Tires fit tight 295/65/15
Old 03-04-2009, 12:01 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
So I got my tires for this season and they are close everywhere besides width. I'm sure someone is going to verbally rape me for putting a set of 295/65/15's (30x11.5x15) on the stock 7" wide wheels. I do like the way they look though:
Old 03-04-2009, 02:21 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Tires fit tight 295/65/15
OMG !! thats beyond tight.
Old 03-04-2009, 02:35 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I noticed too how my sway bar link mod obviously works since the driver side is .75" away from the tire and the passenger side is 1.5".
Old 03-04-2009, 03:27 PM
Shagwell's Avatar
Car: projects.......
Definitely a lot of tire for that wheel. Gonna take some time to find "the sweet spot" on air-pressure.
Old 03-04-2009, 05:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
GOOD GOD that's a big tire!!!
haha, very nice, i'm impressed.
you going to cut away some wheel well ?
Old 03-04-2009, 05:33 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I'm probably going to move the axle forward about 3/8" to give even front and rear clearance, and trim some of the top lip off so they don't hit vertically. Others on here have used these tires without modification, so I'm planning on enough clearance to be there. It really isn't that skinny of a wheel for them since off of a wheel they measure 7.5" across the bead just as my past 275's have measured.
Old 03-04-2009, 05:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
that'll be about 1" clearance front and rear? Hmm, should be alright I suppose, you're going to trim the top lip? I'll have to see what you plan, I can't picture it looking right...
Are there only drag radials available in a 295/65/R15 tire? No regular street tires eh?
Old 03-04-2009, 07:38 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I doubt anyone makes a street tire of that size, but I need the tire height for the gear ratio to go 160mph in the 1/4-mile hehe. You kinda need a picture to see what I mean by trim, lets see if I can quickly. A section of the wheel well right above the tires looks roughly like:
Astriscs are supposed to be empty space
And I'm going to make it like:
This way has no metal directly above the tire and gives me almost an extra inch of vertical clearance.
Old 03-05-2009, 09:17 AM
Shagwell's Avatar
You might want to look into the proper technique for rolling the lip instead of cutting it off. You'd be very suprised at how easily it and the rest of the quarter will bend/dent if you cut the lip off.
Old 03-08-2009, 09:07 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i tried to fit that exact tire and wheel combo(it was even a black painted wheel) on my car and the wheel would not sit flush.
ive since modified my wheelwells with some ******* hammer tubbing, but i still think its going to be a tight fit.
whats your secrets?
did you bang any on the wheelwell in the front near the lca mount?
Old 03-08-2009, 11:00 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I had previously made room for a set of 325/50/15's on 15x10 wheels with a 6.5"BS by heavily hammering the front area by the LCA's, and looks like it should make enough room for these tires.
Old 03-08-2009, 11:11 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
next time you want a tall tire go here http://riverviewtire.com/Tireheightchart.html
and look at the stats instead of using that hillbilly setup with pregnant rims.
if you are going to run at 160 you dont need bad tires matched to bad rims.
Old 03-08-2009, 11:37 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I don't see where that link was supposed to help me? I can calculate and tell you more information than those charts show, along with they don't have my tire size listed there to begin with. Tires normally have inch dimentions readily available anyways. I know these tires aren't meant to be on this small of a wheel, but I highly doubt they will suck or do something stupid because of the wheel width.
Old 03-09-2009, 02:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
any pics of your wheelwell?
im just curious how far they are hammered in.
thanks!
Old 03-09-2009, 06:02 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
The red areas needed room, the one on the left (rear) isn't needed on the driver side. I hammered in the front side about 1/2". The other areas in yellow should be moved for side wall clearance when cornering, but aren't needed if you don't turn hard. Don't be afraid to really hit the metal on the front sides; I was slamming it as hard as I could with a 13lb hammer.
Old 03-05-2015, 03:45 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I know this is an old post very old actually but if I run these tires on a 15x10 rim with 5.5" bs would they stick out too much pass the fender?
Old 03-05-2015, 04:13 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i would not like the look of the 5.5" backspacing wheel. this is a mt 295 on a 8.25" wheel with 5"bs to get you an idea. it completely tucks, but the shot from the back i do not care for. the side angle looks very good. but from the back it looks like truck tires. a 10" wheel would just make it worse, IMO. a 6"bs or 6.5 would be ideal for me, but youll need some surgery
Attached Thumbnails Tires fit tight 295/65/15-dscn2273.jpg   Tires fit tight 295/65/15-dscn2270.jpg
Old 03-05-2015, 04:28 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yeah I had seein your thread on your tire install. Just was wondering how it would look with the wheels I have I wanna run the biggest tire without it having to stick out so much. So far tried 28x10.5 the side wall sticks out a bit
Attached Thumbnails Tires fit tight 295/65/15-img_20150305_131951.jpg
Old 03-05-2015, 10:00 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
On a 15x10 wheel you'll want 6.5" BS. This takes some love from a big hammer, but I have run 325/50/15 on 15x10 6.5 BS:
Last season I modded my z28 wheels to be 2 piece and 10" wide. I didn't take as many pictures as I should have when I made them, but here's part of it:
For this season I want to do some cutting/welding so I can use thinner or no wheel spacers compared to what I've been running with those wheels since the backspace is about 7.25" without the spacers.
Old 03-06-2015, 01:41 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I run the same tires on a 15x10 rim but my rear is 1.5" wider each side. Mine tuck in nice but the wheel wells are tight front and back as well. I only use the tires for the track so I'm not going to mess with the wheel wells. Ran them at the track and had no running with a 1.8s 60'.
Old 03-06-2015, 03:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I really like the 325/50 look... running that with my 5.5" bs though would it stick out alot I just dont wanna go through having to buy new wheels since there about $400-500.
Old 03-06-2015, 03:07 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Or is there a way I could add backspacing?
Old 03-10-2015, 12:52 AM
Car: 87 TA clone
Here was mine on the same size tire.
Attached Thumbnails Tires fit tight 295/65/15-2011-12-08_12-31
Old 03-11-2015, 01:34 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What size tire you run and bs does your wheels have customblackbird?
Old 03-16-2015, 11:45 PM
Car: 87 TA clone
I want to say rims have 5.5 back spacing but I could be wrong... they are summit Brand 5 spoke knock offs in a 15x10" rim.
Tire is the 295/65r15 MT drag radials.
Old 04-14-2016, 08:17 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Guess this proves a 275/60R17 is possible, thanks for the pics!
Street Lethal
04-30-2019 12:14 PM
1992rs/ss
16
01-28-2016 09:58 PM
Djmathis123
08-24-2015 02:53 PM
BlackMagic1984
Wheels and Tires
08-24-2015 06:35 AM
Quick Reply: Tires fit tight 295/65/15
