[NJ] WTB 3 series 9 bolt carrier
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Looking for a 3 series carrier. Worn out is OK, just no gouges in the cone area or the bearing/mating surfaces
Re: WTB 3 series 9 bolt carrier
I've got a used 3 series 9-bolt carrier. The cones look bottomed out so it will need the cones shimmed or new cones. I viewed the cones thru the "window",... The carrier has never been disassembled. Originally had 3.45 gears on it; $75 + shipping. ( sorry - no gears to offer ) If your interested then post your ZIP code and I'll use it to get a shipping quote.
FYI: This carrier will *JUST* fit inside a USPS medium flat rate package. By that I mean I can close the box and the box touches the carrier with no padding. For this reason I suggest ground shipping so a slightly larger box can be used. Might cost a little more than flat rate - but it will allow for the carrier to be better protected when shipped.
