Vortech TPI kit with Wobbling crank pulley
Old 09-13-2016, 05:22 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
I have a Vortech supercharger kit i bought complete minus the spacer for the crank pulley. I used some spacers for the bolts and it wobbled enough to cause an engine vibration throughout the rpm range. Once i traced this down i scrapped the homemade spacer idea. Any ideas on getting a 1 1/8" spacer to go between the pulleys? I attached some pics of the current setup.
Old 09-13-2016, 07:49 PM
Street Lethal's Avatar
Re: Vortech TPI kit with Wobbling crank pulley
Cut a piece of cardboard in the shape that you need along with the bolt holes and snout area, get yourself a small 1 1/8" steel plate, place the cardboard on the plate, mark the diameter of the spacer on the plate, mark the holes, and have someone cut/drill it for you...
Old 09-13-2016, 08:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
call vortech and buy the spacer?
Old 09-13-2016, 08:58 PM
Johnny*G's Avatar
Car: 1987 Trans Am
They said it was discontinued...which is odd because you think there would be one laying around. I guess i will contact Alumifab in Denver and have them make me one. Didnt know if anyone had run across a similar part from another supercharger company
Old 09-13-2016, 09:00 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Yep i am scrounging a cereal box as we speak. headed to the aluminum machine shop tomorrow. Thanks for the idea!
Old 09-13-2016, 09:06 PM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
It's not available anymore. The TPI kit used a odd thickness spacer, probably because they were worried about the crank pulley hitting the fan on single fan cars. The TPI crank spacer is #4GB017-041
The SBC kit uses two different spacers, one for vbelt and one for serpentine. The Vbelt spacer is #4GP017-041 (3.293") and the serpentine spacer is #4GP017-031 (3.695")
If the pulley is not hub centric on both ends he will break the crank snout off.
Mine measures 1.63", I just checked it when I took those pictures.
The reason these are no longer available, is Vortech standardized on the larger hub size used on the 6" aluminum crank pulleys (like the 10 rib). These older style spacers are meant to be used with stamped steel pulleys.
No, I won't sell mine. It's like a unicorn at this point, I'll probably never see another one
-- Joe
Old 09-13-2016, 11:47 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Wow, great info! Hope this research helps someone else too. Hey is it possible to get the other dimensions off that spacer? Thanks Joe
Old 09-14-2016, 05:43 AM
TTOP350's Avatar
Since you have one, it should be fairly easy and cheap to have copied.
Old 09-14-2016, 06:55 AM
anesthes's Avatar
Yup. I could turn one on my lathe if I really needed to.
I can measure the hubs for him and he can have a machine shop whip one out. If it cost more than $100 I'd be surprised.
-- Joe
Old 09-14-2016, 09:44 AM
Johnny*G's Avatar
Car: 1987 Trans Am
-- Joe
Thank you Joe! Yea if you have time to check the dimensions that would be great!
Old 09-14-2016, 09:58 AM
Joe is just teasing you, I am sure he will help you more than just measuring it.
... don't be surprised if he already made it for you.
Old 09-14-2016, 11:11 AM
Johnny*G's Avatar
Car: 1987 Trans Am
HAHAHA!! oh jeez! didn't even catch that! I actually had a customer offer to spin this up for me, but thanks for the offer!
Old 09-14-2016, 02:48 PM
TTOP350's Avatar
Anyone else feel that? All the warm and fuzzies going on..
Old 09-14-2016, 06:20 PM
Johnny*G's Avatar
Car: 1987 Trans Am
it is good to have everyone on here sharing knowledge....its better than the alternative
Old 09-14-2016, 07:16 PM
anesthes's Avatar
You are running the wrong crank pulley by the way. You should have two stock 7.5" GM crank pulleys.
Anyway, here goes:
Old 09-14-2016, 07:20 PM
anesthes's Avatar
If my lathe wasn't an epic POS I'd spin one out for him. My tool post has too much backlash, and I need a new chuck.
-- Joe
Haha, it wasn't sarcasm on my part, I was being serious.
Glad you're getting it done though...
Old 09-14-2016, 07:22 PM
-- Joe
I know, that's why I said that, we're very similar that way.
... you must be Italian.
Old 09-14-2016, 07:31 PM
anesthes's Avatar
Sicilian Republican from Boston.
-- Joe
Old 09-16-2016, 03:09 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Thanks again for all the help Joe!!
Macarchie
08-21-2018 08:34 PM
maks10
06-28-2017 04:03 AM
-=Z28=-
11-07-2016 10:59 AM
Truckin1999
09-30-2016 08:10 PM
QwkTrip
09-13-2016 06:57 PM
Quick Reply: Vortech TPI kit with Wobbling crank pulley
