South East Region Regional Board for South East Members.
91 Camaro need help!
Old 11-01-2015, 07:13 AM
TheBatman90's Avatar
Car: 91 Camaro
Transmission: Automatic
Here are my problems;
I have a 91 Camaro with a 305 V8. It has a constant slight miss that I cannot identify. I have checked every spark plug, every wire, the distributor, button, and have had no luck as of yet. I have also rebuilt the TBI, seeing if that would clean it up to no avail.
In park and neutral it will idle just fine, a little high but nothing major, however when I shift into reverse/drive it wants to stall out on me until I give it some gas then it is fine. Once the car is warmed up it will run fine and idle pretty decent but if I have to stop at a stop sign or a stop light for a decent amount of time will begin to again think about stalling out on me so I must once again shift in to neutral to keep it from stalling out then into drive to get going again.
Any and all advice would be greatly appreciated as I am a college student who depends on this car to get me to from classes. Thank you in advance!
Old 11-01-2015, 10:53 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: 91 Camaro need help!
Whats your fuel pressure reading
Old 11-02-2015, 06:35 AM
Car: 91 Camaro
I do not know at this point I will have to check and get back to you asap!!
Old 10-03-2016, 08:15 AM
marineengineer's Avatar
Car: 1992 Z-28 Convertible
Engine: 305 LB9 TPI
Don't forget to check the IAC Valve setting. I had a similar issue that turned out to be fuel injectors. Your TBI Injectors could be dirty. Also while checking the fuel pressure, look at the fuel filters.
Gray Ghost 8991
03-13-2016 01:16 AM
MY87LT
Aftermarket Product Review
10-26-2015 09:05 PM
Steve Brodie
10-09-2015 01:32 PM
Dfdub92
Classified Ads Feedback Board
10-06-2015 09:11 PM
86IROC112
10-04-2015 12:03 PM
Quick Reply: 91 Camaro need help!
