1991 Camaro Suspension Parts
Car: 1991 Camaro Z28
Engine: 383
Transmission: tci 700r4
Axle/Gears: 373
Planning on ordering some stuff in the near future and wanted to see what yall thought of my choices? I cant decide which SFC's to use which will be where I start. Them and the LCA's and PH bar. Then Probably the torque arm kit. Anyway Suggestions or comments appreciated.
Founders Performance
Lower Control Arms Relocation Brackets 48$
http://www.foundersperformance.com/p...-Brackets.html
1982-2002 On Car Adjustable Lower Control Arms & Panhard Bar Kit Rod/Rod 209$
http://www.foundersperformance.com/p...B47%7DRod.html
UMI Performance
1982 - 1992 GM F-Body Tunnel Mounted Torque Arm- Fits 700R4 & T5 Transmissions 440$
http://www.umiperformance.com/catalo...08612e91d1643c
BMR Suspension
STB004 - Strut Tower Brace, 3 Point Mount, TPI Only 190$
http://www.bmrsuspension.com/index.c...&productid=377
SFC009 - Subframe Connectors, Weld-on, Boxed, Outside Frame Exhaust 230$
http://www.bmrsuspension.com/index.c...&productid=394
Spohn Performance
Tubular Sub-Frame Connectors - T-Top & Hard Top Cars - 1982-1992 GM F-Body: Camaro & Firebird 199$
http://www.spohn.net/shop/1982-1992-...-Top-Cars.html
UMI Performance
BMR Suspension
Spohn Performance
Engine: 383
Axle/Gears: 373
Re: 1991 Camaro Suspension Parts
Buehler Buehler????? Anybody care to share their thoughts on the subframe connectors?? Kinda curious what everyone thinks is best.
Car: 1991 Camaro RS
I can't comment on the quality of the subframe connectors, but my adjustable panhard bar and lower control arms are Sphon, and I have been running them on my car for 3 years now with no problems.
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
I have a 1986 LG4 T5 IROC and am interested in the latest SFC recommendations too. I started with Spohn tubular lower control arms which helped with the wheel hop.
Alsoo I'd like to know which of the recommended SFC installations if any give us better jacking points under the car that are stronger.
Car: 1987 Black IROC-Z (SOLD)
I went with Spohn Tube type SFC because they tuck up out of view and also their Tube type LCA's & Panhard bar. Car is as good as when I had the Spohn parts installed 10+ years ago. Original owner and with the above SFC's my 25 yr old is tighter now then when new.
Engine: 383
Axle/Gears: 373
I was really thinking of going this route and if it dosent stiffen it up enough for me then adding the internal ones from alston I think is who makes them. Between the two it ought to be stiff.
Thanks for including us on your list!
Our SFC's work great and also are pretty stealthy with regards to visibility. You can't even see them on our IROC unless you get down to ground level.
ramey
ramey
UMI Performance
BMR Suspension
Spohn Performance
UMI Performance
BMR Suspension
Spohn Performance
Engine: 383
Axle/Gears: 373
I did like yours as well. If fact i think i meant to add those to the list but forgot to. I got to looking at too many brands. lol. Lots to choose from and kinda overwhelming when your used to building the stuff yourself for trucks. lol
Engine: 383
Axle/Gears: 373
anyone ever use these from Jegs. Mine will of course be welded just be nice to be able to bolt them in at home then take it to a lift to weld them in the resto of the way.
http://www.jegs.com/i/Jegster/550/40053/10002/-1
Car: 91' RS CAMARO
Engine: 305 V8
DO I NEED TO SWAP ALL THESE OUT FOR A FRONT AND REAR BUSHING SWAP? WENT FROM ORIGINAL RUBBER TO POLY... GOOD OR BAD?
ALSO, ON THE PARTS SHOWN, WHAT EXACTLY ARE THESE FOR ? FRONT AND REAR NAMES PLEASE...
Thanks for the mention.
The main bracing is 1/8" and the rear mounts are 3/16". Everything is built in our building in Philipsburg, PA and always of US materials!
ramey
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
1991, 1992, 91, boxed, camaro, connectors, kit, parts, performance, spohn, stiff, subframe, suspension, umi, weldin
