Who makes the better strut mount?
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Hi guys did a few searches and came back with no results. was curious as to what everyones opinion on the best strut mount and why. ive looked at these so far.
http://www.spohn.net/shop/1982-1992-...ut-Mounts.html
http://www.umiperformance.com/catalo...hgl0viul2sdcr0
http://www.hawksthirdgenparts.com/ca...ountspair.aspx
http://www.foundersperformance.com/p...er-Plates.html
The hawks and Spohn seem to be the same design but i know appearances can be deceiving.
Re: Who makes the better strut mount?
These are the best you can buy IMO. I and others have had them and they are fantastic.
http://www.hotpart.com/shop/index.ph...duct_list&c=16
Just clicked through your links, I'm 99% sure these are the same ones shown on Founder's website. If they are the J&M parts and that price is right, I'd buy them now before they find the typo....
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Wow.. Even the description on the Founder's page is almost identical word for word, except for the "made in USA" part and the warranty. Hotpart are made in USA, everything else from Founders is imported and based on the price I'm going to guess these are too. Founders warranty is for "the main plate bending", Hotpart's warranty includes the bearing too. I don't know how you'd bend 5/16" steel in either one in anything less than an accident, the sheet metal its bolted to is probably only a quarter as thick.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Anyone running these strut mounts with coilovers? I'm going with the racecraft coilover kit here:
http://www.racecraft.com/index.php?m...roducts_id=516
Wondering if they would work with the founders kit and save me $120 over buying the racecraft caster/camber plates then.
Car: '88 Camaro (Gone...)
The UMI version is a blatant copy of J&M's innovative design, they didn't even try to hide it. I'd go with J&M/Hotpart over them, the quality of UMI's parts may be good, but they simply stole the design. Boo
---xpndbl3, I have a pair of Afco coil-over sleeves and spring seats (Like Shagwell runs) if you are interested, you can piece a kit like Racecraft's together for less. Just P.M. me if you're interested
Car: 1984 Z28
just ordered it from racecraft this morning and it shipped out already....wish i would have known, I looked all over on here and other places for a used setup but no new threads about it.
Guess I'll pickup the founders one later tonight since everyone seems to be running them without issue with coilovers.
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Educate me here people related to these top strut mount comments...Are they for coil overs ? I'm looking for coil over struts for my 89 F body. Has anyone tried QA1 ? And what mods do I need to do for coil overs ?
Car: 1989 GTA
Engine: 5.7 ltr.
P.S...How much car handling difference do you see with coil overs vs. already having the WS6 suspension package ?
Car: 1984 Z28
no handling difference it's for ride height adjustments mainly. I wouldn't put anything QA1 on my car when it comes to shocks but that's my opinion only. Strut mount caster/camber plates are for more adjustability when it comes to alignment settings only.
The strut mounts improve handling & feel, by eliminating the rubber bushing & "slop" found in the stock ones. Some strut mounts also improve performance on lowered cars by raising the mounting point for the strut, & extend the strut's life.
Unless it's a drag car, where the weight savings & weight transfer come into play, I'd stay away from coil-overs. Or you can research & decide for yourself
Car: 83Z28 HO
Transmission: G Force 5 speed
Can someone tell me what I'm missing here? It looks to me like the UMI,Founder's, and HotParts strut mounts all have the identical adjustibility. Maybe one or two of them say "Made In The USA" , or the warranty differs slightly....but all three have sperical bearings etc...
Looks to me like the Founder's set has everything the HotParts and UMI sets have PLUS they're cheaper...so what's the advantage of buying the Hotparts set??
Is it the "Lifetime" warranty on the Hotpart ones?? How often do these wear out anyway??
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
I dont see the plate ever being a problem, but with really hard use i can see the bearing wearing out and thats apparently covered by hotpart/J&M.
Founders is still pretty new and im not sure if the quality of the bearing is the same.
Only peeve i have with J&M's is its powdercoated in a satin black color, which doesnt match the rest of the parts on my car that are gloss, but its really not that big of a deal.
Car: 83Z28 HO
For instance, I bought a new Samsung LED TV about 6 months ago. Now every brand of TV has LED televisions, plus they have the 3D thing now. Doesn't mean I won't ever buy another brand of LED TV except for Samsung since they were the first to come out with it (as far as I know)...but they don't have trademarks like we do.
An even more extreme thought along the same lines - Ford was the first to perfect the assembly line for manufacturing automobiles...which drastically reduced the price of the final product to the consumer. Others followed suit because THEY HAD TO COMPETE, or go out of business. But I don't presently own a Ford.
The whole bad part to all of this "copy cat" thing, is when foreign countries produce a very simular or identical product for a cheaper price of what a company in the US can. Or even worse, make a better or more reliable product ...can you say Honda, Toyota - back in the eighties??? Luckily, over the years, American engenuity prevailed, and I believe our cars are as good if not better than what the foreign countries are cranking out.
I'm pulling for the USA like everyone else in this country, Hell, I gave years of service in the military to defend our values, ideals etc. in this country. So I'm pulling for the US to remain a wworld power and I hope everything we produce is top notch, and everyone around the world wants it.
But -it's also a harsh world out there - but I think we can meet or exceed any other countries product, price etc. if we really try. We've done it before. Just MO..
Sorry - I kinda drifted there....
//<86TA>\\ - Yeah, it makes sense if you are going to autocross or something and they are the only ones to warrant the bearing itself.
I've seen tons of "made in the usa" parts that are obviously from China. Wanna know how? Us foreigners when buying from Summit and the like get a list of ordered parts w/ country of origin listedm has to do w/ homeland security or something.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Made in the US can simply mean assembled in the US yet still using Foreign produce parts like from China, either way still looks like a good piece.
Car: 1984 Z28
mounted the founder's performance mounts the other night....
They look good to me and fit my coilovers no problem.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The Founders piece looks different from their website photo.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
If you look at lca's and panhard rods, seems like UMI, Spohn and BMR all look the same. Hard to say who copied who.
That is true, but it's hard to come up with a unique or revolutionary design for a bar with two holes on the end of it, lol. Some of the different companies do offer different designs for how their adjustable versions are set up though (some are much easier to adjust on the car), and have different designs for their teflon-lined spherical ends
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i just installed some UMI ones..why over the J&M? cuz UMI is having a sale on em right now! $185
i have a setup from J&M, and one from UMI, both are nice.
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Now my only problem is my car still makes a groaning noise when turning -.-
Car: Turbo Buick
Engine: 3.8 V6
FWIW I have the spohn mount and it allowed me to get about 1 degree more negative camber than I had with stock mounts.
The downside is that on my car, the mount is making contact with the master cylinder and master cyl reservoir. Not really the most comforting thing. I will have to modify the mount to correct this problem. This will probably not be a problem for most people installing this mount as they will not run as much negative camber as I do. But then again, if you don't need that much neg. camber then I don't think you really need these mounts. You aren't asking much of your turning ability already via your camber settings. I think the only reason to get them is if you absolutely need more neg. camber and your car is lowered (to regain some strut travel). The spherical bearing is neat feature but imho is not a huge improvement in the grand scheme of things.
Can't speak badly about any of those brands, but I have lots of UMI parts on my car. They're all made well, and their customer service is great. If they came out with a part I needed, I'd almost goes as far as to say I'd buy it sight unseen based on my previous experience with them.
Just my 2 cents!
Just my 2 cents!
I ordered UMi's this past new years weekend since they were having a sale. Summit had the black ones for 196.00 and after 15% they were 168 or so, so overall a great deal. I didn't like how they only 1/4" instead of 5/16" like the founders but since i ordered more pieces i also saved on shipping.
i had pics, im trying to find them
Car: Turbo Buick
Engine: 3.8 V6
the later ones, from the 98-02 cars have the right threads, and are pretty much a bolt on, you have to tweak the lines a little, or unbolt the prop from the booster and pack it off a little. Looks a lot better than the stock one too.
off hand, i would be inclined to say yes, but i can run outside and measure the 2 cars and see what extra room there is and get back to you.
just a quick measure (its freezing outside) , but at least 1/4" from to the top of the tower to the ls1 reservoir at the front of the reservoir
I bought the Founders units and they look like really nice pieces, the welds looks good and I don't think there will be any issues with these. I am using a number of different manufacturers with all the parts I am putting on car and I can say that I haven't any complaints with any of them. For me price was a big consideration as well the quality of the parts I wanted. I don't feel you have to spend big money to get good parts, you shop around for the best price for the part you want, somethings I got from members here that either changed their mind on their project or needed money for something else. Parts I bought from manufacturers I waited for sales and got some great deals as well. I have parts from UMI, Founders, BMR, Spohn, Lakewood, Edlebrock, and KYB. I have more time than money so I was patient and watched for the deals I wanted.
Car: 89 IROC
I like waiting for UMI's sales throughout the year. 15% off pays for my shipping
Car: 1984 Z28
ls1tech should have a few of them for sale from cars being parted out
I'll double check today, since it should be a little warmer and my fingers wont freeze off, but 1/4" for sure.
Car: Turbo Buick
Engine: 3.8 V6
Kind of hard to tell and there are no specs out there for it.
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
sorry im bringing this back. why not just get the orig looking ones? is there something better about the hotpart/founders??
#42
The following from Spohn's site:
These fabricated front upper strut mounts for the 1982-1992 F-Body Camaro and Firebird feature a chrome moly spherical bearing with a Teflon® self lubricating race. We have also built an extra 1/4" of negative camber adjustment into the mounts. The mounts feature CNC machined components and are precision welded. We even include stainless steel mounting nuts!
The mounts are 1" taller than stock to provide extra strut travel for lowered and non-lowered cars. A must for those looking to do some serious corner carving, and you can't beat the trick look they provide to your engine bay!
JamesC
#43
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Did any of these companies ever get around to making a strut tower brace that fits the Holley Stealth Ram?
#44
#47
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
How much added strut travel do the Founders, UMI, and J&M provide over stock strut mounts? I see that the Spohn strut mounts advertise a 1" increase in height.
