Another 3rd gen passes the smog test
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Parrydice7
'85 Camaro 350 TPI swap
Re: Another 3rd gen passes the smog test
Years ago I posted details on the engine work that Don did on the car under something like "Dyno Don's Latest Masterpiece."
Considering I picked up a used engine/trans combo (although the trans had been trashed and Don replaced it with a T56), I'm amazed the engine runs as clean as it does.
Thanks, Don.
Thanks, Don.
Good job!
It's a nice looking car, too. You need to bring it out more often.
We need more blue cars at the cruises to make it even!
I think it was four years ago I took the car to dyno day. Don and Kevin spent a lot of time working on the tuning. I probably spent more time than anyone on the dyno and it got to the point where I was embarrassed by how much time they were spending on my car, so we finally moved on to another car.
I think all of us assumed (at least I know I did), that the car still needed to be tuned, even though two years later, when I had to go through smog, it blew some excellent numbers.
It is clear that the tuning is spot on.
Both Don and Kevin know what they are doing. Thanks to both of you for a job well done.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
nhra-trans-am
Southern California Area
09-17-2015 10:16 PM
