Sway Bar Clamp Cracked
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
I was changing my oil yesterday & noticed the metal clamp that goes over the passenger side front sway bar is cracked. I have another one, just want to paint it & switch it out. What would cause this to crack? I have a wonder bar & 34mm sway bar on an 84 Z28. Maybe I took corner too hard? Are these known to crack? Maybe stress/age? Just curious, thanks for any input
Received 1,672 Likes
Re: Sway Bar Clamp Cracked
Old age, most likely.
Just get a set of Energy Suspension or similar; they come with new ones anyway.
Replace the end links while you're at it. You WON'T BELIEVE the difference. You'll literally kick yourself in the butt for not doing it sooner.
thanks 4 all the replies, did put new energy suspension bushings on 10/2013 when I switched out the sway bar & new end link, It handles great, will chock it up to old age/stress & replace this weekend. This website is the best thanks again
camaro1185
10-26-2015 06:51 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
