Vader Ta Procharged F2 Car
Car: 89 GTA
Engine: 400
Transmission: 400
Axle/Gears: 9 inch 355
Just a video of my F2 Procharged TA . 400 sbc with 23 degree heads @ 3500 pounds. I know turbos are the more sought after power adder these days , but don't sell the Prochargers short.
Car: 89 GTA
Engine: 400
Transmission: 400
Re: Vader Ta Procharged F2 Car
Thanks guys, Have not had the car out much this year , actually only 5 passes but it still is running well and hope to get after it next season. Just been too busy to give this car the attention it needs. The combo is a 4.125 bore 3.750 stroke 6'' rod with 9.0:1 compression. The top half is a set of 245 AFR heads with a victor efi intake and a Steve Morris camshaft running Bs3 fuel injection. The Blower is an F-2 with a Procharger A/W intercooler. It has a 3 speed th400 and 3.50 rear gears running on MT 275 Pro radials.
Car: 89 GTA
Engine: 400
Transmission: 400
I am closing in on the 180 mph mark. Unfortunately I did not have the front half power in the car on this day as it was a diesel truck drag day as you can see in the staging lanes in this video. If I could put the front half power in with the back half power I think it will run pretty good . But it is a wait until next year type of deal.
Car: 89 GTA
Engine: 400
Transmission: 400
Just pulling timing and adjusting shift points so the boost does not get to high before the shift so it blows the tires off. Running 15 degrees out in first gear. The diesel trucks sure muck up a track. Between blowing oil on the ground and ripping it up with the big aggressive tires with 6000 pounds over them. Made it a real challenge. Yes the announcers are always good at this track.
Car: 89 GTA
Engine: 400
Transmission: 400
Not sure on the wheel Hp as I have not had it on a chassis dyno but it makes 1700 fwhp. Power did not drop on the pulls and after tuning at the track I am confident I have picked up
Car: 89 GTA
Engine: 400
Transmission: 400
Yeah, I would like to make some more power but my goal has been to do it with the factory hood , but that really messes with the front cylinder tune as the elbow is so short that the air favors the back cylinders. Was thinking about getting a fiberglass hood and raising the elbow higher up with a bigger throttle body to see what it picks up. Plus I don't know what a factory hood weighs but it might save a little nose weight. Then after I see what I can gain I will put the factory hood back on. Kind of have a reserve if I ever need it for some reason.
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
bad *** ride man! steve morris is the man would love to have him build me a engine one day!
Car: 89 GTA
Engine: 400
Transmission: 400
No, elbow is wide open. Just cant make the air turn in such a small amount of room. Tried many different things in the manifold but it all comes down to height restriction. I guess I could build a sheet metal intake . But I would have a hard time spending $5000 on one for $2500 heads LOL. Yes Steve is a very smart engine builder!
I dont think i do but maybe check this out for pics and info
http://www.yellowbullet.com/forum/sh...d.php?t=643866
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Beautiful car and crazy fast, love how you still kept the factory look!
Do you have more pics of your setup, interested in how you fit the a/w intercooler.
1 Post
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Very impressive! love the fact that its a GTA!
Car: 89 GTA
Engine: 400
Transmission: 400
Car: 89 GTA
Engine: 400
Transmission: 400
Maybe this picture will give you a general idea as it is the only one I could find.
Car: 89 GTA
Engine: 400
Transmission: 400
good lord thats one nasty TA
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
What is your rear suspension set up? Still running a torque arm?
Car: 89 GTA
Engine: 400
Transmission: 400
Still running a full length torque arm, it is a Moser TA . I have Strange DA shocks in the rear and Strange DA stuts in front. Front springs are 150 lb and rear springs are 100lb. TRZ rear anti roll setup in the back.
Car: 89 GTA
Engine: 400
Transmission: 400
Thanks, I will try and dig some up. Most of my pictures are on an old desktop computer that does not get used . I will have to turn it on and see what is on there.
Car: 89 GTA
How about a rundown of engine parts, what does it actually take to get a engine to live at 1700hp?
Car: 89 GTA
Ah yes I see it now. Little more involved then then a guy could build in his home garage
You'd be surprised. Just takes good money to but those components and a good machine shop to get everything fit in right with clearances and such. Rest of it just about anyone who can build motors can finish. Cam heads installs etc basically same. Just component selection is on a higher level
Car: 89 GTA
Engine: 400
Transmission: 400
Yep , there are no secrets but buy the best you can afford and pay attention to details. But I will give a rundown on the short block. It is a dart Little m block , Callies 4340 crank with a BBC crsank snout with 400 mains, 6" oliver billet rods with the upgraded rod bolts they offer, Steve Morris engines custom hard anodized boost pistons
Steve Morris custom ground cam, Mellings billet oil pump , Morel lifters, and a custom billet rail oil pan that I had custom made but for the life of me cant remember who made it . Piston pins are also very important, I run Trend .220 wall tool steel pins. Rings are Helfire rings.
Car: 89 GTA
Engine: 400
Transmission: 400
Here is the picture of the exhaust I used to run when street driving it, Those are Spintech mufflers. Had plenty of ground clearance.
Car: 89 GTA
Engine: 400
Transmission: 400
I think the F2 is banned in those classes around us unless I run a restrictor . Possibly going to swap to a turbo setup as that gives me more opportunity to run those classes . I like the F2 but it limits me if I want to run any of the 275 classes
#42
Car: 89 GTA
Engine: 400
Transmission: 400
That option is on the table also although it would not be an R as that blower in my car would be too slow . Either route I go it is doubtful I would be very competitive under those rules as my car weighs too much.
#44
Car: 89 GTA
Engine: 400
Transmission: 400
Yep, If I were to run in the class it would be for the fun of it and I would just be a filler car. If I was serious about being competitive the car would be set up a lot different.
#47
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
What elbow and throttle body is that? I'm impressed it fits under the hood.
Waterneck ?
-- Joe
Waterneck ?
-- Joe
#48
Car: 89 GTA
Engine: 400
Transmission: 400
It is a Wilson elbow with an Accufab 90 mm TB . Waterneck is a -16 line into the front of the intake. It is not an ideal setup for making power but is definitely cheaper than a custom intake manifold.
#49
-- Joe
