torque arms and subframe connectors
Old 02-21-2012, 06:53 PM
mtac454's Avatar
I have a 454 with a th400 in my 89 camaro, and I have a couple questions. How much will my car hold up with the stock torque arm and no subframe connectors? When I bought the crossmember that I have, I also had to built my own brace for the torque arm. If I bought a transmission mounted torque arm will it mount onto the th400 because I don't want to buy another crosmember, and I know it won't mount onto the brace I made. If I have to buy another crossmember i would rather just get the parts to get it four linked. All advice will be appreciated.
Old 02-21-2012, 07:17 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: torque arms and subframe connectors
454 and a TH400 will warrant some SFC's one way or the other. I've seen people twist their cars until the dash is a rattling mess with bolt on 350's and hard daily driving.
If you buy an aftermarket torque arm, just buy one that comes with it's own crossmember and mounting point. Mounting to the transmission case on that setup is asking for trouble. You are definitely flexing it if you launch hard at all... and possibly cracking that case in the future.
Old 02-21-2012, 08:00 PM
UMI Sales's Avatar
I think your first sentence is the best thing I've read this week. Or maybe month.
We would love to have you take a look at UMI.
Did I mention 454 in a third gen sounds awesome.
ramey
http://www.umiperformance.com/catalo...=index&cPath=6
Old 02-21-2012, 08:49 PM
mtac454's Avatar
i barely even do burnouts, and i have only pulled off in first once. I had people complaining on youtube (bigred8944 is my account name) that i don't get into it hard enough, part of the reason i haven't made the engine radical is because i don't want to mess up the frame before i get it reinforced. Thanks for the advice i just didn't want to buy another crossmember, because originally i bought a universal one and it didn't fit, then later on i bought the one i have now. it was the first one i found that was guaranteed to fit. i found some from spohn that were 369.99, do you think those will hold up or do i need to buy the super heavy duty chrom-moly ones?
Old 02-21-2012, 09:01 PM
mtac454's Avatar
ramey
Thanks. Do you happen tu know the difference between the 2218 and the 2219 kit because the description appears to be the same but i could be overlooking something. I would assume that the more expensive one is stronger but it doesn't say.
Old 02-21-2012, 11:41 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Especially in your case, you need a standalone crossmember for the torque arm.
https://www.thirdgen.org/forums/post...819-post3.html
Looking at that picture will make it pretty obvious. Look at the link I provided in my post in the link (LOL) for more details.
You can run a crossmember-mounted Torque arm mount... but I just think its asking for trouble, especially with that kind of power.
And this is why you need subframe connectors at the STOCK power level:
https://www.thirdgen.org/forums/body...eet-metal.html
Old 02-22-2012, 07:37 AM
UMI Sales's Avatar
Mechanically the same, one has the driveshaft loop. Same strength and both able to withstand big block power.
ramey
Old 02-23-2012, 05:41 PM
mtac454's Avatar
Do you know of any stand alone torque arm kits? I braced mine onto the crossmeber but i never planned on keeping it there.
tglennon11
09-23-2015 05:30 PM
Nick McCardle
09-10-2015 08:36 PM
Chevy86 IROC-Z
09-07-2015 01:13 AM
middian
09-05-2015 01:42 AM
Quick Reply: torque arms and subframe connectors
