Wanted All Disc Brake Master Cylinder and prop.
Car: 1991 RS Camaro Convertible
Like the title says. Looking for an all disc brake master cylinder and proportioning valve in the Houston area or just the proportioning valve as I know the master is available at O'Reillys.
Thanks,
Alex
Thanks,
Alex
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Re: Wanted All Disc Brake Master Cylinder and prop.
I'll be bouncing to the local pick n pull here in SA this Sunday. I'll give a once over on the 3rdgens.
Jim.
Jim.
https://www.thirdgen.org/forums/tran...-10-bolts.html
Good luck with your search,
JamesC
hectre13
12-11-2023 08:14 AM
