Iroc Suspension Upgrade?
Old 07-19-2010, 01:52 AM
1991-RS's Avatar
I just bought a 1991 RS convertible for $850
and was wondering what I would need to upgrade it
to have a iroc suspension?
Thanks for any help.
Old 07-19-2010, 02:02 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Iroc Suspension Upgrade?
Springs
Shocks (rear)
Struts (front)
Wonderbar
Sway Bar (front and rear)
I would suggest just saying screw it and going aftermarket with the first four of those, and do the best you can. The money it would take to build an IROC copy would be barely less than a kitted out aftermarket setup that would be much better. Not to knock IROC suspension cars by any means, just saying that to piece it together will cost you quite a bit. Plus IROC shocks/struts/springs are gonna be old by now.
Im a big fan of junkyard sway bars though. I got my 34mm IROC front bar for $8. Some of the RS's had the big sway bar standard up front. It will eitehr be like 29 or 31 mm or something like that, or it will be 36mm. If 36 - just leave it alone.
Old 07-19-2010, 02:11 AM
1991-RS's Avatar
If I need the sway bars and wonder bar will they just bolt up or do i need to change alot of things?
Old 07-19-2010, 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. Bolt up (If you install different sway bars, you'll need the appropriate bushings as well).
I mistakenly hit the edit button on your previous post. My bad.
JamesC
Old 07-21-2010, 02:21 AM
1991-RS's Avatar
Whats the difference from a iroc suspension and a f41 suspension?
Thanks for the help.
Old 07-21-2010, 01:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Given it's age - the first suspension dollar I would spend would be on the basics. You can assume that for $850, there's never been any suspension work done on the car (I'm actually amazed you got any vert that runs for $850 - I never see them for less than $3000).
Do tie rod ends, ball joints first (that will run you about $200 for good stuff). Check idler arm and centerlink when doing tie rods ends, and replace if needed. Then get a lifetime alignment - costs a few bucks more, but you'll get free realigns for life.
Then get the sway bars you want and do sway bar end links and sway bar bushings. Can do the wonderbar at this time - it simply bolts to the front swaybar connections.
Then get shocks, struts and springs. Might as well do all these at once, or at least the front struts and springs at same time. I'm running Bilsteins all around and Eibach springs, and I love them - about $1000 for that spring/shock/strut combo.
Given that it's a vert - you should seriously look into sub frame connectors - but I wouldn't do them until after the rest of suspension is done. You can get bolt-on sfc's, but they are best welded - many folks do the bolt-ons and then have them welded in place to save shop labor. The sfc's tie the car together, reducing the flex common in a unibody car. But you want the rest of the suspension to be set good first, so that the sfc's are welded in with the body straight and loaded properly.
Old 07-21-2010, 02:21 PM
1991-RS's Avatar
The tie rod ends, ball joints, idler arm and centerlink are all in great shape.
Im looking for info on whats the difference of the iroc suspension and f41 suspension.
Is it the same just with out the wounderbar? Thanks For any help.
Old 07-23-2010, 05:14 PM
1991-RS's Avatar
Does anyone know if the 1985 Iroc G92 wonderbars are different then the others?
Old 07-23-2010, 06:01 PM
JamesC's Avatar
An OE Wonderbar is an OE Wonderbar.
JamesC
Old 07-23-2010, 06:19 PM
1991-RS's Avatar
Thats what I thought but the one I just bought off a 1985 G92 Iroc looks different then any other one I have seen on other year irocs.
Old 07-23-2010, 06:26 PM
Clutch-Burner18's Avatar
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 3.45 borg warner
Sorry to jump in on this thread, but I have recently installed a 383 into my 87 camaro. My stock springs are sagging and when I brought it to a shop, they said that nothing could be done. Is this true? Is there no set of springs for this car that can handle the extra weight of my 383 without sagging, or was I misinformed?
Old 07-23-2010, 06:35 PM
JamesC's Avatar
In what way (we're talking about the steering box brace, correct?)? Have a pic?
JamesC
Old 07-23-2010, 06:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
the 383 as no major extra weight than any other small block. You can swap in any number of difference springs, lowering, stock height, weight jacks, ect.
dont go back to that shop again.
Old 07-23-2010, 07:33 PM
1991-RS's Avatar
Originally Posted by JamesC
In what way (were are talking about the steering box brace, correct?)? Have a pic?
JamesC
Its a stock wonderbar but it looks different. I will try to post pics of it when I get it. Its not a aftermarket part.
Frozer!!!
01-19-2024 04:55 PM
sweet_87_iroc
09-25-2015 10:01 PM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: Iroc Suspension Upgrade?
