Single turbo engine
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Single turbo engine
I've been pondering this now for a little while.
I have a 355 on the stand with a bag over it I just got back from the machine shop. 4 bolt mains, OE roller block.
I was gonna stick a ZZ4 cam and heads on it, and stick it in my Stingray as a n/a driver.
My Firebird has a 412" with a NX276HR retrofit cam, afr210 heads, cast manifolds and a T76.
I wonder if I should put the 412" in the Corvette, and run it n/a (or nitrous) and instead run the T76 on the 355?
I wonder if the 355/zz4 would be more suited for the smaller T76 than the 412. ?
I also have a concern about the 2 bolt main 400 block. I know the logical answer is to go with a 88mm turbo on a 400+ inch motor and run 9s, but I think I'll end up becoming a member of the "I drove over my crank" club..
-- Joe
-- Joe
Re: Single turbo engine
I just wonder if a 355 would be better with the smaller T76 (more boost, more efficient in the turbos range) than a 412. I wonder if the 412 would be a better n/a or nitrous motor in the stingray.
-- Joe
Terrell351
06-13-2021 01:13 PM
