Budget Turbo for L98?
Car: 92 Z28 Camaro
Engine: 355 TPI
Axle/Gears: 10 Bolt 2.73
Does anyone have any recommendations for a mostly stock L98 budget turbo setup? Preferably a single turbo low boost setup, probably around 8lbs. And how much power this would pick up? My L98 was rebuilt about 100k miles ago, but it was bored .030 over and given a mild cam when it was rebuilt.
Car: 92 Z28 Camaro
Engine: 355 TPI
Re: Budget Turbo for L98?
Cost isn't TOO much of a factor with this setup, but cheap is always better, as long as it's still good.
On3 make those two sizes plus a 76. The 61 would do 350-400 hp easily and comfortably. T70 400-500 easily. T70 is very popular and available so you may find them more often for sale by vendors and classifieds. I put a 70 on my 305 because i got it new for 280 shipped. It spools fine and is abit overkill for what i originally wanted but leaves room to grow
All depends on what you want motor to do and how much you wanna spend. Just throwin out options of whats best bang for buck available
Step up would be borg s366 for 550-600$. Its a lot larger frame tho and makes packaging alittle more difficult. Gt45 also is available for 300-350 ish from vsracing. It will do 600-650 hp so its overkill on stock motor but leaves room to grow
Turbonetics hurricanes are great. 6265-6668 would be great too
Car: 1987 Iroc Vert
Transmission: 5 spd
[QUOTE=Orr89RocZ;5970640]On3 make those two sizes plus a 76. The 61 would do 350-400 hp easily and comfortably. T70 400-500 easily. T70 is very popular and available so you may find them more often for sale by vendors and classifieds. I put a 70 on my 305 because i got it new for 280 shipped. It spools fine and is abit overkill for what i originally wanted but leaves room to grow
Is the main goal to find a turbo that spools at the correct RPM for the motor size and condition of use, track vs Street ? .
I would think that for track use, the turbo would spool higher and street the opposite. Correct ?
In that case, how does your t70 REAR mounted turbo spool easily ?
What RPM does it spool at ?.
Thanks George
Thanks George
A lot of the turbo choice depends on use, engine and power train choices. The more flow into the engine required the more flow out from the turbo you'll need. If I had an auto or manual and no plans to change the converter or engine, I'd lean small. You're only using a narrow power band in a drag application (road race applications are another animal) so having a high stall speed to bring the RPM up quickly, then a bigger turbo that needs it is okay. Naturally "streetable" is a super subjective term as some people believe it's driving whatever doesn't get the cops pulling you over. Even if you're doing something that's more dedicated track it's possible a smaller turbo works better for the reason that you get more area under the HP curve due to a faster spooling time.
Something I don't see in your list is fueling and ability to tune. I'd consider that strongly before I took the plunge on a forced induction system. It's something I would definitely have in order before I started bolting a boost generating device on.
Drac said pretty much what I was going to, with one addition...
There's really not such a thing as budget forced induction--those corners you have to cut to keep costs down usually mean picking up the engine with a broom sooner or later, accompanied by sharp, stabbing pains around the wallet.
[QUOTE=cheesehomer;5970649]
Thanks George Eh sorta. Imo, You want turbo to spool near peak trq rpm and carry strong without restriction to shift rpm. You'd use a trq converter that stalls near peak trq as well. This will be a strong running combo at the track but also street.
Some guys for street only may like quick spool and more instant response. Tend to size slightly smaller and then see some restriction at high rpms aka backpressure.
My t70 rear mount was spooling 2 psi by 2300 rpm stock 305 motor. With cat converter still on. When i gutted that it ruined exhUst flow and heat now doesnt spool til alot later but wot downshift it goes to 5-6 psi instantly and within a second goes to set level of 10. I will be straight piping the cat area and see if i cant get that back
Thanks George
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
1 Post
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
One of the most important things here is picking the right combos. My car with a 3000rpm stall, 3.23 gears, and the turbonetics 62-1 (1.0 exhaust housing) I had was a killer combo. That was a combo that was hard to beat on the street. But with my build, I was maxing the turbo out. Im actually really surprised it made the power it did with that little turbo. I honestly think the 62-1 or similar sized other turbo with a 2800-3000 stall is ideal for stockish TPI cars. Just my experience tho.
COTM Editor (Retired)
why go "rear-mount" or "remote-mount" vs. "front mount?"
seems like it might enable you to keep your headers intact, but i can't think of a logical place outside of the engine bay to install a turbo on a Third Gen.
Car: 1987 Iroc Vert
Transmission: 5 spd
How much of a difference would there be for a 5spd with the same combo ?
Getting cold side past engine k member also can be alittle tricky.
But nothing in engine bay needs changed. Rad stays same, ac stays there, all emissions stuff, coolant reservoir etc. all stays same as stock. Getting turbo up front can be alittle more difficult
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Its the easiest place to mount a turbo. By rear tire frame rail, you can keep stock manifolds and exhaust or shorty headers and oem style catback/ypipe and run it to turbo. Very little fabrication involved on hotside. But you do have to have a good bit of cold piping and also oil scavenge pump which isnt cheap.
-- Joe
if i'm not mistaken, you are doing this on a Camaro, right?
how are you fabricating it? and how is your progress?
Lol its been done and running. Just not quite making the power i estimated yet but i need to regap the plugs, wrap the exhaust and straight pipe the cat, and retune. Cold side hangs touch lower than i like for the roads around here and i do plan on rerouting it but for now its working great.
Car: 92 Z28 Camaro
Engine: 355 TPI
Thanks for the replies guys, and I actually did ask about the fueling in my second post, but I completely see what you guys are saying about there not really being such a thing as a budget setup without risking more expensive things later on. However $1500 to $1700 doesn't really seem to steep at all for the power that will be gained, especially seeing as a procharger will run you $5k or better.
I think for under $1200 the Chinese single turbo stuff works fine for a L98. The only reason I had to modify mine was the afr heads. It fit stock beads fine.
Yeah i guess if you the china single turbo manifold which i am not a fan of. I dont like how the crossover tube joins and dont like the wastegate tube location.
But its not always the major parts that add up. Silicone couplers and tbolts can be couple hundred bucks depending how you run hotside lol. Vbands, oil lines, etc.
My rear mount i have maybe 1600 into it with a stock motor and exhaust. Could easily grow with more fabrication
The hotside/turbo/waste-gate and intercooler/bov are the cheap (using Chinese parts) and easy parts of a turbo build.
Beyond that, on a well built setup you will spend more on the supporting systems like fuel, heat control wraps/blankets/coatings, various lines, battery relocation, intake/filter, crank case evac, tuning gear, fittings, flanges, bolts, gaskets, sensors, couplings, than you will on the turbo setup. I learned this lesson when I built my car the first time, I finished the "turbo kit" and started it up, only to realize I was only half way done!
It seems like a lot of people seem to miss the fact that the only reason turbos are "cheap" is the hot-side/waste-gate/turbo/tubing can be fairly inexpensive and built without to much fuss. Once you get that sorted out you realized how much more you still have to do to make it run "right". Sure it can be done really cheap, especially if you have experience and access to tools and a shop with spares/scraps laying around - but that's not going to happen on your first attempt at it.
Orr is a great example of this, he has a built, 8 second turbo third gen and a rear mount 305 that he built after he built the 8 second car. Starting with a bone stock car in good shape, he has tons of experience building turbo third gens and is in it $1700 with a rear mount (not counting the tuning gear), and he's the first to say it's not really done yet, he's still fighting the little things.
I think a $2500-$3000 budget is a good starting point if you plan on going with a low budget setup for a stock car.
8psi with an intercooler sounds awfully anemic.
-- Joe
Math works out to closer to 100 hp on 8 psi but if motor is tired and old, it may not like the boost and suffer some blowby losses. May not make the power.
I still need to play with my 305 to verify how much power it makes with 9-10 psi. It clearly aint making what theoretical numbers say it should
Car: 88 Iroc. 12.60@ 107. 1.72 60'
Engine: 350 paxton sn93 36lbs injectors
Axle/Gears: 9in. 390s
my 350 is forged bottom end but still standard bore. stock tpi with l98 heads they have been ported and with 2.00 valves though. cam is small .470/.490.old slp grind 36lbs. injectors. the paxton pushes only 5-6 psi @ wot no intercooler but 50/50 meth. ive went few 12.60s and alot of 70s. never dynod but the car weighs 3570 with no one in it. ive used online calculaters and they estimated around 430 flywheel and 350 at the wheels. it has the right gears in it just needs more converter as it sits. just to give a comparison. mabey it will help out. i figure N/A the motors around 300 or so at the flywheel.
jonarotz
10-16-2015 09:51 PM
