finally upgraded shocks struts and more
Old 05-19-2010, 05:28 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
well i just ordered the following at summit
kyb gr-2 front struts
kyb gas adjust rear shocks
moog 5665 springs
moog 5662 spring
poly endlink swaybar bushings
http://www.summitracing.com/search/?...=9-8105r&dds=1
http://www.summitracing.com/parts/KYB-236001/
http://www.summitracing.com/parts/KYB-KG5562/
http://www.summitracing.com/parts/MOG-5662/
http://www.summitracing.com/parts/MOG-5665/
hopefully all this will make a big difference in handling and the way the car moves over the stock worn out parts....
Old 05-19-2010, 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: finally upgraded shocks struts and more
So there'll be no surprises, note that the rear Moog's will jack the car up considerably. I was forced to replace the insulator with radiator hose--and cut a bit of coil--to reduce ride height to a reasonable amount.
JamesC
Old 05-19-2010, 07:14 AM
88fastgta's Avatar
yeah i heard about that... ive also heard that some people didnt notice a difference.... i dont mind it sitting higher because right now my exhuast scrapes the littlest of speed bumps and i have to put a thin board underneath the car to get into my driveway and into the garage so i wont damage my exhuast.. i really hate that.... so 1 or 2 inches higher would be just fine for me....
Old 05-19-2010, 07:22 AM
JamesC's Avatar
If you don't mind, then you're golden.
JamesC
Old 05-19-2010, 07:27 AM
88fastgta's Avatar
did it look out of place with you....... how much space was there between the tire and fenderwell......
Old 05-19-2010, 07:39 AM
JamesC's Avatar
To be blunt, I hated the look. From ground to the center of the fender well was 28 1/2 (I waited a year for the so-called 'settling' process, which never happened). I felt like I was driving a 4x4 instead a great-handling car. Current pic with Moogs front (26 5/68) and rear (27 1/4).
JamesC
Old 05-19-2010, 07:44 AM
88fastgta's Avatar
thats how mine sits now... i have about 3.5 inches of gap...... i really cant let it sit any lower cause if it does my pipes will be scraping all the time....... we will see friday when i install them....
J-money
01-04-2019 09:45 AM
rb85TA
26
09-14-2015 10:29 PM
87camaro87
09-09-2015 10:29 PM
89 formula TPI
09-08-2015 08:00 PM
SG91camaro
09-05-2015 10:27 PM
Quick Reply: finally upgraded shocks struts and more
