynos down there so i can start making some phone calls
Old 03-23-2014, 07:26 AM
  #148
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Well I know of one so far, Voodoo Racing. Ill ask around within the next couple of days.
34blazer is offline
Old 03-23-2014, 07:36 AM
  #149
project89's Avatar
thanks
Old 03-23-2014, 10:24 PM
  #150
83 Crossfire TA's Avatar
do you have details in a thread somewhere (I've been woefully behind reading stuff here...)?
83 Crossfire TA is offline
Quick Reply: and so it starts
