finally alstons and bmr subframe installed with pics
Old 07-10-2010, 07:04 PM
  #101
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: finally alstons and bmr subframe installed with pics
Originally Posted by madmax
Right so in 8 feet its only accurate to about 1/16", not the 0.0005" your post I quoted says. Two completely different numbers. On top of that you're relying on how accurate you can read the bubble, which introduces a possible error all its own. Try some different thicknesses of skew under your level and find out how accurate you can actually read it from what you think is level.
Fair enough I'll admit I read and quoted wrong the accuracy of the level. As to whether or not a laser is more accurate than a bubble, I stand by what I say: the bubble is more accurate than the laser.
If you know how to use a bubble level, you will be more accurate than a laser. Problem is most people don't know how to double level, refine level, or most other basic surveying techniques that are meant to get you down to the accuracy or resolution of the instrument. They just want something that they know the tolerance of and can see where its pointing.
However, I think we can all agree that beyond 1/16" in accuracy is overkill for our cars.
Old 07-10-2010, 08:38 PM
  #102
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
As with any measuring instrument its accuracy depends on its quality of construction and how it is calibrated.
With a laser level the good ones are +/- 1/16" in 100ft so in 10 feet theory they would be 10x more accurate in 10 ft. One issue with a laser level is the thickness of the beam.
With a compensating optical level again well was it built and for what applications. A David White inst is fine for laying out patios and sidewalks.
My level is calibrated to 0.005' in 300ft. First order optical levels have the same accuracy but come with a micrometer adjustment for fine sighting.
ANY optical level is subject to eye parallax.
Electronic levels eliminate eye parallax but the rod has to be in very good focus to read the bar code rod.
Then there is the error by not having your measuring rod perfectly plumb. If its tilted out of plumb then your reading is wrong.
But as said earlier, on a 3rd gen who cares for less than 1/4 inch.
As for Pablos sag, you need the factory manual to determine the difference in points near the ends of the frame or unibody and somewhere near the middle under the B piller.
Old 07-10-2010, 10:34 PM
  #103
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
What kind of level is it? Thats on par with Leica optical auto levels and Sokkia power levels.
Old 07-10-2010, 11:17 PM
  #104
Guest
Guest
Posts: n/a
FOr the accuracy of consistincy of the laser level I listed? I will sayu again it is dead nuts accurate for the application.
Fact: Whenever I set the scales using this level and baseline setup the SUpetruck chassis to 52.4% creoss weight....THEN... I transported the entire rack and scale setup to another location and used the laser to again setup the rack and scale system and THEN set the untuched car upon it the scales ALWAYS registered 52.4%. That laser is dead nuts accurate for this intended use- that task was performed probably 560 times and was always perfect.
You have to know how to use the laser level- Key note is to always use the front self leveling pointer and rest it on a platform that you can rotate it 360* with the front pointer reading- Do NOT use the front readings and then the side readings together in the same perimeter gauging - this is where the accuracy deficiancy lays.
Old 07-11-2010, 12:42 AM
  #105
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Aren't the tripod ones self lelving using the bubble system inside???
Old 07-11-2010, 11:17 AM
  #106
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
I'm not sure. I know that on the outside, you get it close to being level using the level bubbles on the outside of the level, whether its a level vial or a bullseye bubble. I know that Spectra uses prisms suspend from the inside of the instrument to get a true plumb and auto compensator's to refine the leveling down to +/- 1/16". Not sure how the off the shelf hardware store ones do it though.
Old 07-11-2010, 12:10 PM
  #107
injdinjn's Avatar
Ni2
Old 07-11-2010, 03:32 PM
  #108
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The trip pod ones are pricy pricy pricy fancy stuff, why I still don't have one.
Reminds me of the water filled compus everyone had in their car back in the day. It self levels to give an accurate heading.
Old 07-11-2010, 06:41 PM
  #109
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by JamesC
This thread contains pertinent and certainly interesting/important information from knowledgeable members. Please don't allow personal annoyances to outweigh the benefit of the information.
The above from post #88.
JamesC
Old 07-11-2010, 09:48 PM
  #110
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Seeing as how there are quiet a few guys here who know a thing or two about levels, maybe we could put our heads together and come up with an accurate home made level. It would still be a first order magnitude level, but I'm betting there's a few MacGuyver tricks out there to make a decent level for not much money.
I'm thinking it would be an optical level based on something like a BB gun scope. It wouldn't be too hard to make a tribrach out of some plate and 3 machine screws and a tripod out of some 2x4's.
Old 07-11-2010, 10:12 PM
  #111
Guest
Guest
Posts: n/a
Why go to all that expense and headache? Just go to Home Depot, buy a 5 gallon bucket, some clear 3/8" tubing, and make a water level. It will be every bit as accurate as the bubble level or laser level. Tape the tubing to a piece of wood, put it on your first point (jackstand, preferably the high one), mark it at the bottom of the meniscus, and raise all the others to that same height.
Old 07-11-2010, 11:45 PM
  #112
injdinjn's Avatar
Most optical levels do not focus under 5-10 feet.
For leveling a car a water level would be the most accurate.
If you looked at a optical level and tripod you would see why building your own is a waste of time
Old 07-18-2010, 05:34 PM
  #113
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Got my MAC's on Friday and did a quick test fit just now. I noticed that with stock exhaust this style doesn't seem to work. Can anyone else verify this? It looks like the passenger side SFC will not clear the exhaust where it routes under the passenger side floorpan.
The quality is nice but after looking again at the Alstons, I think I'd rather have those than the MACs. Maybe I'll sell em and get the Alstons afterall. The MACs are nice, but its basically bent tube with a flat plate on them to attach to the subframe. They don't have that nice taper like the Alstons do.
Old 07-18-2010, 09:32 PM
  #114
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id agree, Alstons look like something out of a pro race shop.
Well formed bent tube on a pro $$$$$$ machine.
Not a back yard, grab some square stock min work or tools needed to make it.
Old 07-18-2010, 11:51 PM
  #115
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Actually, in pure bending, square stock is better. Tubes are only better in torsion or where you want the same flexural modulus in every direction. Henceforth, nascar chassis elements are box and the roll cages are round. You don't know what direction an impact is coming from which is why a roll cage is round tube. An SFC is undergoing minimal amounts of torsion. Look under any serious truck chassis and you will find a box section chassis. The taller the better.
Old 07-19-2010, 08:22 PM
  #116
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
Why such concern over "leveling" ?
Are your springs all perfectly equal in spring-rates? Weight all perfectly balanced on each corner?
Lots of interesting talk on precision leveling, but for street subframe connectors it is a total waste of time.
If your suspension is already loaded and the alignment set to that, all the goal is for the SFC's is to try to keep that somewhat managed by strengthening the frame so it doesn't twist that out of whack during hard acceleration or turns.
Someone mentioned dynamic leveling? but using static methods...
We might as well determine dynamic centers of gravity in determining how to weld up the SFC's.
Edit: other reasons of course to install SFC's include eliminate rattles and body sags causing cracks and bad door closing etc...
Originally Posted by InfernalVortex
If you have a hardtop car, check the back/top corner of the driver and passenger side window... see if there's a crack there, because if there is, SFC's will keep that thing from getting bigger.
Old 07-19-2010, 08:28 PM
  #117
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
The Alston's come as a bolt in but you can have them welded up.
Old 07-19-2010, 09:00 PM
  #118
Guest
Guest
Posts: n/a
Look at the frame as a spring. If you were to place one wheel on a 4" block, there would be additional stress in the chassis starting at that location. Then you weld in your SFC's. Now take out the block. This really is not any different than preloading a chassis with slapper bars or via the sway bar links or chassis mount location, wedge in the spring, etc. You've put a different spring rate into the car, permanently... and better yet into something that was not only not designed as a spring but does a terrible job of being one. If you think the addition of those SFC's is going to minimize flex on a preloaded chassis... well... its not going to do that very well. Its a couple inches of steel tubing, not a W12x210 I beam (that'd be something in a large building). So what happens if you do that is every time you load and unload that wheel, its going to act a lot different than the other 3. Thats why leveling was brought up. The only real argument one could make is how close is close enough? There is not much symmetry to the chassis either, so making an assumption that a level chassis with a thirdgen and welding in SFC's is going to provide the same amount of resistance to deflection at each of the 4 corners is only going to get you into trouble if you want to consider microscopic effects like these.
Old 07-19-2010, 11:31 PM
  #119
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Um, yes, I would expect SFC's to minimize body flex, or why put them on? Decorations to add ballast? Show pieces for cruise night? Exhaust protectors for speed bumps? Jack points?
I realize the need to have the car sitting level before installing them, like not in a twisted configuration, but this thread is a carryover from others on the same topic, and some points have gotten lost.
Old 07-20-2010, 10:15 AM
  #120
Guest
Guest
Posts: n/a
This is a typical veiw from 99.99% of the world that do not understand the complexities of chassis dynamics and never will to the extent it takes to know why this is important to level the vehicle. THIS is why we are having this dicussion. Your soring rates are NOT all the same not even side to side. You would be amazed to see how much factory springs varry when you put them on a spring rate tester. THEN there are so many other factors that are way to many for me to start listing.
Just start with a level frame and then you are starting with a perfect canvas. Otherwise? so much for best performance- people on race tracks always think the other guy is cheating because they have exactly the same parts visually...but not technically. My famous quote once again," Its not just what you have, its how you set it"
Dean
Old 01-24-2011, 10:50 PM
  #121
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
bump from the dead..
simple question, how is the ground clearance on the alstons/MAC's? anyone take any side pictures? my car is low, i dont want to be scraping the crap out of them
Old 01-24-2011, 11:48 PM
  #122
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
IM fine with Alstons n 225/60/15 hair smaller then stock.
Old 05-24-2011, 12:48 PM
  #123
Guest
Guest
Posts: n/a
Resurrect to say that until finding this, I too would've never considered combining different SFCs under one car. Maybe a chart of which brands work together, as a sticky?
Looks to me like I can do Spohn + Alston? Or did I misunderstand?
Old 08-05-2011, 01:18 PM
  #124
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
never mind
Old 05-24-2012, 08:03 AM
  #125
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
Originally Posted by 96LT4c4
Guys, I know everyone is saying that you should only weld these on with the cars suspension loaded, but I have mine tore all the way down to the shell and plan on putting it on a rotisserie. It would be so nice and easy to weld these on while on the rotisserie. Just wondering if anyone has actually had problems after doing this.
I insisted that the suspension had to be loaded when I had these installed and the guy doing it like refused to try another method to lift it and welded them in with no weight on the wheels and at first I was really upset but the car drives absolutely fine I dont think its an issue.
And I have the Hotchkis SFC's does anyone know if any of these inner ones aren't compatible for some reason?
Old 09-08-2013, 02:44 PM
  #126
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by BMR Sales
I wish that we would develop connectors like the alston's. When combined with our connectors they tie the entire subframe together.
isn't that the whole point?? to adequately tie the subframes together?? why hasn't anyone made a set that combines both designs?? why do we have to buy TWO different sets just to get it right??
Old 09-08-2013, 05:29 PM
  #127
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Most of the time if you want it done right you have to build it yourself...
Old 04-29-2014, 10:56 PM
  #128
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Saw this when it originally went up, but was getting deep into a LS1 installation.
Like the OP says, the difference is amazing. Definitely worth doing, adding inner connectors (Alston's for me) to outers you already have…OR… putting both on. I already had some custom outers done years ago. They made a big difference, but were clearly not enough with a move to New England, and it's challenging roads.
Warning to LSX types- the Alston's require some work to the Hawk's transmission mount. Both want to be in the same place, so a bit of fitting is needed. WORTH the effort.
Old 04-29-2014, 11:18 PM
  #129
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
gotta say guys. I had the inner alstons bolted in and they worked for a little while... at the time i had minimal welding skills and no drive-on "loaded chassis" lift so i took it to a local race shop, they reccomended a full S&W subframe kit. after learning about it, i was all in. i ended up selling the alston inner bars to ed-pontiac.
very happy with this subframe setup:
posts of the frame start at my #4 post
https://www.thirdgen.org/forums/susp...rame-into.html
or view it on my dumb-*** website:
http://www.freewebs.com/iroczman15/workdonein2009.htm
since then the underside has been completley stripped down to metal, undercoated as well as the rear .
of course im not putting down a ton of horsepower, but this kind of frame that ties into rockers, has a driveshaft loop, and an integrated tq-arm has been incredible for the past 4 years.
just wanted to put it out there for curious fbody wrenchers
Old 04-29-2014, 11:26 PM
  #130
IROCZman15's Avatar
Car: 1987 IROC-Z
ALSO. JUST IN CASE PEOPLE WANTED TO SEE PHOTOS OF THE s&w KIT "ISOLATED" HERE IS A LINK TO PHOTOS I TOOK WHEN I WAS SANDING DOWN THE UNDERSIDE OF THE CAR AND LEAVING THE FRAME INTACT, IT SHOWS THE CONTOURS AND PARTS OF THE FRAME SETUP MUCH BETTER
http://www.freewebs.com/iroczman15/workdonein2010.htm
Old 04-30-2016, 12:19 AM
  #131
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Gonna bump this, as im gonna take this route myself now and rally make things solid, might even tie the two in spots...
cept BMR is funny, same price on website and ebay, cept ebay is free shipping, website is not. with ebay fees n paypal, they lose money, direct website sale you make more, so you charge shipping there??? would of ordered them tonight if the website didn't want $45 shipping.
Old 05-13-2016, 09:26 PM
  #132
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How did ya get the LCA bolts out? even cut the head off, wouldn't turn, won't pound out, tempted to drill them out, but my luck the sleeve will start to spin 90% done....
Old 05-13-2016, 10:27 PM
  #133
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
bigger hammer.
Old 06-20-2016, 11:57 AM
  #134
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
20141203 184004
20141107 234154
20141108 013625
I had the Alston inners and the Spohn crossmember. As stated above they want to occupy the same spot and the crossmember dose not want you to have exhaust so this is what ended up happening.
1986BANDIT (11-26-2019)
Old 02-22-2018, 10:19 PM
  #135
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Gonna bump this up again to the Trump era: when ya get the BMRs (to combine w the Alstons) is it SFC008 or 009? With Hooker 2055s + MF catback in my case.
This would seem to indicate 009s but I recall the 008 seemed to fit shorties too(?) and be the more traditional design like the UMI sfc?
BMR offers two versions for different exhaust combinations. Part Number SFC008 is designed for cars with full length headers and exhaust systems that run inside the frame rails. Part Number SFC009 is designed for cars equipped with the OE manifolds or shorty headers with OE exhaust or OE type exhaust that runs on the passenger side, outboard the subframe.
Old 02-25-2018, 03:56 PM
  #136
Flip 2's Avatar
Engine: C5 LS1
SFC008
The tail of the squib mentions the OE type exhaust- seems to include the outer passenger side routing. Such an exhaust setup will not work with a LS motor installed. Long tubes or no, the exhaust wants to run down the center of the car. That would seem to indicate 008. I bet the 009 just makes a bunch of space accommodations you will not need to worry about.
Old 02-26-2018, 06:04 AM
  #137
Car: '89 'ROC
Engine: 5.7L
Excellent- exactly what I suspected. 008s it is. Ty Flip.
Old 03-01-2018, 10:08 AM
  #138
Car: '89 'ROC
Engine: 5.7L
Thought I'd just note as an FYI that the shipped weight on BMR's invoice is 37.0lbs.
UPS has the Alstons at 21.0 lbs.
Old 08-17-2019, 08:22 PM
  #139
91Z-28-350's Avatar
Car: 91 Z28
Engine: 350ci TPI L98
Transmission: Stock 4L60
Sorry, going to necro this thread again - anyone have pics of both the Heidts and BMRs installed? F@*king Photobucket ruined yet another thread it seems.
eddie jr
08-10-2012 08:05 PM
itsMikey
09-07-2011 03:13 PM
Whoboy580
06-09-2011 04:12 PM
Tony89GTA
08-29-2010 01:03 PM
Jared11
11-02-2009 01:34 PM
Quick Reply: finally alstons and bmr subframe installed with pics
