Sponsored Vendors Connect with our Sponsored Vendors that sell the parts you need for your Third Gen Camaro or Firebird. Show your support for our vendors by offering feedback and telling friends about their services.
1982 - 1992 Pontiac Trans Am OE T-Top Seal Set (4 Piece)
Old 06-25-2010, 11:01 AM
Former Sponsor
1Aauto's Avatar
Click here for current pricing...1982 - 1992 Pontiac Trans Am OE T-Top Seal Set (4 Piece)
This 4 piece GM T-Top weatherstrip set is the original replacement parts used from GM. These new seals will help stop the water leaks from your T-tops and cure the wind whistling you may be experiencing from dryed and cracked original weatherstrips.
The details and quality of these OE are excllent. You can own a set of OE GM T-Tops seals for a fraction of the cost than going to your local dealer and ordering them.
PLEASE NOTE: These are NOT reproductions. This kit is actual GM OE seals for your T-Top F-Body car.
This kit includes:
A Pair of GM T-Top roofrail, or body seals - These are the seals that attach to the body of the car and seal the windshield pillar, around 3 sides of the T-Tops and down the back of the side window.
A Pair of outer edge GM T-Top seals - These are the seals that attach to the outer edges of the T-Tops, and seal the top edge of the side window to the T-Top.
These seals are correct for cars with factory GM Fisher T-Tops Only. A great quality kit at a fraction of the dealer price.
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side the tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
FREE SHIPPING
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: 1982 - 1992 Pontiac Trans Am OE T-Top Seal Set (4 Piece)
