Putting a supercharger on a mass airflow car
Old 09-25-2016, 12:19 PM
cougar20th's Avatar
Car: Black 88 Iroc Convertable
Seems what I remember its perfered to use a car with.a map sensor instead of a mass airflow when supercharging. Am I correct or getting mixed up?
If I can use a mass airflow do I just put the sensor on the inletside of the charger?
Old 09-26-2016, 10:03 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Putting a supercharger on a mass airflow car
On my sn2000 paxton its on the inlet side
Old 09-26-2016, 10:05 AM
cougar20th's Avatar
Thanks, that makes sense. the more I think about it the more I think im getting confused between ford,chevy.
Old 09-26-2016, 10:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Ideally you want it on the outlet side to measure air mass and do the fueling. If not using an fmu or some hybrid efi system where fuel is added via map sensor. Problem is stock tpi sensors practically max out around 280-300 whp so you dont get much room for fueling, however if boost curve is linear enough like in centrifugal blowers for the most part, you can add fuel via power enrichment vs rpm table in stock code
Old 09-26-2016, 10:35 AM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
My setup is on the outlet side of Supercharger.
Old 09-27-2016, 02:44 PM
cougar20th's Avatar
Thank you that picture explains alot.
Old 09-29-2016, 03:40 PM
t/aws61985's Avatar
Car: 85-6 TA 85IROC 82-6 MSE 15th/83pace
Engine: Slow ones
Transmission: 700R4/T5
Axle/Gears: Weak ones
What did you have to do to that 305 for it to handle the super charger
Old 09-29-2016, 03:52 PM
IrocZonNos's Avatar
Stock 305 with the usual bolt on's headers,exhaust etc...
In fact only 60k original miles without ever taking off heads.
Old 09-29-2016, 03:56 PM
t/aws61985's Avatar
Engine: Slow ones
I really want to do a supercharger on my TPI, but I don't want to well, blow my engine up. I have done some research here and there over the years and alot of people say the factory tpi can't handle the power of a supercharger. What did you do to your fuel system to accommodate the supercharger?
Old 09-30-2016, 12:38 AM
Twin_Turbo's Avatar
booster pump or better fuel pump.
As for MAF....
Old 09-30-2016, 07:14 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Be realistic with boost and limit it to 6-8lbs and you will have years of fun with it.
Old 09-30-2016, 07:37 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup 7-9 psi will be on par with a bolt on ls1 fbody as far as performance goes
Only things you need to do is give it fuel and pull some timing. Depends how you set it up whether you want fmu or a 2-3 bar map based system or a larger maf like blowerworks
Simplest easiest would be an fmu and get new injectors. High pressure walbro fuel pump is fine.
Only other thing i'd recommend is fresh valvesprings
Old 09-30-2016, 08:28 AM
cougar20th's Avatar
I figured for my project I would need to keep it to under 10 psi into my stock 305 tpi. I also plan on a superram.
My plan is some kit like the vortech one or other. But finding them is a pain.
What approx value on a complete kit. Im figuring $1.5k from what ive seen.
Old 10-05-2016, 12:16 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 305 Tpi
Transmission: T5 Manual
Hey if you find any for that amount, let me know - I will buy 10!!
More like $4k. Then there is the amazing amount of stuff you won't have budgeted for: new, bigger fuel pump, new injectors, chip, transmission upgrade, Boost retard box etc.
It is a lot of work and very expensive BUT worthwhile. Just.
Old 10-07-2016, 07:52 PM
cougar20th's Avatar
I've seen the vortech kits between $1400 -$2000. Mostly complete with btm, pump. Still would need to tune it.
For now im just looking and planning again. That and waiting for money to come in.
Old 10-09-2016, 10:35 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 305 Tpi
Yeah, for some reason i was just thinking procharger kits
Old 10-14-2016, 10:11 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Bought my Vortech S-Trim kit new in 1997. 5.0-5.7 TPI same kit. Now discontinued. $2700. Kit was for a stock TPI engine. Many mods later it is still on the car. Going strong, never had a problem with the supercharger.
Old 10-16-2016, 12:10 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
You can use MAF or SD for boost. SD or MAP is just easier. You don't have to worry about getting the MAF installed in the charge pipe. Don't have to worry about location to a BOV or meth nozzle etc. Then you have to worry about the max flow of the MAF and what it can handle. This is why I went SD and it's been great. MAF is more accurate at reading actual airflow and proper fueling, SD is based off tables and the engine is guessing due to sensor input and pulling from the tables.
Good luck finding a kit for 2k with everything you need. I've seen some used kits go for like 2k but they are far from complete and the TPI is different than a cheap carb application.
Swap pump, injectors, tune, other fuel system components like fun, or boost referenced regulator and set it at 6-8psi and enjoy. You should always swap valve springs as your now fighting the charge intake pressure. Hope your exhaust is up to
Sniff with getting rid of all the added exhaust/power.
Bald_eagle_machine
10-26-2016 11:25 PM
RABMAN
09-25-2016 10:44 AM
Goumba T
09-25-2016 08:35 AM
BOTTLEDZ28
09-19-2016 02:57 PM
dpmalibu
09-18-2016 11:42 PM
Quick Reply: Putting a supercharger on a mass airflow car
