Drifting IROC Camaro project
#102
Car: 91 240sx
Engine: Ka24de
Re: Drifting IROC Camaro project
what ever happened to this car? are u still drifting? are you gonna take it to Formula D again? did u ever get any more angle?
i am currently working on an angle kit if anyone is interested. it's at 54* with 5* negative camber with the camber plates all the way in.
#103
Car: 92 RS
Transmission: WC T-5
Axle/Gears: 4th gen 3.42, mini spool
thats awesome bro.
can you give us a rundown on what your planning on offering with your kit?
#104
Car: 91 240sx
Engine: Ka24de
it comes with 2" extended LCA's that are highly modified and boxed in, modified steering knuckle, and 2" longer zinc plated tie rod sleeves. for now the kit will be $475. in the near feature i will be working on some fully adjustable tubular LCA's that will make things way easier and tunable. and i will also be building my own steering knuckles so modifying stock components wont be necessary. but that may be a little while.
#105
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
#106
Car: 91 240sx
Engine: Ka24de
#107
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
If you eventually plan to make steering knuckles/spindles, a very important thing to factor into the design would be for them to be a drop spindle (1.5"-2") with a steering arm that short enough not to interfere with a wide 18" (hopefully 17"?) wheel. I'd imagine that there would be a lot of interest in such a product.
#108
Car: 91 240sx
Engine: Ka24de
#109
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
best regards
#110
Engine: LB9, LB9
Awesome, I'll definitely be interested then. The only reason why I don't run drop spindles on my car is because they won't clear a 10" or 11" wide front wheel.
#111
Car: 1986 camaro
Engine: 2.8L v6 multiport injection
Transmission: 5-speed
#113
Car: 89 iroc
I have not done much work on the IROC over the last few years. It has sat a bunch, I've taken it to a few drift events. It is a trooper, takes a lot of abuse.
Added a Hydraulic ebrake and second caliper (made a bracket). Sits in the factory area, works well.
This last Saturday we went to Cupcake Meet 17 in Corpus Christi to take part in a drift demo. It was a small lot, but we had fun. Derrick drove and gave ride alongs to people lined up to pay. Went through several sets of tires (used ones).
We also drove it at the Mexican Standoff (Fabricated Motorsports drift event). Yokoi ( Japanese D1 driver) made some laps in it and got the hang of it.
I need to finish up the other one we are building,
James
James
#118
#121
Am I having very detailed deja vu or did you post that rear end before and it got deleted? If the latter is the case you may want to post it in classified section to prevent that from happening again.
#126
Car: 89' IROC-Z
Engine: LO3
Awwwwright!
Dual Caliper Hydraulic E. Noice. My arms are too short to make the move to the e-brake in it's stock location. I plan to hack the center console and move it to the left side, or extend it up and over so I don't have to mess with the center console.
Just picked this up myself. Should bring her forward about 3". Comfortably Close ;P ;P
https://goo.gl/photos/GmRgnxarFShqJZnS7
#127
#128
sounds kinda like what i built for mine about 5 year ago
mustangman65_79
08-11-2015 03:17 PM
