RS vs IROC Steering ratios
Car: 1988 Camaro IROC-Z
Just a quick question:
My '89 RS had a much tighter turning circle than my '88 IROC-Z does.
It also didn't make the grinds and groans that the IROC-Z does (specifically a grind on full right - I know, I know, full lock should be avoided but we live in an imperfect world).
So, were the ratios different? If I could the steering of my RS onto my IROC, I'd be a happy man.
As part of my quest to get rid of the full-right-grind I suspect I'm going to end up replacing most, it not all, of the front steering set up, so I'm wondering if I should be factoring a new box to the bill as well.
Re: RS vs IROC Steering ratios
Here's some general steering box info (I'd like to give credit, but I don't recall where I found the info):
• “WS” – 1982-1992 Camaro – 12.7:1 ratio (just like your Z/28, this may be the box that you Z originally had.
• “XH” – 1985-1992 Camaro – 12.7:1 ratio (this box was also installed on Z/28’s and other high performance Camaros; it has slightly more steering effort required than the WS box.) NOTE – I believe this box was used on cars originally equipped with 16” wheels
• “WN” – 1982-1985 Camaro – 14.1 ratio
• “WP” – 1982-1985 Camaro – 13:1-15:1 variable ratio (used in Berlinettas, least steering effort required of all third gen. Camaro steering boxes)
• “JL” – 1986-1992 Camaro – 14.1 ratio (base Camaro steering box)
JamesC
Interesting, cheers for that.
Just wondering because I could turn the RS straight into my driveway, but the IROC needs a kinda 3 point manoeuvre to get her in. I guess the 16" wheels and the different stops are the reason why.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Thanks for this informaiton JamesC. I am looking into a steering box upgrade and wanted to make sure I don't buy the same ratio box just cleaned up.
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
The a-arm steering stops are different between 15" and 16" wheels (IIRC, the steering box stops are different as well). The wider IROC wheels/tires wouldn't help the the 'pushing/jumping reaction either.
JamesC
JamesC
TXs
Dennis
Car: 89 Firebird
Engine: 355 TBI
Im not sure the part # but I got the fast ratio steering box replacement for my 89 WS6 Formula and WOW what a difference it was from any 3rd gen ive had as far as steering. If I remember right there were several different ones I could order but I went with the performance one that came with my car. But in saying that I replaced almost every suspension part and bushings under the whole car. World of difference
Car: check
Engine: check
Transmission: check
The problem is the ink, it doesn't last. So it becomes difficult to see the code on the box. RPO codes can help as certain steering boxes were dedicated to certain suspension & wheel/tire combinations.
But it isn't the end all to be all, as a different box could have been installed.
Counting input shaft turns lock-to-lock is helpful. So is using a protractor on the output shaft to measure the center-to-lock angles.
RBob.
backtothe80s
09-05-2015 12:39 AM
mustangman65_79
08-11-2015 03:17 PM
