South Central Region Board for the states of Texas, Oklahoma, and Louisana.
HOW BIG CAN I GO
Old 02-01-2016, 05:32 PM
MirandaT's Avatar
HOW BIG CAN I GO
I'm wanting to put new wheels on my 92 camaro. They come stock with 15" and I was wondering if I go with an 18" wheel would I have to make some changes to keep them from rubbing?
Old 02-02-2016, 08:41 AM
Nefarious's Avatar
Car: 1991 Camaro RS convert
Engine: 5.0L TBI
Axle/Gears: 4th gen axle/4.11 gears
Re: HOW BIG CAN I GO
Not at all. I have 18s currently and I feel that they fit better than the stock wheels. It will all vary on your rim and offset. If you check out the wheels and tire section they have a ton of info. People are using 20's from 5th gens all the time.
Old 02-02-2016, 09:58 AM
MirandaT's Avatar
I know that my 15s rub when cut all the way. So I was just wondering about that. Thank you for the info though!!
Old 02-02-2016, 10:32 AM
Nefarious's Avatar
Engine: 5.0L TBI
I had a similar problem with my first 2 third gens and only 15's. I currently have 18's and 245 tires with no rubbing. Mine is on post 337 and 338 https://www.thirdgen.org/forums/whee...aro-5th-7.html
Old 02-03-2016, 10:26 AM
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
I have 17 zo6 rims w/2" spacer and they will rub also have a set of 15 American racing stock offset and they rub also when turning sharp
Old 02-06-2016, 11:02 PM
esc
esc's Avatar
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I have 17 x 9's with 275-40's (4.5" backspacing) all the way around and they rub substantially less than the factory 16's.
It isn't really the diameter of the rim that matters as much as the diameter of the tire and, even more important, the wheels offset/backspacing.
BeyondZ28_85
Exterior Parts Wanted
05-19-2016 11:58 PM
John Hagan
Interior Parts Wanted
02-07-2016 10:06 AM
chuck13
Brakes
02-04-2016 08:23 PM
Steve-o
02-01-2016 12:44 PM
Z-Firebird
Mid-West Region
01-31-2016 06:28 PM
Quick Reply: HOW BIG CAN I GO
