Front bumpstops for lowered cars
Old 07-31-2005, 09:03 PM
CaysE's Avatar
FYI: I got these bumpstops as direct replacements for my front a-arms, but they are a good half inch shorter than the stockers. Perfect for an Eibach drop (should be fine for both Pro-Kits and Sportlines).
Moog K6606 in front, stock in back. They are a little shorter on top than shown, the angle throws the picture off:
Old 07-31-2005, 09:45 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Good to know, thanks CaysE.
Figured out how much to cut the stock sway bar endlink spacers yet for the Pro-Kit springs (not trying to rush you or anything, just curious)?
Old 07-31-2005, 09:55 PM
CaysE's Avatar
No, but I think I can do some measurements to figure it out. Just so you know, the sleeves can't just be cut, you need a bolt with a shorter shoulder as well.
Old 07-31-2005, 10:37 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
do you happen to have a part # for better rear bump stops? i was thinking a poly mount... and is that moog rubber or poly?
Old 08-01-2005, 09:48 AM
CaysE's Avatar
It's rubber. Why would you want poly bumpstops anyway? You want the bumpstops hard enough to prevent bottoming out but as soft as possible otherwise.
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
1992rs/ss
05-19-2020 07:02 PM
Azrael91966669
25
06-20-2017 04:04 AM
87iroctheo
Wheels and Tires
08-29-2015 09:44 PM
Quick Reply: Front bumpstops for lowered cars
