tie rod end thread
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: tie rod end thread
I think they are 5/8 fine thread
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The tie rods themselves or the nuts on the ends where they attach to the spindles?
According to these aftermarket sleeves, they're 5/8"
http://www.jegs.com/i/Hotchkis/515/1601/10002/-1
http://www.jegs.com/i/Edelbrock/350/5250/10002/-1#
If installed properly, the outers should be RH thread. The inners will be LH thread.
Taper on what? Tie rod ends? They probably are 1.500tpf (1,5 inches of taper per foot length) or sometimes called out as 7 degree taper.
As for the sleeves, I'm not paying 40$ for a small sleeve and 2 locking nuts, lengths of that aluminum hex tubing cost next to nothing, you can cut it down, mill it to whatever end hape you want and thread it L&R and be done. I'll end up doing that.
1 Post
Car: 82z28
Engine: 406
Transmission: th350
you can buy them through www.colemanracing.com in the correct length already threaded at a more realistic price.
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
LT1Formula
08-20-2015 09:36 PM
