easy ways to repair brake line leaks
Old 05-23-2004, 10:40 AM
mdr211's Avatar
Car: 86 camaro Z28
Engine: 305 carb
behind my left rear tire my brake line has a leak, when im under there and someone pushes the brakes you can see it squirt out in a fine stream. the hole is in the metal part of the line. does anyone know if theres an easier way to repair that other than replacong the whole line? as long as its safe ill try it.
Old 05-23-2004, 11:38 AM
CaysE's Avatar
Not sure if this will work for brake lines, but you can get this clay-like stuff that's used by plumbers and HVAC contractors to plug leaks in water and steam pipes. It hardens very well, even when wet. The stuff does last a long time, but it's a temporary fix and you should get that line replaced ASAP.
Old 05-23-2004, 01:18 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
When it comes to brakes, there is no quick, easy fix.
The line needs replaced, but before you pull it out, be sure the bleed screw on the wheel cylinder/caliper is free, so it can be repaired/replaced if needed.
Old 05-23-2004, 05:54 PM
halloweenz28's Avatar
yesterday i just finished up exactly the same problem that you have (a hole in the hard line , prob from rust)
i asked many questions and there are several ways to go about it, what i did was: cut of crapped up piece, buy a coupler and a double flare tool and flared the end that i cut on the car, then i bent a new small piece to fit. so far thats as far as i got i was trying to bleed them today but i had problems getting a clear piece of tubing to stay on the bleed screw.
Old 05-23-2004, 07:49 PM
eddie jr's Avatar
the easiest way is to cut out the bad section (back to good metal), get a small piece of new line and two compression fittings. Cut the new line to size and use a compression fitting at each end to attach. Compression fittings don't even require flaring of the line end. Just poke er' in and clamp er' down! Comp fittings are designed to handle the pressure of a brake system (as long as you splice in at a point with good clean metal).
Old 05-24-2004, 09:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup. this is the easist safe way to do it. you just replace the broken section.
the clay pipe repair stuff, JB weld, and other such epoxy methods are NOT safe at all.
the "best" way to do it is to replace the entire line... but theres nothing wrong with just replacing the broken section.
Old 05-24-2004, 11:35 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Don't use a hardener - that is not safe at all.
Old 05-24-2004, 02:33 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I always thought compression fittings were not strong enough to hold brake pressure. I would pull the line out measure how long it is. Then go to the auto store and get a straight line with the same fittings on either end. Then bend it to fit, this way you have new fittings and tubing that aren't all rusty.
Old 05-24-2004, 02:41 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Compression fittings might hold but are not the correct fix either, to repair a line correctly you`ll need to double flare the line and use a union to splice it in to the old part, again not the prefered way to do it and truly a lot harder than just changing the whole line.
Old 05-24-2004, 02:54 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
I just replaced all of my hardlines with stainless steel pieces. I got
the 7 peice kit for $199 from classic tube. Unfortunately I had to wait four weeks for them to make my lines. Perfect fit though. Also Inline tube makes them and can do it in 48 hours. Haven't seen thier stuff though.
Reddeath210
10-06-2015 08:20 AM
TheExaminer
08-26-2015 04:59 PM
Leggman1
Brakes
08-12-2015 08:39 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Leggman1
08-06-2015 04:15 AM
Quick Reply: easy ways to repair brake line leaks
