"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Old 05-22-2010, 05:51 PM
  #51
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
Can I chop my front stock springs??? Figured you guys know your stuff......
Picture103.jpg?t=1274567992
Already redoing the whole front suspensioin: Control Arm bushings, KYBGR2's, End link bolts/bushings, sway bar bracket bushings and new ball joints..... Can I Chop the front STOCK springs?
Old 05-22-2010, 05:56 PM
  #52
Stephen's Avatar
Car: 87 GTA
Sure....I've done it on stock springs & gone autocrossing with no problems. What do you think think people did before aftermarket lowering springs came out?
Old 05-22-2010, 06:15 PM
  #53
Cut at the top or bottom of the spring? How will it seat? Forgive me I am ****-retentive and know you guys know what's best. My Previous post shows she's stripped and ready! How to get the best seat?
Old 05-22-2010, 09:06 PM
  #54
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I'm going to be doing this to the rears when the 2" drop spindles go in... It's safe if you take your time and very importantly DO NOT heat up the spring too much or you will weaken it.
Old 05-22-2010, 09:35 PM
  #55
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
2" drop Personally this is the lowest I would go in terms of springs.
Old 05-23-2010, 01:10 AM
  #56
Str8upChevy's Avatar
Car: '91 RS, '72 Pro/Street Z28
Engine: 305 TBI, Blown 468ci w/NOS
Transmission: 5 Spd, 2 Spd Powerglide
Axle/Gears: 3.08, 4.88
Originally Posted by diablood5
how bad is the ride with that much cut off? does it bounce alot?feel realy bumpy on the road
Anytime you cut that much off a spring it's going to change the spring rate and make it more stiff. If you're concerned at all about ride quality, I wouldn't cut anymore than a 1/2 to 3/4 of a coil.
When I first drove it down the road after lowering it, I thought hmmmm.......that feels a little more stiff than I expected. But, after driving it around for another 10 minutes, I realized it wasn't as bad as I thought. I was just so use to way it rode before that it took me a few minutes to get use to it. Not only that, I have air shocks in the back with ALL the air let out of them. I believe as soon as I install some regular shocks, it won't be that bad at all.
Cut the bottom of the spring. When you go to reinstall them, make sure you put the tapered (non cut) end up into the K-member, and the cut end down in the A-arm pocket.
Now, when it comes to indexing the bottom of the spring down into the pocket, I think "most" people will tell you to point the cut end towards the back of the A-arm and line it up between the two drain holes. (I'm not one of those people)
Here's the the reason why,......when I did it that way, it did NOT lower my car AT ALL, even after cutting 3/4's of a coil off my springs. But, as soon as I turned it around and pointed the cut end towards the outside of the car, it dropped it down about 3/4 of an inch. I ended up cutting another 3/4 of a coil off to get a full 2" drop.
I think he's referring to "not letting your springs get hot while cutting them". I wouldn't recommend using a torch to cut them unless you have a plasma cutter. Regardless, I would use a bucket of water and only have a couple coils sticking out if you do use a torch. I actually put my springs in a vice and used my compressor with a 4" cut off wheel. I cut halfway through then waited about 2 minutes, then I cut the other half.
Old 05-23-2010, 09:55 AM
  #57
Oops, sorry I was not clear! That is what i meant, while cutting, do little by little as to not overheat the coil too much while cutting!
Old 05-23-2010, 12:44 PM
  #58
Guest
Guest
Posts: n/a
24 3/4" front fender lip height. 26 " rear fender lip height.
16x8 factory IROC wheels and 245-50/16 tires
The front wheel wheels still hav ethe factory plastic liners and the wheel on the drivers side has barely scraped the plastic in all the hard street driving I have done and road course playing I have done in this car in the 6 years I built it and drove it.
As low as this car is, you can pound it on the street, drive it fairly normal over speed bumps, and it pulled 1.07g's on a skidpad on street tires.
Old 05-23-2010, 06:17 PM
  #59
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Front springs are clamped for now and rears had 1.5 coils cut off. Getting a tubular k-member and coilover kit from BMR soon.
Old 05-23-2010, 07:00 PM
  #60
That's a nice ride! Just out of curiosity, did you have to cut the rear lip off or roll it under in order for your tires not to rub?
Old 05-23-2010, 07:05 PM
  #61
pwdbychevy's Avatar
I rolled it old school style with a heat gun, dead blow hammer, masking tape and a 2x4
Old 05-31-2010, 12:34 AM
  #62
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
This was original stance, but it was just to low, lower air dam was hitting everything, put a taller front tire on and solved the problem
Old 05-31-2010, 01:40 AM
  #63
WOW, three major improvements on your car........the taller front tires, the Convo Pros, and getting rid of the 3pc rear window louvers. (Just never been a fan of the louvers)
That thing is simply badass!!!. The fact it's tubbed and has Convo Pros makes it my second favorite car on this site. If it had a blower sticking out of the hood it would definitely be my favorite.
Old 06-07-2010, 01:49 AM
  #64
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
here is my project befor and after
Size:  8.2 KBName:  DSCN2404.jpg
it has the hotchkis springs, hotchkis strut tower brace, hotchkis tie rod and center link set and the hotchkis adjustable pan hard bar with kyb shocks and struts...
the tires are much wider now then in this pic
Old 06-08-2010, 05:45 PM
  #65
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My car has always sat high since I put the IROC springs in it. When I redid my ball joints and went with poly a-arm bushings I cut my IROC springs and it sits a good bit lower, but it just looks stock. Cut half a coil in the front, 1/4 coil in the rear and removed the rear isolator.
I think I may just need real lowering springs. And yeah, I had them indexed properly.
Old 06-08-2010, 08:53 PM
  #66
"HOLY WHEEL GAP" Batman, that thing sat up high!!! My car sat lower than that before I cut 2 coils off the back, and 1-1/2 coils off the front.
Old 06-08-2010, 08:58 PM
  #67
Actually my car settled down a bit after those last pictures I posted. Here's what it looks like now:
Old 06-09-2010, 01:58 AM
  #68
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
eibach sport line. soon will be sporting konis sports. my kybs are shot !
Old 06-09-2010, 12:04 PM
  #69
Damn that purple 91 RS is a bit too low for my taste! must bottom out on everything no?
Old 06-09-2010, 03:15 PM
  #70
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Pro kit:
Old 06-09-2010, 06:46 PM
  #71
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
VERY nice, IROCThe5.7, but why in the world don't you shine that car up a bit .
JamesC
Old 06-13-2010, 12:11 PM
  #72
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
you cut your sportlines? it sits really nice.
Originally Posted by Mongoose
Here's mine, Eibach Sportlines with 1/4 coil trimmed from the front.
Old 06-16-2010, 02:17 PM
  #73
Kat
Kat's Avatar
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Spohn coil over kit (275 lb springs 12") and cut nnl springs in the rear.. Since the pic I've raised the front just a hair to make the car more level. That and I needed the clearance for the mufflex 3" y pipe that goes around the spohn torque arm and x-member.
Old 06-17-2010, 12:01 AM
  #74
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Here is mine... Intrax springs with KYBs all the way around. Coilovers go on this upcoming winter, 19s go on in one month. Will repost pics after the rims arrive.
Old 06-17-2010, 09:00 AM
  #75
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Dropzones here and they get the job done
Old 06-17-2010, 09:27 AM
  #76
Twin_Turbo's Avatar
My latest one, it has Eibach Sport Lines. Needs a little meatier tiers, especialy on the back.
Old 06-17-2010, 10:20 PM
  #77
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Old 06-20-2010, 07:47 AM
  #78
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I've had Eibachs on my other cars and I'm always a bit leary. The quality is always nice, but the spring rates can be way off. I had the ProKit on my '93 Beretta GTZ; The ride was still decent but the drop wasn't as much as I wanted. I bought Sportlines for my '04 SRT-4 and it was too low and bounced like crazy. I had to switch back to stock.
After that experience, I'm leaning more towards the ProKit, but don't want to be disappointed with the drop.
Who knows.
Old 06-20-2010, 07:49 AM
  #79
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Originally Posted by WASyL
to low, with this paint and lowering it starts to look like riced honda
best regards
I don't necessarily think it looks Honda, but there is something about the look of the drop that can only be described (by me) as "uncomfortable". It looks like it'd scrape everywhere and bounce your fillings out.
Don't get me wrong, its a ThirdGen, so I dig it; just my $.02.
Old 06-20-2010, 10:06 AM
  #80
r1lorenzini's Avatar
OK so as a new owner of a third gen with a stock stance this thread is great but USELESS Without everyones tire size!!! How am I suppose to know what my wheels will look like without knowing what size tire is on your car? LOL oh by the way all the lowerd cars look SICK!!
Old 06-20-2010, 10:47 AM
  #81
Stephen's Avatar
Car: 87 GTA
Who knows.
And all tat is why my Ground Control Weight Jacks are so nice. Ride height & spring stiffness are 2 separate things. I get the stiffness I want, then adjust the ride height to where *I* want it, not where the manufacturer decides where it will be.
And if I decide to go higher or lower? That is just a turn of a wrench away. If I want stiffer or softer springs? Only $55/each, so I can buy just fronts or rears & not a full set.
Old 06-20-2010, 11:31 AM
  #82
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
15x4 26 x 7.5-15 Sportsmans up front and 15x10 275/60/15 Mickey Thompsons in back.
Old 06-20-2010, 04:18 PM
  #83
Well I can see where dome
people don't want to make it into the 21st century I mean ok the 22's are pretty ghetto but not sure when the Kay time you were at a dealership but most sport cars now have 20's stock. I digress back to topic anyone lowered on 20's? Nevermind the 22's doh!
Old 06-20-2010, 05:02 PM
  #84
MParks's Avatar
Car: 1987 Red IROC-Z Hardtop
Engine: Bolt on 305TPI
Axle/Gears: 3:23
question, how low can you go before you need to buy struts/shocks/panhardbar ?
Old 06-20-2010, 05:49 PM
  #85
Stephen's Avatar
Car: 87 GTA
My 87 GTA coulda used an adjustable panhard bar at stock height.....Some people are fine lowered. A lot of that depends on how tight you want the wheels to fit....Like me stuffing 315s on 11s completely under the fenders. I HAD to get an adjustable panhard bar.
I'm lowered about 2" & my shocks & struts don't bottom out at all. I've never HAD to replace the shocks or struts after lowering.
You don't HAVE to replace any of that when lowering a 3rd gen.
Old 06-20-2010, 06:04 PM
  #86
MParks's Avatar
Axle/Gears: 3:23
Ok, I just bought cut springs (640lbs) and stock iroc springs i think are rated at 650lbs. the stockers im going to use for a higher rate later down the road and throwing on the cut ones that were on another guys autocross car. I have unknown Bilsteins in the back they are old lookin, and unknown struts in the front but they are pretty stiff, i should be ok with the cut ones right? they are not a huge drop. Im ordering koni yellows this week so its until i get them i wanna toss them on. Btw your car looks WICKED
Old 06-20-2010, 06:21 PM
  #87
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Ground Control suspension setup at full drop.
Old 06-20-2010, 08:34 PM
  #88
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
That does not mean anything if their on newer cars, those cars are a different style and body then what our third gens are. Put 17/18's on them and watch them look out of place or plain out bad. Point is, the magic size for our cars are 15/16/17's. Some can pull it off with bigger wheels but that is going over the line of flashyness vs good design.
Old 06-20-2010, 08:48 PM
  #89
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
and the newer sportscars are freaking tanks that dwarf the 3rd gen, hence the larger wheels. the tires are usually 28"+ in diameter. 3rd gen uses 26" tires.
20's can be done and look fine, but it has a lot to do with the style wheel and what tire is used, never seen anything larger that looks right. the ride quality is pretty bad with a wheel that larger with such a thin tire
Old 06-20-2010, 09:40 PM
  #90
Anyway, my suspension is stock at the moment with cut springs, and my wheel/tire combo is below:
Wheels
15x8.5" (rear)
15x4" (front)
Tires
265/50/15 (rear)
165/R15 (front)
Old 06-20-2010, 10:14 PM
  #91
camro91's Avatar
Car: 91 Camaro
Engine: 383
Transmission: 700 r
Axle/Gears: 373
I agree
Old 06-21-2010, 01:11 AM
  #92
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
how does this car ride after this?? my 83 z28 has the iroc springs and its sets like a s10 pick up i could run 31's lol. i love the look of ur car.
Old 06-21-2010, 03:03 AM
  #93
Thanks for the compliment bud! Surprisingly enough it doesn't ride all that bad. It felt a little stiff at first, but I got use to it within minutes of driving it around. (I don't even notice it anymore)
If it was my only car I may not have gone that low,....but since it's not, I decided to go ahead and drop it. Basically I just go over speed bumbs a little slower and pull into driveways at an angle. I don't think that's too much of a sacrifice for having a bitchin lookin ride. Well, semi/bitchin lookin anyway.....I still need to paint it black after I put my cowl scoop on.
Old 06-21-2010, 05:52 AM
  #94
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I dropped mine 2 inches from stock worn out springs.. It does have a little bit of a rake, aswell.. I gotta get some new pics..
okay (06-16-2020)
Old 06-21-2010, 11:13 AM
  #95
ok so with a 27 inch tall tire to be exact how many coils are cut from the stock springs?
Old 06-21-2010, 11:17 AM
  #96
Also for all the old timers who are not sure what that purple car is heres an explanation. Once again an explanation not my taste or would I ever drive one. Those are called DONKS...They get the name from donkey kong as in "really big" they get big lifts and wheels. THe wheels int he pics I think are lexani's and they only come in 27's So those are presumably 27's with a monster ish 4 inch lift. They only lift the car to get the bigger wheels to fit. It defenitely looks silly but it is not cheap so dont mistake poor tase or bad looks for CHEAP lol.... Anyhow the original thread dudes car looks sick with 15's and I actually think its sorta hard looking. That is a good thing as for me I will be putting the 20 inch irocs on my new 3rd gen and lowering after I put the wheels on. I was hoping to get a meatier sidewall but price is envolved so a 35 series will have to do hence the 27 inch tall tire. THanks guys
Old 06-21-2010, 12:25 PM
  #97
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
r1, that pic of the blue convertible you posted does not have an LS1. Your thinking of a different blue convertible.
Old 06-21-2010, 02:47 PM
  #98
MParks's Avatar
Axle/Gears: 3:23
Screw it, here's a couple of how it sits right now. I'll definitely take some better pics after I cut more off and get rid of all that wheel gap.
Are you ridin on stock struts and shocks??? panhard bar or anything? if not im tossing on my cut springs!!!!!
Old 06-21-2010, 02:49 PM
  #99
MParks's Avatar
Axle/Gears: 3:23
Well, I finally got around to pulling my springs out and cutting them today. I had to cut a total of one and a half coils off the front springs, and two and a half coils off the back to achieve the ride height I wanted.
The only thing I need to do now is have my exhaust pipe modified. It sits too low directly after where the two pipes come together. (Between there and the Cat) You'll see what I mean in the last picture. It's only 2.25" inches from the ground as of right now. There's enough ground cleance everywhere else to handle such things as speed bumps and pitched driveways as long as I go slow. (which I obviously will)
That pack of smokes is exactly 2-1/8" wide, so yeah,......2-1/4" is definitely not going to cut it. I'll be raising the exhaust up tomorrow!
Sorry meant to reply to this one where its lower
Old 06-21-2010, 05:56 PM
  #100
Quick Reply: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
