Supercharger help!
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Supercharger help!
Does something like this exist for sbc? Im looking for a blower specificly efi that is fed air through the front or back but i still need to fit my distributor, i have looked high and low on the internet and cant find anything, if anyone has one they are selling or knows where to get one please let me know
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Supercharger help!
I'm surprised nobody responded to this.
I'd buy one of these for SBC if available. I could ditch my FMIC and mile of intake tubing in favor of a small heat exchanger (most of them are water cooled).
The supercharged ford stuff is pretty impressive. Can't believe I'm saying that, but yeah, I wish someone made one of these for SBC.
A 6.0 swap with a mild cam and blower would make great reliable horsepower in a street car.
-- Joe
-- Joe
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I thought about doing an ls swap just to beable to get a blower like that but its really not my thing, id much rather build a 383 and put one of these on it, i called magnasun and it aparently doesnt exist, but the post with the one being fed air from the rear was on here someone was installing it on an scb in 2009
I'd think anything smaller than a 177cid wouldn't make much power on a v8 without spinning the crap out of it.
-- Joe
they do but its custom job and expensive
Whipple 305 series blower which has 6-71 style bolt pattern. You can buy the rear entry style throttle body. Not sure if it clears the distributor. May have to go 24x cam sync style efi to delete the dizzy and put cam sensor on the timing cover
Get a blower shop b-7104 base manifold and use the nozzle tap locations for custom injector bungs. Thats the custom fab part
Then they bolt together.
Its easier if you have a bbc lol they sell a whipple lower intercooled and injected base. Very popular in the marine world
Mangacharger made a MP-112 in 2007 that had a SBC EFI lower. I've found a number of pictures and magazine reviews on it, but can't seem to find any people who actually bought it. Sounds like they did a lot of marketing but then never went into production.
I don't know much about the eaton blowers, but I know edelbrock and others make a SBC MP-112/122 lower manifold. The blower itself is carb.
Couldn't one put an EFI MP-112/122 upper on a SBC lower and just weld injector bungs? Or is the bolt pattern for the case different depending on the application?
I don't know how much power you can make with those little boys, I think they would be done by 500-525hp, but I guess it would wake up a mild 350?
If I cooked my 412 I'd probably just get a junkyard 6.0, do a cam and a maganacharger. I bet it would make the same power and idle better.
-- Joe
Depends on what the goals are of the builder. OEM switched to these eaton based superchargers be
The MP112 is around 60%, where your V3 is 78%. The MP112 is 820cfm where your V3 is around 1100.
But then again the water intercooler is more efficient than no intercooler, or an air/air
Depends on what you wanna do.
-- Joe
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
They are very compact, i will give you that. I wonder if they will ever switch to centrifugal that mounts in a OE style bracket.
Centrifugal makes more power, efficient power, but the packaging is sometimes tough.
-- Joe
