Disc Rotor Sizes ???
I did a search and could not find an answer to my question. I didn't see it in the tech data either.
What are the brake disc rotor sizes for the following:
1982-1992 Front/Rear rotor size? Was it the same for all 11 model years or did it change with the PBR calipers?
1988-1992 Front/Rear 1LE rotor size?
Thanks!
Thanks!
1989-1992 1LE: 11.86 front (12"), 11.86 rear (12")
1989-1992 J65: 10.5" front, 11.86 (12") rear
Late 1991 and all 1992 RS B4C: 11.86 (12") front, 11.86 (12") rear
I don't know about 1982-1988, but I know the rears were smaller, I believe fronts were 10.5".
1989-1992 1LE front was dual piston PBR, and rears were single piston PBR
Front 1LE PBR calipers were aluminum, rears I don't know.
Someone correct me if wrong
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
1982 - 1988 standard rear discs we're also 10.5" like the fronts, using cast iron single piston calipers on all 4 corners.
Car: 1989 Formula 350
Axle/Gears: 3.27 Posi
Re: Disc Rotor Sizes ???
my 89 Formula,has a lil under 11 inch front and 11 3/4 back aprox. Why did they do the rears bigger and not the fronts??
