Going from a single turbo to twins
Old 11-25-2015, 05:31 AM
  #101
jimw67's Avatar
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
Re: Going from a single turbo to twins
Nice build, looks like fun and a challenge - good luck.
Regarding the catch cans. We're running a single AllStar Perf., that is about identical to the Moroso's you bought, and a check valved PCV. The catch can is piped to a JY electric emissions pump that I reversed the direction of. It turns on when in boost and runs for 5 seconds after out of boost. We ran it all summer for more than 5000 miles with no issues, no oil in the intake and no engine oil leaks. I'm triggering the pump via an MS2, but the same exact thing could be accomplishished with a simple/low budget Hobbs switch and relay. We haven't drained a pint of oil out of it total after a full season of driving. Most of the summer was at 10 psi and we turned it up to 14 psi for the last part of the season.
My two cents, throw them out if needed - lol. Good luck - Jim
Old 11-25-2015, 07:57 AM
  #102
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Originally Posted by customblackbird
was it the one I posted? I hope you didn't pay more than $101 lol. Ive seen it as low as $92-98 and free shipping and almost pulled the trigger. But decided I wanted a a 2 speed single fan.
Yeah pretty much the same thing.
Old 11-25-2015, 07:58 AM
  #103
Thanks I will keep that in mind.
Old 11-26-2015, 06:00 PM
  #104
Not much to report past two days. Still trying to figure out what ill do for down pipes. Either fender exits or under the k member by the control arms..........
Old 11-27-2015, 08:54 PM
  #105
Think I have my upper radiator hose figured out.
Old 11-28-2015, 05:08 PM
  #106
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
That's still close..
-- Joe
Old 11-29-2015, 09:17 PM
  #107
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
That's plenty of space especially if the exhaust is wrapped
Any new ideas on your downpipes?
Old 11-29-2015, 09:20 PM
  #108
Going to be going the fender exhaust route after looking at every possible thing today. Going to be coming out at the lower chin spoiler on the sides of the fender. I have no other choice and since the car isn't my daily driver I'm content with that.
Old 11-29-2015, 09:21 PM
  #109
Once all the exhaust is done and all welded up it will be coming off and sent out to be coated.
Old 11-29-2015, 10:28 PM
  #110
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I think the hose will be ok. You might want to look for a silicone version of the one you have. Only because it will last a lot longer when exposed to heat. OEM rubber is only good till like 300* or something… silicone is good for like 450+*
Old 11-29-2015, 10:56 PM
  #111
I will keep an eye out for one. Not sure I will be able to find one. If anyone happens to come across one please let me know. Thank you
Old 11-30-2015, 10:38 PM
  #112
I received my flanges and clamps today. For now I have only tacked on the start of the down pipes. Waiting for my fans before I finish welding the first half up.
Old 11-30-2015, 10:49 PM
  #113
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Mines closer and has been fine. Its autozone type universial hose with the spiral wire core
Old 11-30-2015, 10:53 PM
  #114
As long as it works . As for the exhaust I will have to see how loud it is. I don't think it will be too loud with the .68 a/r exhaust housings.
Old 11-30-2015, 11:27 PM
  #115
Car: 87 TA clone
Idk your hose application. But look up the make/model and see what's out there for silicone hose applications. I think you would be fine if you coat or wrap the bend.
Those bump pipes look real lose to the rad. I would wait for the fans before going any further remember the fans at the motor are like 4.5" deep so around the fan blade supports is probably like 3.5" from the rad surface if you mount it that close.
Old 12-01-2015, 07:04 AM
  #116
Yeah , that it the plan with the down pipes. The fans will be in today and once I get home I can put those in place and see exactly where I need to route the piping.
Old 12-02-2015, 12:04 AM
  #117
I have the cooling fans in place and the first part of the down pipes tacked up
Old 12-02-2015, 12:06 AM
  #118
Here is the other side. It looks closer than what you see here but it's fine.
Old 12-02-2015, 04:13 PM
  #119
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
have you considered running the DPs like this?
you will have to dodge the fans obviously and I just show a straight shot, but if you merge the two 3" pipes into a 5 (or 4), then reduce down to 4" when you have to duck under the heater box and header it should fit no problem.
Old 12-02-2015, 08:23 PM
  #120
Yes I have but I don't want to create a restriction by merging the two 3" pipes to a single 3". Then out to the 4" cat back. I don't have room for a 4" pipe in the engine bay either.
Old 12-02-2015, 09:40 PM
  #121
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Are your headers in the way of the 4"?
I was under th impression that the only tight spot with a 4" dp is by the a/c box and you just run the heater box
This is a 3" pipe going under a modified a/c box, surely a 4" could squeeze in there?
Old 12-02-2015, 10:42 PM
  #122
Car: 87 TA clone
Where you able to test the fans and see how much air they pull? They look pretty decent.
Fender exhaust exits would be interesting lol… but loud even with the turbos. Not to mention any cop could give you a ticket for not running exhaust to the rear bumper. They got me for that, as well as being too "loud" by issuing a noise complaint at a check point. That happened a few times lol. I would get sick of the sound bouncing off everything and kicking right into your ears/face. I had turndowns before the axle and the sound kicking back off dividers would get old real quick lol and those turndowns were behind me. I think the turbos do a good job of killing the noise but its still not going to be fun with them in the fenders.
No way to do a dual 3" into a 4" and run it back? I run one now for my 4" catback and the flow difference isn't really noticeable, its very close in CFM but the 4" wins in the "less surface friction" so its basically even. The only issue with the 4" flowmaster merge is the length. But it can be shortened a lot.
Old 12-02-2015, 11:42 PM
  #123
Unfortunately I do not have room along the sub frame near the header to run that size of a pipe. I might be able to get away with 3.5 " but that's pushing it too. I still want to access my spark plugs if need be as well as replace a blown out header gasket easily if I have to. My heater box is modified as well but I would rather the extra room.
Old 12-02-2015, 11:48 PM
  #124
I have not tested the fans yet but I've read a lot of people are using them with good luck.
As for the fender exits and the police as much as I drive my car I'm not worried too much about it. I have a few good "friends" so if something does happen I am all set.
No room to run dual 3" to a 4" merge either. I would've been better off doing a 2.5" dual to a 4" merge but I did not feel like sending back the 3" tubing kit that I bought from www.mandrelbends.com with an extra 10% off.
So I just sucked it up and decided to deal with using the 3" tubing as well as purchasing two Vibrant resonators to help cut down the sound. I don't think it will be too loud anyways especially with the .68 exh ar on the turbos.
Old 12-02-2015, 11:58 PM
  #125
I'll post a few pictures of the driver side almost done.
Old 12-02-2015, 11:59 PM
  #126
Another
Old 12-03-2015, 12:00 AM
  #127
Just have to trim a little off and install the waste gate and the the driver side is finished.
Old 12-03-2015, 06:56 AM
  #128
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Looks good!
Old 12-03-2015, 07:24 AM
  #129
anesthes's Avatar
That's gonna be loud.
-- Joe
Old 12-03-2015, 07:27 AM
  #130
We will find out when the time comes lol
Old 12-03-2015, 09:51 AM
  #131
anesthes's Avatar
Depends on the state. I work in Mass and it's pretty strict. I can cite you for using an autozone replacement muffler if it's louder than stock.
In New Hampshire where I live, you can run side pipes that exit before the rear axle, as long as heat shields are in place. You still need a proper muffler, but the state understands the difference between a high HP muscle car, and an idiot who cut his exhaust off to be cool.
-- Joe
Old 12-03-2015, 09:59 AM
  #132
Yeah...Mass is pretty strict.
Old 12-06-2015, 05:31 PM
  #133
Not much progress this week . Have too much going on so I've been busy. I did manage to get the waste gates in place where I want them. I put them up front so I can remove the down pipes if necessary.
Old 12-06-2015, 07:59 PM
  #134
jimw67's Avatar
-- Joe
Hey, hey, hey, do you still consider them idiots if the exhaust wasn't there whenthey bought the car - hehe. It's more fun if it dumps before the rear axle anyway
Old 12-06-2015, 08:01 PM
  #135
jimw67's Avatar
Have you considered running 4" oval pipe. Obviously it doesn't have the flow capacity of 4" but it should surpass 3.5" and if memoryserves me correctly, it is only 3" on the short dimension.
Old 12-06-2015, 10:32 PM
  #136
Yeah I have thought about it but it would still be a pita. If I think it's too loud then I will do something about bringing the exhaust back to the rear of the car. Time will tell with this one anyways. i could always do two 2.5" down pipes and merge it into the 4". I'll know more come spring time when I can actually drive the car.
Old 12-07-2015, 06:42 AM
  #137
anesthes's Avatar
Guys with stock cars and very loud exhaust drive me nuts.
I get it if you have a 500+ hp car, and a reasonable exhaust tone.
But if you have a 150hp crap box and it's pushing 150 decibels you should be executed
-- Joe
Old 12-07-2015, 07:09 AM
  #138
-- Joe
Old 12-07-2015, 07:10 AM
  #139
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats $$$$
Old 12-07-2015, 09:44 AM
  #140
Thats $$$$
Indeed it is
Old 12-07-2015, 08:08 PM
  #141
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Coming along great! I wouldnt worry much about the upper rad hose. just double or triple wrap that section. I have seen turbine hosings closer to a rad that that.
Jay
Old 12-07-2015, 10:29 PM
  #142
Jay
Thanks. I plan on having the hot side coated once finished. On another note I managed to get the driver side all finished and half of the passenger side done before I ran out of mig welding wire. Thank god I have a spare roll at work that I will grab tomorrow.
The next part will be a pita as well....running the cold side.
Old 12-07-2015, 10:30 PM
  #143
Here's another view.
Old 12-08-2015, 11:30 PM
  #144
Loaded up the welder with a roll of new wire. Hot side is now finished. Now to take everything off and send it out to be coated. Then work on the cold side. With I could run 14 psi with no intercooler or meth.
Old 12-09-2015, 06:25 AM
  #145
anesthes's Avatar
Welding over oil stained cardboard?
-- Joe
Old 12-09-2015, 07:09 AM
  #146
Lol I was waiting for someone to comment about that.. Yeah its old card board that has been soaked in water before it went under the car. no chance of it going up in flames even though I only tacked in the pieces and took them off and up to the front of the garage to weld them together.
Old 12-10-2015, 08:47 PM
  #147
Choices. Methanol or intercooler........
Old 12-10-2015, 09:59 PM
  #148
anesthes's Avatar
Intercooler. Turbos generate a lot of heat.
-- Joe
Old 12-10-2015, 10:49 PM
  #149
I have one here but may need to sell it to get a different one . The one I'm looking at online has two inlets and one outlet. The outlet exits the middle of the unit.
Old 12-11-2015, 07:27 AM
  #150
anesthes's Avatar
Why not run two atw cores ? A lot of new OEM cars are moving to ATW intercoolers. Much higher cooling efficiency.
-- Joe
Quick Reply: Going from a single turbo to twins
