Mini tub for a road race car in progress
#51
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Re: Mini tub for a road race car in progress
Only data I have is 27 years of experience building drag cars. With that said, all of the tubing types listed in this thread is not even legal in the type of cars we build at work.We are only allowed 4130, talk about expensive! DOM should be fine for this application, given satisfactory construction and welds, as you pointed out. Given my choice and I was riding in the car, it would be CDS. That is some tuff stuff. I'm going to say it again, ERW has no place in rollcage construction.
#52
Car: Turbo Buick
Engine: 3.8 V6
DeanJ, I do have road race in the title but a more accurate title would be "Time attack/AutoX/DE car" since I do not plan on doing any wheel to wheel stuff with this thing. I will take your concerns about the bar into consideration. I think the concerns about potential defects are certainly valid. You gave an example of the seam not being welded properly on some ERW tube you saw. Could the same thing potentially happen with DOM considering that it starts life as ERW? Also, how many cage failures have occurred due to use of ERW that you are aware of?
#53
Car: Turbo Buick
Engine: 3.8 V6
Got some new goodies in the mail, just mocked them up:
4.9 lbs
It would be a fair amount heavier if I had poly on both ends
2.22 lbs
Not a bad little weight savings for some partially unsprung weight. The main thing is that at the shortest adjustment, the LCAs are 1.25" shorter than the factory. I might be able to shorten them that much without bottoming out my driveshaft. I will have to run it through the range of motion to see what I have.
Didn't get a chance to do anything to the car today. I had to put in some overtime at work. Hopefully tomorrow I will get some good things done
4.9 lbs
2.22 lbs
#55
Car: Turbo Buick
Engine: 3.8 V6
What kind of things were you thinking of?
#57
Car: '88 Camaro (Gone...)
If you feel charitable and just want to try the lathe out, I have a little project I could outsource to you
Nothing complicated, I just need a plug made for a speedometer port in a 700R4 Super not top-secret non 3rdgen related project going on with that
Pretty please I'll pay for material cost
#58
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
4130 is not for the amatuer or back yard builder. It is very strong for its weight. You can use thinner wall. We build ProMod cars and it is the only tubing that we are allowed. Molly requires a very specific fitting and welding technique, that is probably why it is not allowed. Read in my earlier post where I said if I had to ride in the car I would use CDS. The CDS is some tuff stuff. Dean
#59
Engine: LS6
#60
Car: Turbo Buick
Engine: 3.8 V6
Well I got some spacers for the rod ends and put them on the car. I managed to bring the rear axle forward just about the full 1.25 inches and have .25 inch of room for the driveshaft yoke to move in and out of the tranny. I moved the rear axle through the range of motion and I believe I have enough room.
The great news is that now the spring mounts line up. So I put the springs in. Just to see how low it would go I cranked the adjusters all the way up, threw on the wheels, and set the car down. Here are some pics:
The flash makes the "paint" look even worse
I would like to lower the front to match the rear but I'm afraid Ill cut a tire since they stick out slightly. The goal is to eventually get stepped outers for my wheels and run 18s up front so I can tuck them more. With that I will be able to bring the rears inboard about a half inch at least for proper symmetry. I will probably just raise the rear to match the front for now.
I also fixed my shock issue:
I ended up taking a nut, welding a washer to it, and then welding the broken stud from the original shock mount to the top of the nut. Yep... My welds look like poop but I just need it to hold. The washer is what the bump stop will hit once I put it on the shock.
Other than that, I didn't get much done today. I was really beat from putting in extra hours from work this past week.
#61
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
What did you do to get the fronts to fit? I had 275's on 17x9.5's (Zr1 replicas) and they rubbed ever so slightly.
Something else to consider for checking clearances, especially if you're doing time trials, is tire sidewall flex. Granted it will be less on than 16's, but here's a surprising video of my car on 255/50 16 Toyo R888. Hoosiers should grip even better tho are probably much stiffer than these.
http://www.youtube.com/watch?v=g70n7IOcQpA
#62
Car: Turbo Buick
Engine: 3.8 V6
I'm running 5.5 inches of back spacing on the front after the use of some spacers. So I am very close to the tie rod end but in reality not any closer than I was with 17x9 SS wheels.
#63
Car: 95 Camaro Z28
Engine: Need one
Transmission: auto
That looks really good actually. Ya, it's a little rough, but who cares? Like you said, it's easier to go nuts when you have nothing to lose. Awesome job! Love it!!! Any plans for ladder bars?
#65
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
Looks awesome...where did you get the tubs from.
#66
What's the scrub radius like on your set up pablo
#69
