“full” front end rebuild kit
Old 10-06-2006, 11:40 AM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Hey guys, I have a 1982 Camaro berlinetta LG4. I need to replace the front end bushing really bad I was wondering what was the best “full” front end rebuild kit. I’m looking for something that will not chance the ride height but will “dramatically” change the handling. Any ideas, thank guys
Old 10-06-2006, 12:39 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
I used a P-S-T suspension rebuild kit in my front end. They use a polygraphite bushing. Graphite in the poly keeps them from squeaking. I had good luck with this kit and had no problems. I ordered it with all the tie rods and the two ball joints.
The poly bushings keep the suspension from deflecting under load, and keep alignment true through the travel of the front end.
There are other manufactures that make kits so shop the market.
To "dramaticly" change the ride you will have to change springs and shocks. A spring change would probably alter the ride height as well as the characteristic of the ride.
Good luck.
Old 10-06-2006, 03:14 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Also consider replacing the upper strut mounts while you have it apart. Two good sites for these items are:
Spohn Performance, Inc.
and Shox Bilstein shocks, Bilstein PSS, Koni, BOGE, Eibach, K&N and other name brand suppliers
hectre13
12-11-2023 08:14 AM
customblackbird
08-15-2021 10:16 PM
Terrell351
06-13-2021 01:13 PM
italiano67
12-11-2016 09:21 AM
bellez77
09-05-2015 08:39 PM
Quick Reply: “full” front end rebuild kit
