Run filters or screens with your turbo(s)
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Re: Run filters or screens with your turbo(s)
Man, that is rough! What do you think you pulled through? Hopefully it was something the engine could spit out without much harm. You check out the intercooler to see if you could find any debris?
Car: 1991 Z28
That is one expensive wire stripper you have there! You may have gotten lucky by having the intercooler core "filter" the wads of wire and insulation. It would definitely be interesting to see what is in there.
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Man, bummer! It will need to be re-balance too right?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Why were you not running screens or filters in the first place?
i've seen a couple cars with similar damage lately. i think i am going to just run a tad slower and keep filters on it. its just not worth the potential damage unless you are running a heads up class or something like that where every last hundredth counts.
ur lucky the wheel didnt come apart , usually running withotu filters or screens isnt to bad as long as ur turbo inlet is under the hood , ur more likley to pick up something driving around the pits then u are on the track.
anyone rember that video of of an import iirc with the turbo threw the hood sucking up a small bird at the track
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
And people knock Turbonetics. Thats some awesome customer service!!
Jay
Jay
eightsixseven
08-14-2015 03:09 PM
92camaroJoe
08-13-2015 06:07 AM
