Southern California Area Southern California Members.
10 bolt rear advice
Old 11-06-2016, 10:17 AM
Gr89RS's Avatar
Car: '02 Z06
10 bolt rear advice
'89 Iroc with an apparent bad ring and pinion in the rear diff according to previous owner. my question is is this something worth trying to fix this or should I just replace it with a spare rear end?
Anyone have a 10 bolt for sale or know a local shop that rebuilds them for a reasonable price? every shop ive called wants over a grand. I messaged Dyno Don a few days ago but no response yet.
Old 11-06-2016, 03:28 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: 10 bolt rear advice
Your 89 is equiped with a 9 bolt rear if its disc brakes.
Old 11-06-2016, 03:33 PM
Gr89RS's Avatar
Car: '02 Z06
Drum brakes
Old 11-06-2016, 09:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Is it a throttle body injection? That would be drum brakes. Or a 305 TPI automatic would have drum brakes and 2.73 gears, too.
If you want to upgrade to disc brakes and better gears, a whole rear end swap would be your best bet.
Old 11-07-2016, 12:56 PM
Gr89RS's Avatar
Car: '02 Z06
It's TPI. 2.73 rear drum posi..
I do not plan to keep the car long.. so keeping costs to a minimum is ideal. The most efficient way to do it would be to find an exact replacement.. just don't know how realistic that will be.
Old 11-07-2016, 01:00 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Getting a "new" rear from a salvage yard will likely be your cheapest solution. Typically a car isn't scrapped because the rear went out... so it should be useable.
Otherwise, buy new gears ($200), bearings, gaskets, misc parts ($200), and labor to install ($200-$300) makes for a $600-$700 ballpark. YMMV.
Old 11-07-2016, 01:02 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
if your gonna get rid of the car, look on your local craiglist or shop around. should be able to find a used one very cheap.
have you pulled the cover to see whats exactly wrong with your current rear?
Old 11-07-2016, 07:40 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Pulling a complete rear out of another car will be your best bet drum rears out here in cali can be had for under 200.
Old 11-07-2016, 10:52 PM
MarineIROC's Avatar
Car: 1989 Camaro Z28
Old 12-09-2016, 12:03 PM
leo037's Avatar
Car: 92 RS with B4C Package
Axle/Gears: 323
Found this on the offer up app $60 complete rear end
This guy seem to have many parts for cheep
