Opening Fabrication/Powder Coat Shop (Spring)
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Hey yall,
Opening a fabrication and powder coat shop. I have been wanting to go for a while.
Most of it will be turbo fabrication. I was a fabricator/tech at a diesel business. Have much experience with turbocharged applications. Also we will be be powder coating our own products in house.
Turbo kits will range from basic mild steel and exhaust manifolds to full blown tubular stainless. I alredy make a nice kit for LS Vortec trucks thst keep all emmision equipment
Have 2 running examples now. both over 500rwhp on stock longblocks. Been getting some demand for them on truck forums.
Also will offer LS swaps for any vehicles. I currently make accessory drive parts for LS motors made from billet 6061 material,CNC made.
Will offer many other services also.
Just throwing it out there for fellow TGO folks. Fair pricing and quick turnarounf.
Still in process of getting all of my equipment together. Will be openimg soon since i alredy have some work lined up.
My shop car is a 1991 Camaro with 410ci LS motor, TH400, Moser 12bolt and a **** load of boost
Los
Los
Car: 02 SS
Re: Opening Fabrication/Powder Coat Shop (Spring)
apologize for spelling errors. fat finger, small keys phone.
Car: 02 SS
swaps are more of a case by case basis. currently ive performed a total of 10 swaps. 3 in 3rd gens.
so im pretty familiar with obstacles.
i can provide engine and transmissions,harness etc.
depends what customer is interested in having built.
basic swap 5.3 or tt 408, etc. priced accordingly. but based on labor hour rates
some fabrication is set prices.
also looking to bring in a guy that builds race type transmissions. he is interested in coming back home to houston. so may offer that as well if goes as planned.
Car: 02 SS
i have my first piece of work.
airbag,brake chambers,shocks and pm on a mack truck. a big rig.
and r/r engine trans in a 4th gen.
Car: 02 SS
the coated parts have to sit in a oven for a period of time. after receiving the coat of powder. its basically very fine plastic powder. some are more coarse than others if they have metallic or texture in them.
cant really say if they will hold up if they dont get baked.
ive been baking em all and the demand just got too high for me to keep doing it at home.
i am putting together my 6x6x6 oven and a smaller one for smaller parts.
was coating all the cold side parts and flanges my uncle uses in his business.
to have correct results, the part coated needs to sit in an oven for a while.
you can actually do it home w a diy kit. but still need an electric oven to finish part.
got the bigger oven so i can do wheels and other big parts.
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
Car: 02 SS
lookin to get a vertical mill for the shop. i make the parts at my soon to b former place of employment. contract machine shop.
but prolly get me a bridgeport to hold me over for a while.
im not the worst at cutting metal
hmu if interested.
hmu if interested.
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Sounds like you will have some good stuff going on over at your shop. I would like to stop by and check out your operation once you are up and running.
BTW, I noticed your '91 has a TH400?
I have a TH400 in my '82 and am considering either a T56 or possibly a 4L80E.
One of my concerns is that I would prefer to keep my carbon fiber drive shaft if possible. Do you know the relative drive shaft requirements for these transmissions?
Thanks,
Thanks,
Car: 02 SS
sure thing man. shop is welcome to any fellow tgo members. im alredy used to 12+ hr workdays. so im gonna b open later hours and saturdays. maybe have an open shop day a sunday every now and then.
im getting alot of interest from my ls1tech folk. been working on tech members rides and selln stuff on there for years. with a good strong rep.
i have chart i got off some site w most of the gm rwd trans. but i couldnt tell u off the top of my head. i gotta go look it up.
im gonna have to cut my old th350 shaft and replace the yoke for th400 shaft.
but i can see how u would want to keep the cf shaft. not as easy to just take to local ds shop to have modded.
since im using 1.5+ setback mounts w the ls motor in my car. around the headers im using and no way any factory trans xmember fits. im gonna have to make a "drop" type tubular one on my car that ties into the sfc i also have to make. also looking into making a cross bar mount point for the tq arm instead of tunnel mount.
with the th350 i was able use the b&m trans mount bracket and stock tq arm.
I also have a little expirience gluing metal back together with electricity on my resume, hopefully ill get to check out your shop sometime.
Car: 02 SS
any one in houston area looking to get a basic turbo set on there car?
im looking to develop a basic easy to install turbo kit for sbc 3rd gens. basic means essentials. i wont install at my place any ebay turbo,wastegates or bov. only thing i use from ebay are a/a fmic.
but i can build around those size turbos and wg.
im in the process of becoming a turbonetics and hks dealer. gonna use them because of the warranties and proven performance. plus its my fave brand of turbos and i know for a fact they work.
basic means vband mild steel hot side. mild steel cold side w silicone couplers and tbolt clamps. a/a fmic. oil feed/return lines for single turbo. 3in mild steel downpipe w 02 bung
keeps a/c. need to replace factory overflow w smaller one. few other misc. mods needed but nothing invasive.
ive alredy done a turbo ls 3rd gen. but thats different because of the mounts used. too many motor mounts used. none are the same like on a sbc car. whole nother deal.
of course would b to lowered price to a member who is interested. would need to keep the car in the shop to get it started and finished asap.
i dont like cars and parts sitting around. lol
Los
Los
Just buy my car from the classifieds and have at it. :-D
Car: 02 SS
i had to thin out the herd at home.lol
just kept my 02ss and my 68 c10. not too attached to the 91 rs. but using it for the ls swap stuff.
sold an 85 chevy truck and a 00 ws6 trans am.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Wish I had the spare cash, would have you help me start a 4.8 liter of doom turbo project in a third gen or fox.
Car: 02 SS
aww come on zane.
u always welcome. i will alwYs help u out if i can. can use any tool i have.
get a ebay gt45 and build u blo thru carb and let it eat. theres a kroger down the street that has e85. so im gonna keep a drum or 2 of it.
also alredy started researching the nitrous refill station. prolly wont make much off it. but will bring ppl in and maybe lead to other services.
i just wont install the ebay stuff cuz they have no warranty and the tnetics does
Engine: 377
Transmission: 400
Blow-through huh?
What do you think it would take to build a blow through setup with my 900cfm Pro-Jection TBI?
What parts would be needed?
Car: Faster
Engine: Than
Transmission: You!
ESC - ....bigger injectors, possibly a bigger fuel pump, and ALOT of tuning with a wide-band
Disclaimer, yes I know this is off subject If 3rd gen F-bodies but since we're on the subject of a local speed/fab shop and in the good sport of hot rodding and looking for more power....
I have something to bench race with y'all and maybe get a rough estimate on what it would cost. I just picked up a 4wd Kia... Yes I said Kia. :-D Sportage. I haven't done any serious off-roading in a few years other than my 4wheeler so this is a quick cheap way back into my original hobby.
It has a puny little 2.0 that is basically a larger CI Miata engine. I'm not sure if I'll even bother with registering and street driving it but good fuel mileage and a smoother ride than my truck make it likely if I don't completely destroy it.
Either way, on or off-road, guarantee I'm going to want/need more power eventually and I think a turbo would be the thing to do. Feel free to give me other ideas for it.
So after all that long-winded crap, what could I expect throwing a turbo at the four inline squirrels to cost vs what kind of power output coul expected? & no, I won't be doing a V8 swap anytime soon, this is meant to stay CHEEEEEAP, lightweight and not break anything.
Engine: 377
Transmission: 400
Either way, I would probably also install the Mega Squirt I built. It has a feature to allow for the use of dissimilar injectors in stages. It also has a neat feature that will blend in some NO2 while you are waiting for the boost to build.
I think I have the fuel pump situation pretty well in hand with dual, inline Walbro 255's. Right now, the second is on a window switch so that it won't overwhelm my puny return line at idle.
Engine: 377
Transmission: 400
You can get an Eaton blower, good for about 6-8 psi, starting at $2500.
If it were me, I would probably get the Eaton because it is so easy to install, or go plumb it for wet port injection NO2.
Cool, I really want my next on road toy to be a Miata (even though I barely fit!) It would become a death-rocket with some kind of LS-nastiness. :-D
If you trust wiki: Mazda FE
I definitely wouldn't be spending that kind of money on it. I only paid $600 for the thing. I was thinking some kind of cheapo parts & self fab as much as possible with guidance and a little help from a pro as needed. You know if any good ways to squeeze more power out of that engine cheaply for now?
& last thing. The transmission had broke and only has 4th gear. I pulled it out this morning and next I'm either going to tear into it, take it to a trans shop or just junkyard source a new one. Any pointers to what it could be or how hard to fix? The lady said it lurched ahead while driving, then would only go into 4th & she parked it. It will actually shift through the pattern but only engages 4th but acts like it has no synchro.
I'm only asking here because I trust y'all as gearheads vs people on Kia forum I have been searching the last couple days. They seem at their limits beyond bolt ons & maintenance. (makes sence because what car enthusiast desires a Kia... Something is wrong with me. :-D )
If you trust wiki:
The rest of the world received the FE-DOHC in the 1995–2003 Kia Sportage, built by Kia under license. Kia first introduced the engine in March 1992, when they installed it in the Kia Concord, a license built version of the 1982 Mazda Capella. The Sportage variant was reconfigured for rear-wheel drive configuration with long single-runner intake manifold, low-duration cams and exclusively in the low compression ratio of 9.2:1.
Car: 02 SS
im using microsquirt in my own car. w 75lb. injectors. and dual bosch 040 i.tanks in a 4th gen tank.
Car: 02 SS
bronco,
imo i would use a totota ct26 turbo. internally wastegated. turbo that will make some hp. very common and cheap. easy to find. they came off celicas/supra and other toyota cars.
ive used one back in the day on a 95 5spd v6 camaro. used a 10:1 fmu. some old 36lb. injectors i got from jy from a sc bonneville. it ran good for about a week on stock tune. and then i started messing w the wgs and it went boom. lol
i did have a inline pump i got from jegs also. didnt even have a boost gage.
if u wanted to stay cheap. get one of those turbos. they are tiny so they fit anywhere.
alot of rebuild parts and upgrades for them.
and use a fmu and also plumb a sprayer strait into the turbo compressor inlet. w a hobbs switch. w a pure meth or 50/50 mix. will add a source of fuel under boost. run colder plugs. start w less psi. and run on stock tune if there is no way to tune it. the stock tune should b able to handle some boost w a fmu and also if u spray the compressor. read plugs and maybe get a wideband if it allows. the fmu will work and add fuel under boost.
but gotta remember its just an aid but in no wau meant to replace a real tune.
also, sprayin pre compressor w save using a ic.
Engine: 377
Transmission: 400
The Mega-Squirt can do almost anything. But I'll have to make a new wiring harness to go with it.
I would probably need to rebuild my bottom end also. 11.2:1 probably isn't the best starting point for adding boost and my 253/260 duration cam wouldn't be so good either.
Thanks NemeSS, that's some good info.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I need to just find a spare fox and play with a junkyard turbo setup. But....my S10 extended cab build might be more fun with a rear mount turbo....and a t56. Just because no one would expect it.
Car: 02 SS
sounds like a plan zane.
i just would never build a fox for myself. i would build me a 240 like duy's car.
lil ****ers get lite real quick too. ls fits good too
Car: 1991 RS Camaro Convertible
Good luck on your venture. I am out of Thirdgens for now but bought an LS6 2004 CTS-V with 14000 miles on it. Have been having fun with that.
Car: 02 SS
hey thanks al!
ive installed a procharger kit, h/c/i lt headers on a 05 v. clutch n hydraulics. love those cars. guy I put together for got it tuned by a guy in atx and then sold it to a guy in mx.
have fun w it.
so far so good. finishing up a lq9 swap in a 69 convertible c3 corvette.
also got a 68 convertible firebird lined up. same owner.
made a 4l80e fit in a c3 convertible vette. engine and trans look lime it came stock. made the long tube headers off a 98-02 fbody work.
also doing single kit on a 5th gen. after tg.
planning on getting a NOS station at the start of the the year for those who like danger to manifold
have fun w it.
Car: 02 SS
Got my bendpak 2 post lift installed today. Bidness is picking up quite a bit
Car: 02 SS
working on a chebby w a lil s475 and few other ls swaps.
Car: 02 SS
Have for sale.
Complete setup to swap ls motor into a 3rd gen.
Have a low miles 4l60e.
Few 6.0 motors.
SW stainless 3rd gen headers. For ls swap.
12 bolt rear end w disk brakes. Cast iron center w built/cast in tq arm mount. 3td gen offset
1.75 drop springs f/r set.
4in cowl hood.
91 rs roller ttops camaro. No interior. Good dash. Good headliner.
Text me for more info if interested
Located in spring tx
Los
832 610 9373
Few 6.0 motors.
4in cowl hood.
Los
832 610 9373
Car: 02 SS
Most of this stuff was for my own personal 91 rs swap that I'm working on.
can install. Also
can install. Also
what would it cost to drop my IROC off and get an LS swap complete to A/C and power steering? Alternatively, do you do work on the TPI's? if I keep the TPI i'd like to do a mild heads/cam, headers and exhaust.
Car: 02 SS
Ls swap,depends on what motor/combo options u want. i can provide it 100%. Price is based off that. If you want more info.feel free to text me. 832 610 9373
Car: 02 SS
Been used to fire up and get another 3rd gen swap tuned. Less than 100 miles. Fit good.
Was going to use on my own personal 91 rs ls swap at one point. Then i wanted twins.
And now im looking at a c6 z06. So the 3rd gen is the project that has to get cut from the team.
Nothing wrong w em. Have no collector triangles. I can install vbands or triangle flanges on them.
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I was looking at getting a set of the LS swap longtubes and replacing the mess that is under my car at the moment. What size primaries and collectors? How much were you thinking? I'm less concerned about there not being v-band clamps or triangles on them.
Car: 02 SS
some pix of headers
#44
Car: 02 SS
front pic of car. can text more pix
#45
Car: 02 SS
500$ for the 91 rs roller w blue title.
300$ for hardwood 4in cowl hood no parting line. Can text pics
#46
1 Post
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
What is the name of your shop?
What parts do you still have available? I'm collecting for my 89 GTA LS swap.
#47
Car: 02 SS
Brutal.
I got pretty much everything. Text me with what u need.
LS1NNOVATIONS is my shop. I'm on spring cypress rd in spring TX
832 610 9373
832 610 9373
#48
Good luck with the shop! I'm not too far from you in College Station. If I need anything like this I will give you a holla!
#49
Car: 02 SS
Car/ rear end SOLD!!
450$ for headers. Sw version of the hawks. Quick sale.
I got the mOMotor mounts that work w these headers. Stock 3rd gen inserts n clamshells. 50$
Hmu. Prefrr local sale. houston n surrounding.
832 610 9373
832 610 9373
#50
1 Post
Car: 1989 GTA
I live just south of HOU in League City, might be interested in the headers and mounts.
