Tell me about the strut tower Bearing/Plates, Different options.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, i am unsure what they are called but I am intrested in changing my Strut tower plates and would like info as far as pros and cons and different options. Thanks
Re: Tell me about the strut tower Bearing/Plates, Different options.
That said, I note that you're running an Edelbrock STB. With that brace in place, I couldn't align the car as I wanted using the Spohn mount (and the alignment was nothing outlandish), so I swapped in the Founders version thinking that the added adjustments would eliminate the problem. Nope. Even the Founders mount required modification.
JamesC
Car: 86 Z28
Are they worth the Money? What do they offer over stock? How do you check if your stock ones are worn out?
Car: 86 Z28
They look fine i think, What is the going price for these?
Here are the founders:
http://www.foundersperformance.com/p...er-Plates.html
Mine came out good. They made a noticeable difference to my steering.
Here's a copy and paste from one of my other posts, it describes my experience with them:
Originally Posted by NOSHOWALLGO;
Keep in mind my situation when I installed mine; My steering had EVERYTHING rebuilt with moog parts, I had Koni Yellow struts, a new rag joint & steering box rebuild & power steering pump rebuild all installed in one weekend. The strut mounts where an over-sight on my part, so I had to stick with the worn out rubber stock mounts for a few months.
The reason I'm telling you this is because I had next to no weak links in my front suspension besides my stock rubber strut mounts. Prior to installing my solid bearing strut mounts, The steering feel was excellent. After installing the founders SM I was surprised, the steering now feels better then it did before. Before there was a slight delay in the steering, where as now it just goes where you point it.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
1) More adjustment for alignment settings (more aggressive options available)
2) The stock rubber strut mounts have a wobble going forwards/backwards as well as side to side. This means your struts aren't getting the work they're supposed to....The solid bearing strut mounts put all the movement into the struts themselves. This lets the struts perform to a higher performance.
Car: '89 GTA 350 hardtop
I've originally gotten the moog mounts off rockauto. I was aware one of the slots is twice as wide as needed in order to acomodate all years thirdgen for some of the mounts, but the moog ones pictured on the website showed the slots the right size (all 3 narrow). They were 130ish if memory serves.
The rubber in my mounts was awesome, but after I took it off the bearing had some minor binding. Decided to change for this reason alone.
I got the mounts and then I noticed the third slot was wide... and they didn't even provided some washers. That was substandard, esp for a moog part and the picture on the website misleading. On a side note, just verifying the application years should have revealed it fit all years (so wide slot). Not only that, but the plate is constructed of 2 sheets of metal stamped together (poorly, worse than my originals). So I had to return. For only $40 more I got the founders. Awesome product and beef like all hell. The adjustting slots were longer so they barely accomodated my aggresive street spec (1" camber).
All in all they look trick, they compliment nicely my underhood look vs the stupid replacement where I should have used the big *** washers).
PS: I was a little nervous about the rubber missing, fearing they may transmit some NVH but completely unfounded, they're awesome.
Car: 86 Z28
$170 for the set I guess isn't bad, So after putting these on Ill have to realign the car correct.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
The biggest difference I found with the aftermarket plates was brand and price. Most are the same design.Check them all out. UMI, J&M products, founders spohn, are all I can remember right now. I have j&m products but IIRC founders are identical and cheaper.
yes u have to ralign. u'll find the alignment is easier beeing that u can adjust cmber separately from camber
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
You don't HAVE to get the car aligned after installing CC plates. You can usually eyeball where the caster and camber should be. I would certainly recommend an alignment after changing the toe, but the toe won't be changed by just installing CC plates.
The factory went with rubber for a reason. Is it because its cheaper? I've heard that strut mount bearings like these aren't very long-term reliable, although none of that was in reference to any thirdgen, more of a general observation of these types of suspension setups. Any of you guys know about that? Anyone noticed any excessive wear over a few years?
gixxer92
05-18-2017 11:20 AM
LT1Formula
10-08-2015 08:34 PM
