South East Region Regional Board for South East Members.
Official Tampa, FL Area Thread
Old 11-24-2014, 09:48 AM
  #401
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Originally Posted by loneroad
what is your fuel setup again? mechanical pump? are you using a carb style pick up?
or are you using the in tank pump with a return?
He is using a mech pump with the stock v6 mpfi tank. We think he may have the mech pump connected to the wrong hose cause it won't pull fuel.
Old 11-24-2014, 09:49 AM
  #402
willexoIX's Avatar
Originally Posted by RubberDucky
Well, car still doesn't run. Still trying to get the pump to pull fuel.
Run that thing off gas fumes for 100mpg+, lol.
Old 11-24-2014, 09:58 AM
  #403
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: Official Tampa, FL Area Thread
did he pull the electric pump out or is he trying to pull fuel thru it.
Old 11-24-2014, 10:04 AM
  #404
willexoIX's Avatar
I believe its still there, and now that you mention it, it could be part of the problem. He's trying to pull through it, is it getting blocked by the electric pump in tank? Doesn't seem too far fetched.
Old 11-24-2014, 10:08 AM
  #405
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I would agree, aside from the fact I've seen it done with the electric pump still there. Buddy of mine is going to come by today and help me out.
If we can't get it going I'm just going to order a AFPR and braided line and keep the intank pump.
Old 11-24-2014, 10:14 AM
  #406
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
its been done before. if hes gonna keep the mechanical that's gotta go.
if he hasn't removed the electic pump, id keep that a use a return style regulator. esp if upgrades are in the future.
he could use a non return regulator, and deadhead the system. I did that foe awhile when I went carb.
I wish I would have kept my in pump. I went external. I wanna go to a xfi next year, and will be going back to the in-pump
Old 11-24-2014, 10:15 AM
  #407
willexoIX's Avatar
I'm surprised you haven't done that already, lol. Its how I would do a carbd swap. F the mech pump lol.
Then again, I dont think I would ever do a carb swap in my car, unless the first thing I am doing to it is converting it to efi off the bat.
Old 11-24-2014, 10:20 AM
  #408
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
use compressed air in your supply line. If you don't hear bubbles in your tank, the pump is a restriction, or your using the wrong line
Old 11-24-2014, 10:23 AM
  #409
willexoIX's Avatar
I never would have thought of that! Great idea!
Old 11-24-2014, 10:36 AM
  #410
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Not sure if your intank pump is the same as mine, but for a couple of weeks after I rewired my whole car and got rid of the computer, I didn't have any power going to the intank pump and my highpower mechanical pump pulled fuel just fine.
Old 11-24-2014, 11:42 AM
  #411
Car: 1989 Camaro RS
Engine: LH6
I'll try that today.
Old 11-25-2014, 02:37 PM
  #412
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
For those of you who are welders...I am planning on purchasing a welder. My father and I have a 69' Mustang Fastback that needs new quarter panels and quite a bit more. Is this welder ideal for that?
Would it also handle some sub-frame connectors?
This Friday, Saturday, and Sunday it is $84.99.
http://www.harborfreight.com/90-amp-...der-68887.html
If not, recommendations?
Old 11-25-2014, 02:59 PM
  #413
willexoIX's Avatar
We have a MIG 175 220 volt from eastwood and its great. We use the spool gun for aluminum. Its very versatile.
The price would be a bit higher, but this time of the year itll probably be cheaper.
Go with a MIG, at least 125, 220volt. And spend the money now on gas tanks and you will be set. Yes the smaller tanks are cheaper, but they run out fast. We have a 6ft tall tank for steel and a 2 1/2 ft tall tank for aluminum. Dont quite remember the specific classifications for the tanks.
Flux core is ok, but welding with gas is superior in just about every way. Typically flux core is best for windy/extremely windy conditions.
Old 11-25-2014, 04:30 PM
  #414
Car: 1991 Firebird
Engine: 3.1L V6
Thanks for the info.. I read basically the same info on a car restoration website about welders. So I'm looking at spending basically $300-500 on a decent one. Definitely don't want to skimp out on something like this. According to the website as well, it would take about an hour of practice to get comfortable and make uniformed welds.
Old 11-25-2014, 04:40 PM
  #415
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i've been through a few of those flux core welders. IMO, they're tricky to use especially "out of posistion". they make a LOT of splatter mess. so expect to do a ton of grinding.
i do like them for exhaust that doesnt need to be pretty or odd jobs. plus they're 110 volt and easily portable.
i'd recommend a better machine that uses gas. it will be worth the extra expense. i wouldnt want to weld quarter panels with a flux core.
i've done SFC's and a stainless street roll cage though with the cheap HF welder, lol.
lots of grinding and sanding!
Old 11-25-2014, 07:31 PM
  #416
willexoIX's Avatar
Saturday, December 13th at the Sonic on 301 in Zepherhills.
Anyone down for a meet?
Old 11-25-2014, 07:35 PM
  #417
willexoIX's Avatar
That sounds about right. Don't forget tanks, the initial investment on the tanks can be pricey, but once you have it all you do is trade in an empty tank for a full one and really only pay for a refill. Then its all your consumables, tips, wire, brushes, tip cleaners, etc...
Like I said, the initial investment will take a hit to your wallet, but a welder is something you really don't want to skimp on.
Old 11-25-2014, 08:21 PM
  #418
Car: 1991 Firebird
Engine: 3.1L V6
I work that day but I will be out by 4. Usually I get out earlier. Would give me time to clean the car up.
Old 11-25-2014, 08:33 PM
  #419
Car: 1989 Camaro RS
Engine: LH6
I'm down. Car will be ready for this one lol.
Old 11-25-2014, 08:48 PM
  #420
willexoIX's Avatar
Would be cool to have a meet with some daylight but I was thinking around 7pm cause you get off around 4 Jim.
Time is not set in stone though.
  #421
willexoIX's Avatar
Mine too unless I blow it up between now and then lol
Old 11-26-2014, 12:21 AM
  #422
Car: 1989 Camaro RS
Engine: LH6
I'll make sure to have my camera this time.
Old 11-26-2014, 07:07 AM
  #423
Car: 1991 Firebird
Engine: 3.1L V6
4pm is fine. Zepherhills is like 15min drive from me.
Old 11-28-2014, 04:36 PM
  #424
willexoIX's Avatar
Well probably wont be there in the Camaro.
Old 11-28-2014, 06:39 PM
  #425
Car: 1989 Camaro RS
Engine: LH6
If I can get mine running , I can help swap it. Its not as hard as you think lol.
Old 11-28-2014, 07:19 PM
  #426
Car: 1991 Firebird
Engine: 3.1L V6
What is keeping it from making an appearance?
Old 11-28-2014, 07:31 PM
  #427
willexoIX's Avatar
Its knocking. So the 2.8 has to come out and the 3.4 has to go in. Don't know if itll be done by then but I will have to retune it now and everything.
Old 11-29-2014, 01:56 PM
  #428
Car: 1989 Camaro RS
Engine: LH6
Well I quit. If anybody wants a 327 swapped 89 RS for 3k let me know, just need to get fuel to it and figure out the battery drain. I'm done.
Old 11-29-2014, 03:16 PM
  #429
willexoIX's Avatar
Waaaaah. Get that **** done bro. We expect you and your car at the meet on the 13th
Old 11-29-2014, 05:32 PM
  #430
Car: 1989 Camaro RS
Engine: LH6
I expect you to swap in the 3.4 before tomorrow.
Old 11-29-2014, 06:43 PM
  #431
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Dude, I wish I had 3k, I'd be there in a hearbeat. I gots 3 hunnit!
But I suppose that won't cut it.
Old 11-29-2014, 07:01 PM
  #432
Car: 1989 Camaro RS
Engine: LH6
Haha, if only $3,000 would cover the rest of the repairs for my Mercedes.
I'm going to go with this motor for the car. Can be had for around $4,000, 5.5l bi-turbo V12.
Old 11-29-2014, 07:41 PM
  #433
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
DUDE!
Put THAT in the Camaro.
Old 11-29-2014, 07:50 PM
  #434
Car: 1989 Camaro RS
Engine: LH6
DUDE!
Scratch that idea. Its got 2 plugs per cylinder, and each coil "pack" is $1,300. MegaSquirt couldn't control that motor no matter what I did. But, all it not lost. The older M120 6.0 V12 can be controlled by a MS3.
This is the original idea for the Mercedes.
Old 11-29-2014, 08:09 PM
  #435
DevilInside's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305cu. 4BBL
Transmission: 5 speed manual
New member here from Orlando FL...even tho my account is old lol. Got my 87 Trans Am about 2 weeks ago.
Its a 305 carbureted with a Edelbrock 1406 and a aftermarket distributor. Also has a 5 speed manual. Other than the current fuel issue i still love it.
Old 11-29-2014, 08:42 PM
  #436
willexoIX's Avatar
Haha. Yea. Right. Lol.
No really though, yours should have been running by now lol. I hope mine is only a flexplate, sure didnt sound like one though.
I would have assumed the flexplate would frag pushing the car to 110+ wot in boost if it was cracked.
Then again if it was detonating I would have assumed it would have died many wot shots ago.
Old 11-29-2014, 08:43 PM
  #437
willexoIX's Avatar
Welcome to the disfunctional thread of the CFLers! Lol.
Old 11-29-2014, 08:45 PM
  #438
willexoIX's Avatar
Video Link: https://www.youtube.com/watch?v=oN8pHJ3sQ0Q
!!! Sounds like a frickin nasty streetbike lol
  #439
Car: 1989 Camaro RS
Engine: LH6
Flex plate will hold because its bolted to the converter. When mine failed the center of it came out. Lol.
Old 11-29-2014, 08:47 PM
  #440
willexoIX's Avatar
I got one hunnit. Anyone got some pocket lint?
Old 11-29-2014, 09:50 PM
  #441
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
So Will, if we can find a benefactor to give us $2600, we can split the '89 327 every other week haha! Also, if you do end up swapping to the 3.4, I can drop by and help if it's a weekend.
Ducky, I secretly think Mercs are cool, so run with it!
And welcome Devil, we're all a bit nuts like Will said!
Old 11-29-2014, 10:04 PM
  #442
willexoIX's Avatar
Well Im still debating on how to go about checking the flexplate. Probably going to have to pull the motor anyway. If its a broken flexplate the 2.8 can stay. If its anything else the 3.4 goes in.
Old 11-29-2014, 10:14 PM
  #443
Car: 1989 Camaro RS
Engine: LH6
One day I'll be that guy and show up to a third gen meet with it.
Old 11-29-2014, 10:28 PM
  #444
willexoIX's Avatar
You and me both.
Old 11-30-2014, 11:07 AM
  #445
Engine: 305cu. 4BBL
Lol we are all nuts in our own ways. Thanks for the welcoming. Ill post a pic or 2 in a bit so yall can see what im workin with. Its not pretty and has major issues but its still my baby.
Old 11-30-2014, 11:36 AM
  #446
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i'm with ya!
my trannys been down for months, rear tire leaks air, and needs a paint job. just havent had time & money for a while. i did pick up another tranny the other day though. i'm gonna pull the front pump out today or tomorrow.
do you ever real get done working on a third gen?
Old 11-30-2014, 11:39 AM
  #447
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
If I didn't have to spend the money I got on floorpans, I would buy yours
Old 11-30-2014, 11:51 AM
  #448
Car: 1989 Camaro RS
Engine: LH6
I ordered a AFPR and braided hose today. Going to just keep the in take pump. I'm done fighting with the mech pump.
Old 11-30-2014, 12:00 PM
  #449
willexoIX's Avatar
Bout damn time! Im ready to hear yours run!
I'll be taking a good look at my flexplate at some point tomorrow.
Old 11-30-2014, 10:25 PM
  #450
Engine: 305cu. 4BBL
Here she is in all her glory lol. Better pics will be taken. Wifey took these.
Quick Reply: Official Tampa, FL Area Thread
