Anyone here have BF Goodrich G-Force Z rated tires on their car?
Old 12-10-2001, 08:41 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I am thinking about getting them for my car. I can get them for about $116 a piece. I have BF Goodrich Comp T/A ZRs on the car now, and I liked them alot. but they discontinued them now and the G-force is the replacement. I just want to know how they are.
Thanks!
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs; Removed Smog Pump and all other Smog related parts.
Old 12-10-2001, 10:26 PM
Camarokid01's Avatar
My brother just got them for his 95 Z28 they are really nice tires they have a cool tread patern and they ride very nicely I would suggest them.
Old 12-11-2001, 06:51 AM
Engine: ZZ4 - 350
Thanks CamaroKid01! They do have a nice tread pattern! I think I am going to get them.
Take care
Mike
Old 12-11-2001, 04:52 PM
jmon92conv's Avatar
I ahve them and love them. I autoX and could really tell the difference compared to the Comp TA's I had.
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old 12-11-2001, 08:03 PM
Engine: ZZ4 - 350
Thanks Jmon, I am getting them for sure.C-ya
Mike
Old 12-11-2001, 08:16 PM
88greyiroc's Avatar
i will tell you about a tire i found to be unbelievable was the pacemark directional tire that you can get at canadian tire you wouldn't think that they would be good coming from there but i could notice the better handling and cornering those tires give my car not to mention there durability i could smoke them all day and bairly scrath the treads this is my 2 scents but these tires are remarkable.
1988 Iroc-z (Gun MetaL)
350TPI (38K MILES)
700r4 stage 2 shiftkit
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old 12-11-2001, 08:57 PM
Engine: ZZ4 - 350
Thanks 88greyiroc. I have never heard of them. I will check it out.
Later
Mike
Old 12-12-2001, 12:25 PM
LimaBravoNiner's Avatar
Car: 89 GTA, 89 Formula
Engine: L98, LB9
Transmission: Auto, 5-Speed
WC GTA,
I too went from Comp T/As to the G-Force KDWs. The KDWs are very nice tires. I think they basically do everything better than the old Comps. Ride, handling, & noise are all improved. Only bad thing is that they aren't offered in P255. I had to go with P245/50ZR16 on all four corners. I plan on auto-Xing them in the spring too.
1989 Formula
305 TPI/5-speed
White/Grey
Old 12-12-2001, 04:35 PM
Engine: ZZ4 - 350
Hey Limabravoniner, Thanks for the info. Sounds like it is a good tire. What is Auto-xing????
Mike
Old 12-13-2001, 07:00 AM
Engine: L98, LB9
Auto-xing = autocrossing
Ya know, SCCA Solo II type stuff (driving around temporary road coarses set up in parking lots).
Check this out:
http://www.scca.org/amateur/solo2/classes/index.html
1989 Formula
305 TPI/5-speed
White/Grey
Old 12-13-2001, 04:13 PM
Engine: ZZ4 - 350
Thanks LimaBravoNiner - I saved the site and will check it out later.
Later
Mike
Old 12-03-2008, 08:08 PM
bonddav's Avatar
Re: Anyone here have BF Goodrich G-Force Z rated tires on their car?
i was looking for p245/50zr16 but bfgoodrich did not have it in the kdw g force they had it in a 245/45zr17 were did you get them in the size 16
Old 12-03-2008, 08:31 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
this thread is about 7 yrs old man...im not sure they still post on here anymore..
Old 12-04-2008, 06:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
im using the G-Force T/A KDWs, 245/40/18 front, 335/30/18 rear, with the flame like pattern. They are pretty good, but the do seem to wander a bit at higher speeds, 90+. But they do have quite good wet and dry traction. i had to drive almost 50 miles home from a meet in a torrential downpour this summer. My car doesn't really even see rain and i've never driven it in its current state in rain like that before, and wasn't very confident that i would have a good drive home. But i tell you what, driving home was a blast, the car was just glued to the road the whole way, never slipped/slid once and i was driving faster than i should have been.
but yea, old thread
Old 12-05-2008, 09:43 PM
bonddav's Avatar
how did you fit the 18s did you do mods or use spacers and what weels did you use
Old 12-05-2008, 10:08 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
I have g-Force sports on my car, Im simply amazed by them. They have a directional tread pattern, which makes it a good wet tire (atleast 10 times better than my old khumos). Ive put about 5000 miles on the tires, laid down quite a few strips, and the tires still look new, they are wearing quite nicely. Good traction,good handling,good wear,nice look, and theyre cheap. I suggest them to anyone.
Old 12-06-2008, 12:28 AM
Guest
Guest
Posts: n/a
I had BFG KDW g-force on my Camaro and was not impressed at all. As someone above has already stated, they wander above 90mph (88 mph to be exact on my Camaro). They are an average performance tire- much better out there, but at a cost.
As much as I hated the KDW tires on the Cmaro, I just put some new G-force "Sport" tires on my girlfriends Mercedes 320sport. They are an improvement over the regular KDW's, but still not he greatest. Tread does look great though, and they are a bit wider than the narrow rounded stance KDW tires. She likes the looks, amd does not drive fast- good for her and they are wearing decent after about 5k. I expect she will get 25K out of them driving normal.
On a scale of 1-10, I give the KDW tires a 6, and the sports a 7.5. The Goodyear GS-D3's I give a 9.5 (not a 10 simply because of a tad bit of feeling loss on corner turn in.- you get used to it though and gain back all confidence)
Old 12-07-2008, 08:45 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I've got the g-Force Sports on my car and they aren't a bad tire. Not had anything better, though. Wanting to get something better next time if I can afford it. Not a bad tire for the money, IMO.
Old 12-19-2008, 02:55 PM
blp226's Avatar
I have a set on the front and BFG drag radials on the back. No complaints.
Old 12-19-2008, 03:07 PM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
I have the G-Force Sports all the way around and love the way they ride!!
Old 12-19-2008, 03:16 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Glad you guys are liking them, I put them on my car and hate them....
Jason
Old 12-19-2008, 06:33 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
What exactly is a RS/Z28?
Old 12-20-2008, 05:46 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
245 50zr16's up front and 255 50zr16 out back... i like em and ive had em for 3 years on 2 different cars
Old 12-27-2008, 11:36 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
An RS that has been converted to a Z28...
Old 12-27-2008, 08:37 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Oh. I thought about re-badging mine with something after the Z28 spoiler and 'SS' hood, but I just decided to de-badge at some point. Still figured it was a RS even with the other parts.
Old 12-27-2008, 09:05 PM
Guest
Guest
Posts: n/a
...(grinning).....Mine went from a V6RS to a V6RSR.....I added the last R for "raceprepped".........or was it "rails"........ or was it "really cool"....... or maybe it was "rocket"......(scratches chin).....Nope, It definately wasn't "rocket".
My license plate read "On A Rail" meaning On rails as in cornering hard (On rails was taken), but I did not have any RSR badging on the car, thats just something I labeled it around here for one of my MANY screen names I was forced into having.
I have a new toy now, It is not going to have a label either, matter of fact I am taking the emblem off it and replacing it with something much more fashionable. Its a 1985 Cadillac Eldorado and it will be sporting a nice set of 36" Longhorns on the hood in place of the orniment. Figured this redheaded stepchild west coast NASCAR boy needed to up my southern image at the local tracks- gotta fit in with the good ol' boys. Attal fit the look. THe plate will be CAL RDNK. Maybe I will sport a TEX355 on the hood- we'll see.
Yeehaaaaaa
Old 02-09-2009, 07:45 PM
blp226's Avatar
I have them on mine and I like em. The car drives better and handles better with them than the goodyears I had before.
mitch_04
Members Camaros
20
09-20-2021 02:24 PM
customblackbird
08-15-2021 10:16 PM
Azrael91966669
25
06-20-2017 04:04 AM
Scorched1984
Wheels and Tires
66
04-16-2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
03-16-2016 07:07 AM
Quick Reply: Anyone here have BF Goodrich G-Force Z rated tires on their car?
